POV-Ray : Newsgroups : povray.unofficial.patches : media fire Server Time
19 Nov 2025 03:53:36 EST (-0500)
  media fire (Message 1 to 8 of 8)
Subject: media fire
Date: 14 Dec 2000 17:17:34
Message: <3a394566.8957677@news.povray.org>
I made a candle lit with an emission media.
When the background is black the flames look right, but as soon as I
add the candle to my scene the fire looks too clear, even if I
increase the amount of emission. What should I do?
Should I add absorption or scattering media to the fire ?
Subject: Re: media fire
Date: 15 Dec 2000 04:48:31
Message: <3A39E8EE.13C9617A@enst.fr>
	The easiest solution (at least if you're using unix) is to download
mPov and use emission mehtod 2. The not-so-easy solution is to add an
absorbing media, see the mPov page for an example of this method (and an
explanation of why emission method 2 is better).
	The mPov page:
http://www.enst.fr/~jberger/mpov/mpov.html
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 16 Dec 2000 16:26:49
Message: <chrishuff-AEBE5F.16275116122000@news.povray.org>
Another reason your method is better: if you have a patterned and
colored density instead of a grayscale one, you will need to specify
multiple media statements with different density colors instead of
putting both emitting and absorbing in one. This is even worse than the
case you showed, with a grayscale density. Of course, using separate
media statements *is* more powerful, just harder to do what is usually
wanted...
Christopher James Huff
Date: 16 Dec 2000 16:47:01
Message: <3a3be2d5@news.povray.org>
"Chris Huff" wrote:
> if you have a patterned and colored density instead of a
> grayscale one, you will need to specify multiple media
Why is this so bad? It takes up a bit more text, but using the method I've
described in povray.advanced-users it's very easy to control.
I haven't tried emission method 2. Can it do thick black media and other
dark colors?
I assume not, since it's emission after all? Anyway, the method I've
described can be used easily to make both light and dark colors. There's the
usual rgb vector *plus* a value that controls opacity.
> This is even worse than the case you showed, with a
> grayscale density. Of course, using separate media
> is usually wanted...
A bit more inconvenient, but not really harder... :)
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated October 9)
/ Also visit http://www.povrayusers.org
Date: 17 Dec 2000 17:50:55
Message: <chrishuff-C73B82.17515917122000@news.povray.org>
In article <3a3be2d5@news.povray.org>, "Rune" <run### [at] inamecom>
> I've described in povray.advanced-users it's very easy to control.
Pretty much the only advantage is that it is shorter...but it seems like
something that would fit in well as a built-in feature. However, I would
probably have done it as an optional feature of emission media instead
of a completely new type...
Date: 18 Dec 2000 05:15:19
Message: <3A3DE3B6.97CB9F8@enst.fr>
e
d
	Well, it is an optional feature of emission media. I added two optional
keywords: emission_method and emission extinction that have meaning only
in the case of emission media. Specifying emission_method 1 is the same
as standard pov. I would have preferred a syntax similar to scattering
(emission { type, color, extinction }) but I haven't taken the time to
find out how to do this while staying compatible with the current
syntax.
To Rune:
	Of course there are ways to do something similar in straight pov and
you'll get more flexibility that way. But it is impossible to get
exactly the same effect and you need a lot more code to get results
especially if you've got a complex media (remember TonyB's mediagames
last spring?)
Date: 18 Dec 2000 09:11:44
Message: <chrishuff-8BCA5B.09124818122000@news.povray.org>
> keywords: emission method and emission extinction that have meaning only
Oh, ok...I thought it was more like "emission2".
> I would have preferred a syntax similar to scattering (emission {
> type, color, extinction }) but I haven't taken the time to find out
> how to do this while staying compatible with the current syntax.
Something like this should work:
Get_Token();
if(Token.TokenId == LEFT_CURLY_TOKEN)
    Unget_Token();
    Parse_Begin();
    ...parse your syntax here
    Parse_End();
else
    Unget_Token();
    ...parse standard syntax...
Date: 18 Dec 2000 11:29:55
Message: <3A3E3B78.F842AD9@enst.fr>
	Thanks, I'll try that
