POV-Ray : Newsgroups : povray.unofficial.patches : POV-Man sky_sphere problem Server Time
27 Jul 2026 12:21:13 EDT (-0400)
  POV-Man sky_sphere problem (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: POV-Man sky_sphere problem
Date: 5 Dec 2000 05:58:51
Message: <3a2cca6b@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: I would think so...but you still don't have intersection point,
  AFAIK the sky_sphere works like if it was a sphere of radius 1 with its
center in the source of the ray.
  A "fake" intersection point could be created from this information.
  Of course if this information is used to create a normal vector and thus
shading, the result will not be the expected.
  But why limit it anyways?
Date: 5 Dec 2000 07:41:58
Message: <chrishuff-31355A.07424305122000@news.povray.org>
In article <3a2cca6b@news.povray.org>, Warp <war### [at] tagpovrayorg>
Actually, the pigment is calculated as if it was on a radius 1 sphere,
but sky_sphere behaves mostly like a sphere with infinite radius. Since
it isn't an object, there are some other odd things about it, like it
can't have a texture, only a pigment, doesn't have an interior, doesn't
have a surface, etc...it is just an extended "background" feature.
That's what I said...
Why go through a bunch of trouble to get it to partially work, and
probably slow it down noticeably, when there is already a way to do what
you want and get correct results? Just put a big hollow sphere, a real
sphere, around the scene.
Christopher James Huff
Date: 5 Dec 2000 10:03:32
Message: <3a2d03c3@news.povray.org>
: Just put a big hollow sphere, a real
: sphere, around the scene.
  Why hollow and not inverted?
Date: 5 Dec 2000 10:16:08
Message: <3A2D0780.3CFD64F3@pacbell.net>
He said it just to bother you, Warp :)
Date: 5 Dec 2000 10:21:41
Message: <3a2d0804@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: He said it just to bother you, Warp :)
  Warp, the non-hollow man!
Date: 5 Dec 2000 10:38:16
Message: <3A2D0C66.C0BB0DDB@aetec.ee>
Paul Wise wrote:
> Vahur Krouverk wrote:
> > Sky sphere is not usual object and its shading
> > calculation lacks number of parameters (most notably normal of surface),
> > which are needed for anisotropic shader.
> Could the normal of the skysphere be considered to be -1 times the ray direction
One possibility of course is to pass along as much information as
possible in each case: in case of sky sphere find normal and pass it
along (btw, such approach, proposed above, will work only in special
case, generally normals are transformed differently from points or
vectors), etc. But will it be sound solution? In such case shader writer
should know beforehand, which variables are available and which are not
in each particular case. Of course available variables for each type of
non-object could be specified in documentation, but this will be too
implementation-dependent and its use will become cumbersome and awkward.
Additionally, normal is used for lighting calculation, but sky sphere
(and other non-objects) have nothing to do with lighting, they have only
pigment.
Much better solution would be to create other shader type (lets call it
pigment shader).
This shader could be used with such non-objects, it will have clearly
defined subset of built-in variables (e.g. shading point (or better yet,
evaluation point) P, output color Ci, output opacity Oi etc.) and
built-in functions, which are guaranteed to work with this limited set
(e.g. shading and lighting functions have no meaningful implementation
and should be disabled, math and geometric functions could be used).
But such approach will require quite big rewriting and I'm not sure,
whether I want to do this right now (although I'm thinking about
implementing displacement shaders sometimes in future and such work
could become handy in this case, for displacement shaders have limited
set of functionality as well).
Easiest solution for now would is to issue warning, when shader is used
with non-object and shader writer should ensure, that shader will work
correctly. Of course this implies, that it should be documented, which
functions and built-in variables are available and could be used without
problems (from built-in variables only shading (or evaluation) point,
resulting color and opacity are available, possible functions are math
and geometry, etc.).
Date: 5 Dec 2000 17:15:26
Message: <chrishuff-D9971B.17161105122000@news.povray.org>
In article <3a2d03c3@news.povray.org>, Warp <war### [at] tagpovrayorg>
So you can put media in it. :-)
Date: 6 Dec 2000 01:29:54
Message: <3a2ddce2$1@news.povray.org>
Vahur Krouverk wrote in message <3A2C8EFE.8619FB3F@aetec.ee>...
>P.S. Mark, out of curiosity, what was the reason to try anisotropic
>shader with sky_sphere? Was it attempt to break things or attempt to
>perform something nice? Sky sphere is not usual object and its shading
Originally, I was applying a "clouds" shader to the sky_sphere, but after
POV-Man crashed when using it, I tried a few other shaders to see if the
problem was with the specific shader, or with POV-Man, and the anisotropic
shader just happened to be the last one I tested.
Mark
"The derivative of sin(2x) is cos(2x)"  - Matt Giwer
"I never said that" - Matt Giwer
Date: 6 Dec 2000 02:08:40
Message: <3A2DE67A.12BC1C37@aetec.ee>
Do you mean clouds shader from my homepage? I'm not sure, whether it
will work with sky_sphere even with the fixed version: in order to have
something, that resembles cloud, several spheres (or other objects)
should be used; with one surface it doesn't look like cloud at all.
Date: 7 Dec 2000 02:05:02
Message: <3a2f369e$1@news.povray.org>
Vahur Krouverk wrote in message <3A2DE67A.12BC1C37@aetec.ee>...
No, it's one I found on the Internet.  It uses only the evaluation point as
input.
Mark
