POV-Ray : Newsgroups : povray.unofficial.patches : UV-mapping of bicubic patches not working in 0.6a Server Time
16 Jun 2026 01:46:17 EDT (-0400)
  UV-mapping of bicubic patches not working in 0.6a (Message 1 to 4 of 4)
Subject: UV-mapping of bicubic patches not working in 0.6a
Date: 11 Nov 2000 07:35:42
Message: <3a0d3d1d@news.povray.org>
This works fine with megapov 0.5a (the bicubic patch has a checker pigment
applied to it) but in megapov 0.6a the bicubic patch is just white:
camera { location -z*8 look_at 0 angle 35 }
light_source { -z*10, 1 }
bicubic_patch
{ type 1 flatness 0 u_steps 4 v_steps 4,
  0, x, x*2, x*3,
  y, x+y, x*2+y, x*3+y,
  y*2, x+y*2, x*2+y*2, x*3+y*2,
  y*3, x+y*3, x*2+y*3, x*3+y*3
  uv_mapping
  pigment { checker rgb x, rgb 1 scale .125 }
  translate <-1.5,-1.5,0>
Subject: Re: UV-mapping of bicubic patches not working in 0.6a
Date: 11 Nov 2000 07:50:24
Message: <chrishuff-8E97B1.07503211112000@news.povray.org>
In article <3a0d3d1d@news.povray.org>, Warp <war### [at] tagpovrayorg>
>   pigment applied to it) but in megapov 0.6a the bicubic patch is
>   just white:
UV-mapping of bicubic patches changed between the two versions. I think
it is explained under "8.6.4. Other changes related to UV mapping" in
the MegaPOV manual.
Christopher James Huff
Date: 11 Nov 2000 21:37:26
Message: <3A0DF3E3.FDFFC6B2@aol.com>
> >   just white:
> the MegaPOV manual.
A change that was made in version 0.6a is that the uv_vectors need to be
specified AFTER the patch vectors and before the uv_mapping keyword.
Warp's example renders properly if specified as:
bicubic_patch
  type 1
  flatness 0
  u_steps 4
  v_steps 4,
  0, x, x*2, x*3,
  uv_vectors <0, 0>, <1, 0>, <1, 1>, <0, 1>
  uv_mapping
But there is still a bug present, since it should render properly without
ANY uv_vectors specified.  I'm not positive, but I think that when someone
moved the code:
MSquareQuad(Object->ST, Object->Mapping); /* mapping matrix */
in parse.c, it caused that section of the code to not execute unless
uv_vectors are specified with the patch.  The result is that mapping
transform is not performed on the uv_vectors created with the patch by
default, and thus the texture is not mapped correctly.  Again, not sure but
I think that's the problem.
-Mike
Date: 13 Nov 2000 09:30:19
Message: <3a0ffafb@news.povray.org>
Yes, it would make sense that <0,0>,<1,0>,<1,1>,<0,1> would be the default
if none is specified.
