POV-Ray : Newsgroups : povray.unofficial.patches : megapov rotate -x*90 error Server Time
29 Sep 2024 01:21:22 EDT (-0400)
  megapov rotate -x*90 error (Message 1 to 5 of 5)
Subject: megapov rotate -x*90 error
Date: 3 Apr 2001 21:08:42
Message: <3aca741a@news.povray.org>
Hi all
moray.zip contains the output from moray of a simple scene. torus, camera
and a light.
it renders perfectly in megapov when in normal mode.
clunk.zip contains exactly the same, except I have added the version info to
the main pov and ini file, now it clunks with
torus { //Torus001
    1.5, 0.5 rotate -x <----ERROR
untitled.pov:96: error: no matching } in torus, * found instead.
I am using winmegapov 0.7, on windows 2k.
manually editing the files in not an option, as I mentioned in the pbi
thread, I regularly do very complex nested csg creations, and it has not
been unknown for them to include hundreds of objects. there is no way in
hell I am going to edit that by hand. that is the reason I use a modeller.
as this only happens in mega pov when the version line is added, I don't see
that it is a problem that should be addressed by Lutz, as its is obviously a
mega pov bug.
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Download 'moray.zip' (3 KB) Download 'clunk.zip' (3 KB)
Subject: Re: megapov rotate -x*90 error
Date: 3 Apr 2001 23:24:24
Message: <3ACA92CA.89FC11DD@videotron.ca>
"Rick [Kitty5]" wrote:
> Hi all
> and a light.
Bingo.  It seems the "Version" parameter in the ini file is not meant
for text strings.
Read the message screen and you'll find out why!
Strangely enough, moving the semi-colon to the beginning of the line
fixes everything.
Francois Labreque |   //\\    Wear an ASCII ribbon!
    flabreque     |  ||  ||
        @         |   \\//    Support the campaign
   videotron.ca        \\     against HTML e-mail
                      //\\    and news!
Date: 4 Apr 2001 16:32:49
Message: <3ACB84EC.C61126DE@pacbell.net>
>    moray.zip    Type: Zip Compressed Data (application/x-zip-compressed)
>             Encoding: x-uuencode
>    clunk.zip    Type: Zip Compressed Data (application/x-zip-compressed)
Is it really necessary for me to remind you that binaries attachments should
not be posted in a non-binaries group ?
Ken Tyler
Date: 14 Apr 2001 00:09:48
Message: <3ad7cd8c$1@news.povray.org>
"Francois Labreque" <fla### [at] videotronca>...
> > Hi all
camera
> > and a light.
info to
> for text strings.
> fixes everything.
Francois, you provided all the correct info, but in such a mysterious way
that I think I will get bug reports about this if I don't clarify:
The INI parser doesn't understand POV script.  Therefore, when it sees the
"#version unofficial..." string, it thinks you're setting the version to
zero.  As Francois points out, the message screen displays, "Input file:
untitled.pov (compatible with version 0)."  Way back then in version 0, the
expression parser didn't support the "-x*90" syntax.
(Moving the semicolon to the beginning, of course, comments out the line in
the INI file.)
-Nathan
Date: 14 Apr 2001 00:22:02
Message: <3AD7CF39.F01135D0@videotron.ca>
> info to
> > for text strings.
> > fixes everything.
Sorry about being a bit sarcastic, but I hate it when people don't look
at the messages on their screens and double-check the docs.  I hope I
didn't offend anyone.
> the INI file.)
Hence the smiley.
Francois Labreque | It is by caffeine alone I set my mind in motion, it
    flabreque     | is by the beans of Java that thoughts acquire speed,
        @         | the hands acquire shaking, the shaking becomes a
   videotron.ca   | warning, it is by caffeine alone I set my mind in
                  | motion.
                               - Stolen from Badger's .sig file
