POV-Ray : Newsgroups : povray.unofficial.patches : Bump_maps + Mesh + MegaPov? Server Time
19 Nov 2025 03:51:52 EST (-0500)
  Bump_maps + Mesh + MegaPov? (Message 1 to 10 of 10)
Subject: Bump_maps + Mesh + MegaPov?
Date: 13 Jan 2001 22:27:50
Message: <3a611cb6@news.povray.org>
I'm not getting bumps from image_maps. Is this broken for mesh objects?
Forgive me if I'm posting on a known thing. I'm pulling hair over here! :)
Grim
Subject: Re: Bump_maps + Mesh + MegaPov?
Date: 14 Jan 2001 00:27:26
Message: <3a6138be@news.povray.org>
I meant no bumps result from using an image as a bump_map?
Grim
"GrimDude" <gri### [at] netzerocom> wrote in message
news:3a611cb6@news.povray.org...
> Grim
Date: 14 Jan 2001 01:23:03
Message: <3a6145c7@news.povray.org>
Is it paletted?  :-)
Bob H.
news:3a6138be@news.povray.org...
Date: 14 Jan 2001 01:56:04
Message: <3a614d84@news.povray.org>
That's a good question. I tried two color png, and two color bmp.
Grim
"Bob H."
<per### [at] aolcom?subject=PoV-News:%20&body=Relating%20to%20POV-Ray:>
wrote in message news:3a6145c7@news.povray.org...
> Is it paletted?  :-)
> Bob H.
Date: 14 Jan 2001 02:30:08
Message: <3a615580@news.povray.org>
I got it. I had to up the bump_size to 5k and use an image overlay to
augment the bumps. This won't work well with my aluminum surface normal. :(
Grim
news:3a614d84@news.povray.org...
> Grim
> "Bob H."
> > Is it paletted?  :-)
> > Bob H.
Date: 14 Jan 2001 13:16:06
Message: <3A61ECBE.E3A85E4C@inapg.inra.fr>
Are you sure that your bump map is contrasted enough ? For instance, the bump
maps that come with Poser have little contrast, so to make them usable I
convert them to B&W and increase the contrast. It's easier to control if you
have the full range of tones between black and white.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 14 Jan 2001 23:47:40
Message: <3a6280ec@news.povray.org>
Thanks for that, Gilles.
I ended up using a bump_map image twice the size of the first.
I haven't had any trouble stacking pigments, but everytime I stack normals I
get problems. Is there a trick to applying more then a single bump_map to a
single surface?  I like my aluminum to look a little wavy, but other
features are best represented in the normal differently. Material map?
Hmmm,...
Grim
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:3A61ECBE.E3A85E4C@inapg.inra.fr...
bump
you
> G.
> Graphic experiments
> Pov-ray gallery
Date: 15 Jan 2001 04:13:46
Message: <3A62BF23.65F74535@inapg.inra.fr>
> single surface?
You can trying averaging normals.
normal{
    average
    normal_map{
        [1 bump_map1] // the number is the weight of the map
        [1 bump_map2]
In fact, the doc says that "average was originally designed to be used in a
normal statement with a normal_map as a method of specifying more than one
normal pattern on the same surface", so this may be the most efficient way to do
it.
G.
Graphic experiments
Pov-ray gallery
Date: 15 Jan 2001 21:20:42
Message: <3a63affa@news.povray.org>
Thank you, Gilles!
...click...click...whirrr... (got me thinking)
Grim
news:3A62BF23.65F74535@inapg.inra.fr...
normals I
to a
> > single surface?
> normal{
>     average
>     normal_map{
>         [1 bump_map2]
a
to do
> it.
> G.
> Graphic experiments
> Pov-ray gallery
Date: 17 Jan 2001 00:24:01
Message: <3a652c71@news.povray.org>
I finally resorted to a 16 color image for a material map. It requires a ton
of texture code, but,...WOW!
Grim
news:3a63affa@news.povray.org...
> Thank you, Gilles!
> Grim
> normals I
> to a
> > > single surface?
> > normal{
> >     average
> >     normal_map{
> >         [1 bump_map2]
in
> a
one
way
> to do
> > it.
> > G.
> > Graphic experiments
> > Pov-ray gallery
