POV-Ray : Newsgroups : povray.unofficial.patches : Glows can't be the last thing in a scene??? Server Time
27 Jul 2026 12:22:20 EDT (-0400)
  Glows can't be the last thing in a scene??? (Message 12 to 21 of 21)
Subject: Re: Glows can't be the last thing in a scene???
Date: 10 Nov 2000 18:51:55
Message: <chrishuff-8BBD28.18520210112000@news.povray.org>
In article <3a0c86f3@news.povray.org>, "GrimDude"
<gri### [at] netzerocom> wrote:
> That's interesting! I've been declaring them and they work fine! :)
Umm, you must be dreaming or misunderstanding, because it isn't
possible. MegaPOV 0.6a will let you put a glow after a #declare, but it
won't create a glow variable and you won't be able to make a copy of the
glow.
Christopher James Huff
Date: 10 Nov 2000 23:25:01
Message: <3a0cca1d@news.povray.org>
You know, I'd like believe you. :)
I'm right in the middle of an overnight render, or I'd double check.
What I did was:
   #declare EuroSun = object { glow { location.... } sphere {0,0}}
then:
   object { EuroSun }
finally I redundantly added:
   light_source {(same location)....looks_like {EuroSun}}
and I swear it rendered a glow.
Now you're making me nervous... :)
Grim
Date: 11 Nov 2000 06:09:55
Message: <chrishuff-24733B.06100211112000@news.povray.org>
In article <3a0cca1d@news.povray.org>, "GrimDude"
> What I did was:
> then:
>    object { EuroSun }
Of course it did, this line:
Puts a glow in your scene and declares a sphere variable named EuroSun.
This line:
object { EuroSun }
Then uses that variable to make a sphere. Since there is already a glow
in that position, you don't notice that it doesn't put a glow there. If
you tried making multiple copies of EuroSun or attempted to translate
it, it wouldn't have worked.
I've managed to get glows to attach to objects correctly, but haven't
worked out glow declaration yet. You still can't declare glows(though I
might be able to add that before the next release), and objects that
have glows attached don't act properly when copied.
Date: 11 Nov 2000 12:30:54
Message: <3a0d824e@news.povray.org>
Well then, you were correct and I misunderstood what you meant by 'declare.'
Isn't that what the first line does?
Grim
Date: 11 Nov 2000 14:04:22
Message: <chrishuff-7F97EA.14042811112000@news.povray.org>
In article <3a0d824e@news.povray.org>, "GrimDude"
> 'declare.'
No, it declares a sphere and puts a glow in the scene. The glow would be
there even if you hadn't typed "object { EuroSun }". This is still a
problem with my patch(it doesn't work properly if you declare objects
with glows attached), and it isn't going to be easy to fix.
Date: 11 Nov 2000 23:11:52
Message: <3a0e1888@news.povray.org>
Yes, but it appears to function normally. Right? I mean, you're trying to
tell me this is not how it is done? :(
Grim
Date: 12 Nov 2000 09:34:19
Message: <chrishuff-307C2B.09342912112000@news.povray.org>
In article <3a0e1888@news.povray.org>, "GrimDude"
It only appears to work correctly in your scene because you don't try to
do anything but put it in the scene. Try typing:
object {EuroSun translate x*2}
object {EuroSun translate y*2}
object {EuroSun translate z*2}
You will get a zero-radius sphere at < 2, 0, 0>, < 0, 2, 0>, and < 0, 0,
2>, and one glow which is completely unaffected by all the EuroSun
objects.
It lets you put it in the #declare statement, but *it does not declare
the glow*!
Date: 12 Nov 2000 11:49:13
Message: <3a0eca09@news.povray.org>
Ah! I don't mean to waste your time answering superfluous questions, Chris.
I had read that transforms upon glows would not work. I had no idea that
declares didn't, either. Thanks for clearing it up.
Grim
Date: 13 Nov 2000 01:38:56
Message: <3A0F8CD1.B19B2F1C@hotmail.com>
Chris - I am pretty sure that I implemented particle declarations in the
ParticlePatch
- you could look at it & do something similar.
Bye
Pabs
Date: 13 Nov 2000 16:08:02
Message: <chrishuff-9FA6B1.16081213112000@news.povray.org>
In article <3A0F8CD1.B19B2F1C@hotmail.com>, Pabs <pab### [at] hotmailcom>
> ParticlePatch - you could look at it & do something similar.
I've been thinking of following the spline patch through the source and
duplicating everything that looks like it has to do with variables, but
I also want to understand what the code is doing. The next release of my
patch will have declarable glows, don't worry. :-)
