POV-Ray : Newsgroups : povray.unofficial.patches : Spline bug: floats converted to vectors Server Time
22 Mar 2026 20:59:54 EDT (-0400)
  Spline bug: floats converted to vectors (Message 1 to 10 of 10)
Subject: Spline bug: floats converted to vectors
Date: 2 Dec 2000 18:47:16
Message: <3a298a04@news.povray.org>
This is about the spline type by Wolfgang Ortmann. (Splines with variables.)
The documentation says that it can handle both vectors and floats, but
whenever I use floats they are converted to vectors, as the code below
shows.
#version unofficial MegaPov 0.6;
#declare MySpline = spline {cubic_spline
   0.0, 0.2,
   0.5, 0.3,
   1.0, 0.1,
#debug str(MySpline(0),7,4)
Is there any way around this problem?
Using MySpline(0).x is not an option, because I use the same macro to handle
floats and vectors, and I don't want my vectors to be converted to floats.
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated October 9)
/ Also visit http://www.povrayusers.org
Subject: Re: Spline bug: floats converted to vectors
Date: 3 Dec 2000 03:38:51
Message: <3a2a069b@news.povray.org>
Rune <run### [at] inamecom> wrote:
: whenever I use floats they are converted to vectors
[snip]
: I don't want my vectors to be converted to floats.
  There's an inconsistency here.
Date: 3 Dec 2000 07:13:40
Message: <3a2a38f4@news.povray.org>
> [snip]
No there's not. First I was talking about the *problem*, which is that
floats are converted to vectors.
Then I asked for a solution.
Oh, but can't I just add .x after the spline call to avoid vectors?
No, because that would convert my vectors to floats, and I don't want that
either.
If you reread my original post I believe that you will find it clear that
that is what I really meant. :)
Rune
Date: 3 Dec 2000 08:53:16
Message: <3a2a504c@news.povray.org>
Uh, it was a bit too complicated for my simple mind... :)
Date: 3 Dec 2000 09:17:39
Message: <3A2A5676.4CED75F9@peak.edu.ee>
Well, if I understand the problem correctly, this should avoid converting the
values to float when they shouldn't be (untested!):
#if(MySpline(n).x = MySpline(n).y & MySpline(n).x = MySpline(n).z)
#declare Val = 0 + MySpline(n).x; //float
#else
#declare Val = <0,0,0> + MySpline(n); //vector
Margus Ramst
Date: 3 Dec 2000 11:14:34
Message: <3a2a716a@news.povray.org>
> converting the values to float when they shouldn't be (untested!):
<snipped>
Yes, that works in many cases, but vectors such as <0,0,0> and <3,3,3> will
still be converted to floats 0 and 3 respectively.
Anyway, I think I can get around it, I just hope it will be fixed for the
next version.
Rune
Date: 3 Dec 2000 13:24:21
Message: <3A2A9049.EEF3A868@peak.edu.ee>
Does it matter? They get promoted back to <0,0,0> and <3,3,3> respectively, if a
function requires a vector value.
If you want to use them with e.g. dot operators, you can force vector promotion
with (Float + <0,0,0>)
Margus Ramst
Date: 3 Dec 2000 15:05:17
Message: <3a2aa77d@news.povray.org>
> > <3,3,3> will still be converted to floats 0 and 3 respectively.
> respectively, if a function requires a vector value.
Ah, yes. You're right!
Rune
Date: 4 Dec 2000 15:18:50
Message: <3A2C25E2.E423AAE9@ibm.net>
While we are talking about spline bugs, here is another one.  One cannot do the
following:
#declare thespline = Spline {
    cubic_spline
    floats, points
do something with the spline
#undef thespline // this produces an error
This problem can become an issue when you are using huge numbers of splines in
the scene and the memory for them never gets freed (needless waste of space)
Andrew C
Date: 4 Dec 2000 23:49:42
Message: <3a2c73e6$1@news.povray.org>
Andrew Clinton wrote in message <3A2C25E2.E423AAE9@ibm.net>...
the
>following:
>    cubic_spline
>    floats, points
Since I've been working on improving the spline stuff, I'll take a look into
that.
Mark
"The derivative of sin(2x) is cos(2x)"  - Matt Giwer
"I never said that" - Matt Giwer
