POV-Ray : Newsgroups : povray.unofficial.patches : slope-dependent pattern Server Time
17 May 2026 11:00:31 EDT (-0400)
  slope-dependent pattern (Message 1 to 10 of 21)
Subject: slope-dependent pattern
Date: 4 Jan 2001 20:39:08
Message: <3a5525bc@news.povray.org>
Got a question for you all:
Does anybody use the advanced features of MegaPov's slope-dependent pattern?
Anything that can be done with the advanced features can be replicated using
a combination of the simple slope pattern, gradient, and color_maps, using
pigment_pattern to combine everything.  Personally, I think the advanced
features are quite confusing and difficult to use.
Therefore, I'm thinking about removing them from future versions of MegaPov
(and probably POV 3.5, also) and keeping only the simple form of slope (
"slope <vector>" ), but I didn't want to do that if enough people thought
they were very useful.
-Nathan
Subject: Re: slope-dependent pattern
Date: 4 Jan 2001 22:14:02
Message: <3a553bfa@news.povray.org>
pattern?
To be quite frank with you, I haven't really gotten into them because they
are very confusing to me, and I've not had good results with them in my
work. I would really like it if I could use "slope <vector> <vector>", and
have it work as advertised, but I have not had much success with this.
MegaPov
Go right ahead... but like I said, the second form would be nice if it
worked for me. I had some strange problems with it I'm not sure I can
replicate, but they were there nonetheless.
Date: 5 Jan 2001 02:30:03
Message: <3a5577fb@news.povray.org>
Hi Nathan
I've tried using the more advanced features and have had mixed success. If
the ideas behind them could be developed they could be very useful. I must
admit I've been deterred from using them by their difficulty. I won't miss
them if they go.
Mick
Date: 5 Jan 2001 03:59:57
Message: <3A558DAA.81609503@inapg.inra.fr>
Same thing here. I also have trouble understanding the advanced features and
wouldn't miss them.
One thing that could be useful though, is to make the slope-dependent pattern
work with turbulence.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 5 Jan 2001 04:01:31
Message: <3A558D6B.61C493BF@gmx.de>
No, please keep them!
As the megapov docu says (and it's quite good to understand in that
section) there are three different types, the first two quite easy to
understand, i use both quite often.  The 'snowman' picture i posted some
time ago to p.b.i. uses 'slope z, z' for the terrain and 'slope z+y' for
the tree.
The third type is a bit more difficult, i also used it in the past, but
it's not so intuitive to use.  But it also seems to be more difficult to
be replicated with more complicated pigments as you suggested.
I already thought about writing a slope pattern tutorial in the past.  If
you decide to keep it, i could give it a try, otherwise there is not much
need :-)
Something different: i often like to have a slope pattern not for objects
but for patterns themselves or pigments, like:
  slope y {
    [pattern]
  color_map { ... }
This would be quite useful for isosurface functions for example.  I have
no idea right now if that's easy to implement, just an idea.
Date: 5 Jan 2001 04:32:28
Message: <3a5594ac$1@news.povray.org>
"Nathan Kopp" <Nat### [at] Koppcom> wrote in message
news:3a5525bc@news.povray.org...
Well, I've never used type 3, but I will cry if you remove type 2.
Date: 5 Jan 2001 09:57:08
Message: <3a55e0c4@news.povray.org>
I have been playing with the slope dependent texturing quite a bit lately -
I have found that it is really useful (at least for my stuff anyway...).
Put my vote for keeping types 1 and 2.  I haven't gotten the hang of 3
(yet).
--  the autowitch
Date: 5 Jan 2001 17:18:16
Message: <chrishuff-4CD772.17194905012001@news.povray.org>
In article <3A558D6B.61C493BF@gmx.de>, Christoph Hormann
...snip...
Are you thinking of something for the gradient of a pattern? A pattern
that would return higher values in areas that change rapidly, but
approach 0 in "flat" areas? The displace warp can do something similar,
the code could probably be modified to do this pattern(maybe a more
general pattern that calculates the "amount of warping" for any warp).
Actually, you could probably do it with an isosurface function...I don't
know how useful it would be in isosurfaces, though.
Christopher James Huff
Date: 5 Jan 2001 18:10:17
Message: <3A565458.62638751@gmx.de>
That's exactly what i meant.
I think that would suffice, since a warp does not only specify the amount
but also the direction, this could be even more universal.
Not sure whow you mean that, the purpose i was thinking of was for example
controlling the fine structure of an isosurface landscape depending on the
slope of it's large scale shape.
Date: 5 Jan 2001 19:25:42
Message: <chrishuff-4D1D42.19271605012001@news.povray.org>
In article <3A565458.62638751@gmx.de>, Christoph Hormann
Well, the warping vector can't be used directly, since patterns are
float values only...I was thinking of using the length of the warp
vector.
Ah, I see...well, declare the large scale function, and use something
like:
#declare P = 0.01;// sampling distance
#declare Fn = function {...}
#declare MaxSlopeFn =
function {
    max(max(
        (abs(Fn(x+P, y, z)-Fn(x-P, y, z))),
         abs(Fn(x, y+P, z)-Fn(x, y-P, z)))),
         abs(Fn(x, y, z+P)-Fn(x, y, z-P)))
    )/(2*P)
