POV-Ray : Newsgroups : povray.unofficial.patches : Glows are not translated with the light source Server Time
29 Sep 2024 09:19:09 EDT (-0400)
  Glows are not translated with the light source (Message 1 to 10 of 20)
Subject: Glows are not translated with the light source
Date: 6 Nov 2000 15:02:37
Message: <3a070e5c@news.povray.org>
A bug:
light_source
{ <0,0,0>, 1
  glow { whatever }
  translate <1,2,3>
  The glow is not translated with the light.
Subject: Re: Glows are not translated with the light source
Date: 6 Nov 2000 16:03:29
Message: <chrishuff-69716C.16032906112000@news.povray.org>
In article <3a070e5c@news.povray.org>, Warp <war### [at] tagpovrayorg>
As mentioned in the documentation, ;-), glows will not be transformed
correctly when you transform the light they are attached to. This is
just another unimplemented feature...you will have to transform them
yourself, or use vtransform to set the light source position.
Christopher James Huff
Date: 6 Nov 2000 17:01:43
Message: <3a072a47@news.povray.org>
A little annoying when you have several hundred glows to translate!
Date: 6 Nov 2000 17:09:59
Message: <chrishuff-E44E36.17100006112000@news.povray.org>
In article <3a072a47@news.povray.org>, "Mick Hazelgrove"
Indeed...why do you have that many glows? Can't you use macros and loops
instead? I certainly wouldn't want to manually position that many
glows...
Date: 7 Nov 2000 02:15:10
Message: <3a07abfe@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: I certainly wouldn't want to manually position that many
: glows...
... when it would be much easier to put them in a union and translate this
union.
Date: 7 Nov 2000 06:01:34
Message: <3A07E166.A57B679B@pacbell.net>
> : glows...
> union.
I agree.
Date: 7 Nov 2000 14:37:25
Message: <chrishuff-CFC31C.14372607112000@news.povray.org>
In article <3a07abfe@news.povray.org>, Warp <war### [at] tagpovrayorg>
> : glows...
> union.
How are they generated? I still wouldn't want to manually create that
many glows, even in a union.
Besides, why won't the workaround of creating them with a macro work?
You can put the transformation in the macro, and call it multiple times
to give them different positions, colors, etc. A pretty clumsy
workaround, but it should work.
It will probably be a while before I can get them working in unions,
though I am looking at the problem...basically what I am planning is a
dynamically allocated array of pointers to glows. The glows will still
be located in the main list, but they will have additional pointers in
the union. Since I have never used an array of this type, I will
probably wait until I see Mark Wagner's spline code. And I will have to
make sure that stale pointers are never used...etc, etc...
BTW, another thing I have been thinking of adding: a "multiglow" or
compound glow. Basically a glow with multiple locations, it would act
like a group of glows having everything but location identical. The main
advantage would be memory, you would only have to store another vector
to make each new glow. There might also be a slight speed gain, since it
would eliminate walking along a linked list...but probably not
noticeable. What do you think?
A glow that follows a spline instead of originating from a point could
also be useful...but will take quite a bit of coding.
Date: 7 Nov 2000 17:29:41
Message: <3a088255@news.povray.org>
Both would be wonderful additions. Don't blather about it, get on with it
lad!( as my Dad used to say)
Date: 8 Nov 2000 04:46:16
Message: <3a0920e8@news.povray.org>
: Besides, why won't the workaround of creating them with a macro work?
: You can put the transformation in the macro, and call it multiple times
: to give them different positions, colors, etc. A pretty clumsy
: workaround, but it should work.
  What I wonder why it can't work like a light_source. You can put a
light_source inside a CSG and all transformations applied to the CSG will
transform the light_source as well. Why the glow can't work in the same
way?
  And answering your question, it may be quite complicated sometimes.
  Just consider something like this:
// Candle:
union
{ union
  { union
    { light_source // Candle light
      { 0, 1 glow { ... }
        translate y*1
      cone { ... } // Top of candle
      cylinder { ... } // Body of candle
      translate y*5
    union
    { // some candlestick stuff here
      translate y*-2
    scale 2 translate y*-5
  union
  { // Some lantern stuff here
  scale 5 rotate z*30 translate <10,20,30>
  It breaks entirely the ideology and structure of a CSG if some sub-part of
it is not transformed by outer transformations.
  Besides this, it's not easy at all to calculate the right location value
inside the glow-block.
  Also if you change any of the transformations of the CSG, everything else
changes accordingly, except the glow, which you have to remember to
recalculate again.
  Suppose that I want to declare that object as an identifier which I could
put in an #include file. The only way of making it work would be making it
a macro. Again, it would break the ideology of delcared objects. I could
not say anymore:
union
{ object { Candle scale .25 translate y*5 }
  object { Table }
  translate <1,2,3>
: BTW, another thing I have been thinking of adding: a "multiglow" or
: compound glow. Basically a glow with multiple locations, it would act
: like a group of glows having everything but location identical. The main
: advantage would be memory, you would only have to store another vector
: to make each new glow. There might also be a slight speed gain, since it
: would eliminate walking along a linked list...but probably not
: noticeable. What do you think?
  Yes, it sounds useful.
  Btw, I think there could be better (and faster and less memory-consuming)
ways of storing the glows than a linked list.
  Just imagine if the triangles of a mesh were in a linked list... ;)
Date: 8 Nov 2000 07:12:48
Message: <chrishuff-288BCF.07125108112000@news.povray.org>
In article <3a0920e8@news.povray.org>, Warp <war### [at] tagpovrayorg>
> way?
Because it isn't implemented yet!
Light sources are different, they are objects. Glows aren't, they are a
much simpler structure, and changing them to be objects isn't easy and
would consume more memory, so I am going to try a different tactic of
allowing them to be attached to objects. And have you looked at the
current state of the CSG parsing code?
> of it is not transformed by outer transformations.
> value inside the glow-block.
> else changes accordingly, except the glow, which you have to remember
> to recalculate again.
Which is why I am trying to fix that.
Originally, the glow was a light_source effect. I separated it out so it
was an atmospheric effect, like fog, that could be attached to a light
source. I then added more object-like features to it...but it is not an
object, so much of this stuff that happens semi-automatically with
objects needs to be done manually.
> memory-consuming) ways of storing the glows than a linked list.
Nearly everything in POV is a linked list...light sources, objects, in
my particle_system patch the particles are in a list, etc...it would be
nice if POV provided some standard functions for allocating, copying,
inserting and deleting parts of, and resizing arrays. For allowing the
glows to be specified in an array, I am attempting to make a dynamically
allocated and resized array of pointers to glows...my last attempt
crashed my computer hard.
