POV-Ray : Newsgroups : povray.unofficial.patches : Glow Tutorial? Server Time
17 May 2026 09:35:00 EDT (-0400)
  Glow Tutorial? (Message 1 to 9 of 9)
Subject: Glow Tutorial?
Date: 5 Feb 2001 07:38:50
Message: <3a7e9ed9@news.povray.org>
There doesn't seem to be anything on glows in the Megapov docs.  Anyone know
where I can find a tutorial?  I've got the options from various examples,
but I don't know what the various parameters do, and experimenting with
types and the like has be less than illuminating (no pun intended, really)
Also, do glows interact with other objects?  When I placed a glow in a hole
in one object, I got glow effects on the outside of the object.  Is that
supposed to happen?
Geoff
Subject: Re: Glow Tutorial?
Date: 5 Feb 2001 11:14:16
Message: <3A7ED158.8CD2A6F8@gmx.de>
I have some sample pictures on:
http://www.schunter.etc.tu-bs.de/~chris/pov/glow.html
but i don't know if they are useful.
> supposed to happen?
Yes, but using additional parameters like size and fade_power sometimes
also leads to wrong interactions.  This is a known problem.
Date: 5 Feb 2001 12:55:28
Message: <3a7ee90f@news.povray.org>
They are, but only from an intuitive sense.  It seems that type 1 has a
double boundary, for lack of a better word, which is to say there is a white
area, then a colored then it drops sharply as it fades out.  T0 has a white
boundary, but fades out much more smoothly from there.  Size affects how big
and bright, radius cuts off the glow effect after a distance, and fade power
changes the sharpness of the drop off.  That's basically all I needed to
know.
>> supposed to happen?
Drat.  I was afraid of that.  Can you size the glow by intensifying the
color, then, or would that not work?
Geoff
Date: 5 Feb 2001 13:26:00
Message: <3A7EF02E.6E2722ED@gmx.de>
That 'double boundary' is only due to 'overexposure', meaning that the
brightness of the glow exceeds the output range.
That's possible, it was the only way to influence a glow's appearance in
earlier versions.
Date: 5 Feb 2001 16:29:45
Message: <3a7f1b49@news.povray.org>
What's wrong with chapter 9.21 of the Megopov 0.6 docs? Not that long, but
it tells the basics, I think. But "glow" is indeed no keyword in the
index-list ...
Marc-Hendrik
Date: 6 Feb 2001 07:44:19
Message: <3a7ff1a3@news.povray.org>
> index-list ...
Yeah, it doesn't show on the index, and for some reason, doing a find didn't
work.  And doing scans on object types and such wasn't helpful either.
But speaking of which, while nosing around the povray ftp site, I saw a
bunch of files for Megapov 0.7.... Is there actually going to *be* a megapov
7?  I thought we were waiting for 3.5 before creating a new megapov.
Geoff
Date: 6 Feb 2001 08:45:03
Message: <3a7fffdf@news.povray.org>
>> index-list ...
Er, um, I guess there is a 0.7... posts crossing in the wind. ;)
I see size works now.  Does transforming a glow in a union?  Doesn't say so,
so I guess probably not.
Geoff
Date: 6 Feb 2001 19:09:01
Message: <chrishuff-01DFBF.19100206022001@news.povray.org>
In article <3a7fffdf@news.povray.org>, Geoff Wedig
> so, so I guess probably not.
I'm not sure how much of the glow code I sent them was used, I had
partially started something like this.
In the future, it will be an effect that is added to objects, and it
behaves more like media than an object, so don't rely on it being
transformed along with an object. (though I may add a glow_object to
help work around this)
Christopher James Huff
Date: 7 Feb 2001 08:00:10
Message: <3a8146da@news.povray.org>
Well, it works weirdly.  If I attach a glow to a declared light, with the
light in a CSG object later, the transforms on the CSG seem to affect the
glow (it travels with them), but the transforms directly on the light (in
the light statement itself, even) don't seem to.  It stays at the light's
base position.  Still, at least if the glow is transformed the same as the
light in the bounding CSG, that makes things a little bit better, since I
can do the light's transforms on the glow manually if need be.
Geoff
