POV-Ray : Newsgroups : povray.unofficial.patches : Re: Torus Torture Server Time
27 Jul 2026 12:21:11 EDT (-0400)
  Re: Torus Torture (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Torus Torture
Date: 18 Jan 2001 19:40:34
Message: <chrishuff-855580.19413918012001@news.povray.org>
In article <3a6746fe@news.povray.org>, "Rune" <run### [at] inamecom>
wrote:
> "Wlodzimierz ABX Skiba" wrote:
> > I plan to mix [the deform patch] with tessalation patch
> > and allow one directional deformations for meshes and
> > bidirectional for other objects
> That's interesting. The mesh deformation would be handled in a
> *completely* different way than for other objects, right?
I think he is talking about a different deformation method that will
work for all objects, but work by first converting them to a mesh.
> Also, my macro gives the user full control over the deformation. How
> would the user control the deformation in your patch? (I mean the
> deformations for meshes.)
Similar to the way patterns and warps are done: a set of predefined
deformations and maybe function-defined deformations. Maybe warps too.
Christopher James Huff
Date: 19 Jan 2001 04:31:46
Message: <3a680982@news.povray.org>
Rune wrote in message <3a6746fe@news.povray.org>...
> That's interesting. The mesh deformation would be handled in a *completely*
deformation applied to mesh copy array of recalculated vertex to another memory
location or aplies function to vertex during tracing - first solution: slow
parsing and memory wasting but fast rendering, second solution: fast parsing and
memory saving but slow tracing - this could be parametrized
> > > Doesn't this slow down the rendering?
> > a little
> > my parsing time is not changed
> But for deformed meshes the parsing time would increase and rendering time
 >would be unchanged, like with my macro, I think.
but pach is faster than macro
and I think this is good usage patch solution instead of macro solutions
> I'm sure a mesh deforming patch would be much quicker than my mesh deforming
> macro. It's just that nobody has made such a patch *yet*...
but you are not first how think of it
I'm not first neither.
I have read nearly whole pov-ray news and I meet such propositions many times.
But not everyone has such programing skills.
> Also, my macro gives the user full control over the deformation. How would
> the user control the deformation in your patch? (I mean the deformations for
> meshes.)
I'm waiting with user control deformations for release 3.5 becouse I plan use
functions but want patch them first (if pov-team doasn't) to pass more
parameters. Functions stuff is so complicated and I don't want duplicate such
complicated work.
ABX
Date: 19 Jan 2001 04:59:51
Message: <3a681017$1@news.povray.org>
Chris Huff wrote in message ...
I think about joining my method and method with deforming vertices
my method will be applied when you type predefined deform i.e. twist
or type deformations with two defined functions (bi-directional deformation)
box
  1, 1
  texture { texture stuff }
  deform {twist 7}
  deform {MyDeformFunc(x,y,z,7,11) MyUndeformFunc(x,y,z,7,11)}
but when you put only one user defined function or you type deformations
one-directional - this cause error
box
  1, 1
  deform {warp{...}}
  deform {MyDeformFunc(x,y,z,3,5)
noticed parsing *Error*: Only one direction of deformation specified - to achive
proper shape please tesselate it first!
and user must add tesselation with parameters he wants
box
  1, 1
  tesselation { 7, 13, 15}
  deform {warp{...}}
and this is parsed ok.
note that parameters above are only example and has no meaning
this way for such simple deformations like twisting you don't need waste memory
for copy of recalculated vertex becouse all is done with curved ray - but there
is gate for user defined deformation
there is even place for control points
#declare DeformationByControlPoint=
  function
    Point_X,
    Point_Y,
    Point_Z,
    ControlPoint_X,
    ControlPoint_Y,
    ControlPoint_Z,
    Radius,
    Power=1
   /* function changes Point if it is less than radius from Control Point */
#declare MyDeform=deform
  deform { DeformationByControlPoint(x,y,z,1,2,3,2)
  deform { DeformationByControlPoint(x,y,z,7,1,2,4,2)
  deform { DeformationByControlPoint(x,y,z,5,3,1,10)
box
  -1,2
  texture {}
  tesselate {}
  deform { MyDeform }
please notice that you are really convincing
in talking about warps deformations
ABX
Date: 19 Jan 2001 05:49:58
Message: <chrishuff-FB6DA2.05510119012001@news.povray.org>
In article <3a681017$1@news.povray.org>, "Wlodzimierz ABX Skiba"
> deformation)
...snip...
...snip...
> - to achive proper shape please tesselate it first!
> box
>   1, 1
>   deform {warp{...}}
I'm not sure this is a good idea...what if the user wants to use
ordinary deformations on tesselated objects, which are just meshes?
Sometimes you have very low resolution meshes which are representing
straight edged objects (a 12-triangle cube mesh, for example), and if
you apply per-vertex deformation without subdividing the triangles, it
will look pretty ugly. Subdividing the triangles is another thing to
think about, but after the basic functionality is there...and my point
is that the user should be able to choose the method.
For example, have "method 0" be the "direct displacement" method which
has highest possible accuracy but is limited to reversable deformations,
and "method 1" be the per-vertex method. When "method 1" is used, have
optional tesselation information in the deform block...POV would
automatically tesselate the object if needed (or "always_tesselate"
could be turned on to process meshes).
box {1, 1
    deform {warp{...}
        method 1
        tesselation_options {
            [always_tesselate on|off]
            [other options and parameters]
> note that parameters above are only example and has no meaning this
> memory for copy of recalculated vertex becouse all is done with
> curved ray - but there is gate for user defined deformation
I like your function syntax. :-)
I'm not sure how the function does a deformation, though...are you
planning to extend them to return vectors, or to allow them to modify
their parameters? Or will you create a special kind of function that is
3 ordinary functions bundled into one? I kind of like that last
solution, especially if functions are allowed to have variables...I
think the basic syntax should remain scalars-only, though.
#declare DeformationByControlPoint =
function_3d(
    Point_X,
    Point_Y,
    Point_Z,
    ControlPoint_X,
    ControlPoint_Y,
    ControlPoint_Z,
    Radius,
    Power=1)
    local Foo = blah blah...;
    {x = Bar1;},
    {y = Bar2;},
    {z = Bar3;}
I was? It didn't seem like it at the time... ;-)
BTW, I saw your question about reversable turbulence in
comp.graphics.algorithms, but it disappeared before I could reply...I
probably just forgot to mark it unread. Anyway, you might find more help
if you say it is a Perlin noise texture deformation.
Date: 19 Jan 2001 11:18:45
Message: <3a6868e5$1@news.povray.org>
"Chris Huff" wrote:
> > How would the user control the deformation in your patch? (I mean
> > the deformations for meshes.)
Predefined deformations does not give the user full control. Nor do warps.
POV-Ray functions returns floats and not vectors, don't they?
The only way the user can get full control, is by using functions where both
input and output are vectors.
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 6)
/ Also visit http://www.povrayusers.org
Date: 19 Jan 2001 11:18:46
Message: <3a6868e6$1@news.povray.org>
> patch is faster than macro and I think this is good usage
I fully agree about this.
But a macro can be useful until the patch is ready.
It is also possible that the patch is not as flexible.
Will the user be able to use functions where both input and output is
vectors? That would be the only way to get full control over the
deformation.
Rune
Date: 19 Jan 2001 12:06:47
Message: <3a687427@news.povray.org>
Rune wrote in message <3a6868e6$1@news.povray.org>...
I agree with it, but ... patch is nearly ready :-)
I don't want to forbid you play with your stuff
I'm just trying to compare results
if patch serves more accurate result it is worth to play for me.
perhaps you missed example: http://www.abx.art.pl/pov/nonlinear/step3.jpg
more images after weekend with wife and daughter :-)
and .... can you twist plane{} ? :-)
result is very interesting, belive me
> vectors?
in my specifications of possibilities, yes
in first version, no
> deformation.
this is part of my greater plans
I want patch functions to allow:
1. more/less input parameters
2. more output values
3. default values for some input parameters
4. local variables
5. calling during parsing
I've started with such patch in November and 1. and 3. works fine and 5. seems
be easy
but 2. and 4. is big thing and therefore I wait with that for source of POV 3.5
becouse I don't waste time for double coding. I don't know structure of sources
designed by Team for functions in 3.5 therefore I must wait.
ABX
Date: 19 Jan 2001 13:08:44
Message: <chrishuff-BF57E9.13094919012001@news.povray.org>
In article <3a6868e5$1@news.povray.org>, "Rune"
> warps.
Yes, but it might be possible to combine three of them into a single
function that returns a vector. This would be best with variables in
functions, but would be quite useable otherwise.
Or you could just use three separate functions...
Date: 19 Jan 2001 14:25:25
Message: <3a6894a4@news.povray.org>
Well, they could always define a function for each of x,y,z.  Little messy,
though.
Geoff
Date: 19 Jan 2001 15:46:09
Message: <3a68a791@news.povray.org>
But maybe your patch is better for some purposes while my macro is better
for others.
Not an infinite plane obviously, since meshes can't be infinite.
> > and output is vectors?
With my macros user-defined deformations are very easy simple.
This is a simple twist:
#macro deform_mezz (P) vrotate(P,120*x*P.x) #end
How would a user-defined twist look with your patch?
(I do *not* mean the build-in twist-deform. I mean user-defined function!)
Rune
