POV-Ray : Newsgroups : povray.unofficial.patches : Getting Function Evaluation Server Time
17 May 2026 10:59:53 EDT (-0400)
  Getting Function Evaluation (Message 1 to 10 of 10)
Subject: Getting Function Evaluation
Date: 16 Dec 2000 14:16:28
Message: <3a3bbf8c@news.povray.org>
Is there any way to get the value of a function directly?  I know about
eval_pigment/pattern, which don't work.  What I want is this:
#local var = function(x,y,z);
Ie, given a function, and coordinants, return the value of that function.  I
didn't see anything in the Megapov code to do this, and I'd really like to.
Anyway, help?
Geoff
Subject: Re: Getting Function Evaluation
Date: 16 Dec 2000 16:06:47
Message: <chrishuff-D37EC7.16074816122000@news.povray.org>
In article <3a3bbf8c@news.povray.org>, Geoff Wedig
This is a feature which I have wanted for a long time...I have done a
little work on implementing it, but haven't really tried. The syntax
would be:
#declare FuncName = function {...}
#declare FuncVal = FuncName(XVal, YVal, ZVal);
> I know about eval_pigment/pattern, which don't work.
Uh, they don't? The eval_pattern() function should be perfect for this...
Christopher James Huff
Date: 18 Dec 2000 08:06:00
Message: <3a3e0bb8@news.povray.org>
> would be:
That's what I tried at first.  It makes sense, at least to me.  Eventually I
created a function and a macro, both with the same equation.  Not ideal, but
workable in my case.
No, it gave me an error.  I don't have the code here, so I can't tell what
error it was, but once I saw that, I began to wonder what eval_pattern() was
for in the first place, since it wasn't for that.
Anyway, problem (mostly) solved (see above), so it's no big deal.
Geoff
Date: 18 Dec 2000 12:31:27
Message: <chrishuff-AC1E80.12322918122000@news.povray.org>
In article <3a3e0bb8@news.povray.org>, Geoff Wedig
> what error it was, but once I saw that, I began to wonder what
> eval_pattern() was for in the first place, since it wasn't for that.
The eval_pattern() function returns the float value of a pattern at a
specific point...for a function pattern, this should be the result of
evaluating the function at that point, at least as long as the result is
in the 0-1 range and you don't have any special waveforms,
transformations, or warps applied. If you post the problem code I will
try to figure out what's wrong...
Something like this macro *should* work for most cases:
#macro Eval_Func(Func, X, Y, Z)
    eval_pattern(function {Func}, < X, Y, Z>)
Of course, that could also be written:
#macro Eval_Func(Func, Pt)
    eval_pattern(function {Func}, Pt)
Where Pt is a 3D vector.
The problem might be in the implementation of the isosurface
functions...I don't understand the code very well, but it uses a lot of
global variables, and may only work at render time...I've had problems
with it before, trying to get a function pigment to work(specifying 3
functions, for red, green, and blue).
Date: 18 Dec 2000 12:37:35
Message: <3a3e4b5e@news.povray.org>
> #end
> #end
Hmm, this is a deformation formula, so it ranges quite far (much further
than [0..1].  I'll check to see what error it gave when I get the chance.
Geoff
Date: 18 Dec 2000 12:51:26
Message: <chrishuff-80493E.12523118122000@news.povray.org>
In article <3a3e4b5e@news.povray.org>, Geoff Wedig
Ah, than this bit of code:
  value = ((value > 1.0) ? fmod(value, 1.0) : value);
will cause you some problems...it shouldn't make an error though, it
will just make it repeat the [0, 1] range.
I'm thinking of modifying the pattern feature to allow values outside of
[0, 1] to let these "special cases" work properly, it shouldn't be a big
problem for older scenes. Also, I did write up a bit of code for
allowing functions to be evaluated directly, but I never tested it. I
posted it here or in povray.programming...maybe I will get back to work
on it.
Date: 18 Dec 2000 13:53:10
Message: <3a3e5d16@news.povray.org>
> on it.
That would be the perfect solution, but creation a function and macro pair
isn't *too* awful, I've found.  This code was originally intended to
automatically calculate the bounding box of an isosurface based upon a
distorted coordinant space.  In fact, I need both forms of transformation
(to/from the new coordinants), so I couldn't have used the same function as
it eventually turned out, and ended up having to write the macros.
Geoff
Date: 19 Dec 2000 10:19:11
Message: <3a3f7c6f@news.povray.org>
> #end
> #end
What you wrote works, but if you have:
#declare test_function = function { Func }
eval_pattern(test_function, Pt)
I get the following:  "error: numeric expression expected but func_id found
instead."
So it sortof works.
Geoff
Date: 19 Dec 2000 12:16:04
Message: <chrishuff-B74F01.12171019122000@news.povray.org>
In article <3a3f7c6f@news.povray.org>, Geoff Wedig
That won't work because you are just passing the function identifier.
The eval_pattern() function takes a *pattern*. Use this instead:
eval_pattern(function {test_function(x, y, z)}, Pt)
The "function {}" is necessary, because that is what tells POV it is a
function pattern.
Oh, and a partial workaround for the range problem:
#macro Eval_Func(Func, MaxRange, X, Y, Z)
    eval_pattern(function {Func(x, y, z)/MaxRange}, < X, Y, Z>)*MaxRange
A slightly more complex macro could be written to handle any range, you
just need to tell it what range your function will be using.
Date: 19 Dec 2000 13:22:02
Message: <3a3fa74a@news.povray.org>
> function pattern.
> #end
Aha!  Thanks, Chris.  You've managed to solve two major problems for me in
as many days.
Kudos.
Geoff
