POV-Ray : Newsgroups : povray.unofficial.patches : library path with mcp 0.7 Server Time
11 Jul 2026 23:18:23 EDT (-0400)
  library path with mcp 0.7 (Message 1 to 2 of 2)
Subject: library path with mcp 0.7
Date: 8 Mar 2001 06:09:16
Message: <3aa7685c$1@news.povray.org>
With Megapov mcp it seems that I always have to declare the library path in
every ini file (even c:\programs\pov bla bla 3.1\include). Why doesn't it
recognize the ini path stored in the main ini file of povray?
Besides I noticed mcp crashes every time I use the isowood include file.
Subject: Re: library path with mcp 0.7
Date: 8 Mar 2001 06:25:45
Message: <3AA76C39.D9B75462@gmx.de>
Like the unix version, The cygwin compile searches for an ini file:
- specified by POVINI environment variable
- ./povray.ini
- $HOME/.povrayrc
- POV_LIB_DIR/povray.ini where POV_LIB_DIR is set to
/usr/local/lib/povray31
You therefore only have to place a povray.ini in the same directory as the
executable or specify a POVINI environment variable.
That's a known problem occuring with black_hole warps using turbulence.
It also occurs in Megapov 0.7.
Vahur Krouverk made a fix in PovMan 0.71, but i did not yet have time to
include it in MCP.
