POV-Ray : Newsgroups : povray.unofficial.patches : Malfunctioning Post-process - Stars Server Time
27 Jul 2026 12:20:17 EDT (-0400)
  Malfunctioning Post-process - Stars (Message 11 to 13 of 13)
Subject: Re: Malfunctioning Post-process - Stars
Date: 15 Nov 2000 20:20:04
Message: <3A13363F.C54CDAFB@ij.net>
GrimDude wrote:
> I hate to say it, but that is only going to make things worse. :)
	Correct, it does make things worse. The astronomical scale of the solar
system is too great to render and look realistic.
	If I remember correctly a standard camera lens, about 50mm for 35mm
film which should be roughly the 4/3 aspect, has about a 30 degree
viewing angle. From Earth both the sun and the moon have a 1/2 degree
angular diameter. for a 640 wide image that less than 11 pixels.
http://giwersworld.org/artiii/elevat23.jpg is a to-scale rendering and
that blob is the moon. The blob looks a bit better as rendered rather
than at the jpeg quality used.
	On the recent images I have posted I have cut the earth-moon and
earth-sun distances by about ten with other scales equal. On that scale
a lunar eclipse lasts two days but the moon is on the recognizable side.
	I'll be posting the result of my way of making a sun in binaries in a
few minutes.
You know you are a bigot if you wonder what
Jessie Jackson does for a living.
	-- The Iron Webmaster, 162
Date: 16 Nov 2000 15:56:08
Message: <3a1449e8@news.povray.org>
1.9 times 10^28 kg.  according to this web page:
http://www.egglescliffe.org.uk/physics/gravitation/planets/jupiter.html
"GrimDude" <gri### [at] netzerocom> wrote in message
news:3a11bf8e@news.povray.org...
> Sorry, I have no data on Jupiter's mass.
Date: 19 Nov 2000 18:01:58
Message: <slrn91gl6s.4b3.hjp-usenet@teal.h.hjp.at>
On Tue, 14 Nov 2000 16:42:53 -0500, Greg M. Johnson wrote:
>Do you have the masses? The first almanac I looked at didn't have it.
>Particularly interested in sun, earth, Jup.
Look at
http://seds.lpl.arizona.edu/nineplanets/nineplanets/nineplanets.html for
lots of infos about the solar system.
	hp
| |   | hjp### [at] wsracat      |    -- Lutz Donnerhacke in dasr.
__/   | http://www.hjp.at/ |
