POV-Ray : Newsgroups : povray.unofficial.patches : Glows: color vs. size ? Server Time
2 Apr 2026 03:56:25 EDT (-0400)
  Glows: color vs. size ? (Message 1 to 3 of 3)
Subject: Glows: color vs. size ?
Date: 17 Feb 2001 16:06:15
Message: <3a8ee7c7@news.povray.org>
The MegaPov glow feature has a size keyword which controls the size of the
glows as a scaling factor.
However, the apparent size of glows can also be controlled by adjusting the
color.
The code below shows that there's very little difference between multiplying
the size with a factor and dividing the color with the same factor. Try to
change the value M to values from 0.1 to 2.
#version unofficial MegaPov 0.7;
#declare M = 1;
glow {type 0 location -x color 0.1*M size 1}
glow {type 0 location +x color 0.1   size 1*M}
camera {location -4*z look_at 0}
box {x,x}
The code below shows that the same thing but in a different way. Here you
can change the M value from anything from 0.000001 to 1000000 and still the
difference is rather small.
#declare M = 0.1;
glow {type 0 location -x color 0.1   size 1  }
glow {type 0 location +x color 0.1*M size 1/M}
box {x,x}
So, what exactly is the point of the size keyword? How can it be used to
achieve results that can not be achieved with the color alone?
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 28)
/ Also visit http://www.povrayusers.org
Subject: Re: Glows: color vs. size ?
Date: 18 Feb 2001 22:00:07
Message: <chrishuff-2DCA5D.21594418022001@news.povray.org>
In article <3a8ee7c7@news.povray.org>, "Rune" <run### [at] inamecom>
> the color.
With some glow types, the size keyword works by adjusting the color
brightness, but it uses a different method for other glow types.
To adjust the size of the glow.
> How can it be used to achieve results that can not be achieved with
> the color alone?
Depending on your glow type, the differences between the results can be
extreme or nonexistent.
Christopher James Huff
Date: 20 Feb 2001 11:14:10
Message: <3a9297d2@news.povray.org>
> the color brightness, but it uses a different method for
> other glow types.
> results can be extreme or nonexistent.
Ah, thanks.
I will look more into this later...
Rune
