POV-Ray : Newsgroups : povray.unofficial.patches : fields in mechsim Server Time
13 Jul 2025 22:14:15 EDT (-0400)
  fields in mechsim (Message 1 to 1 of 1)
Subject: fields in mechsim
Date: 31 Dec 2003 12:50:23
Message: <3FF30C88.26569D79@dcs.gla.ac.uk>
I don't know if this is related to Florian's earlier problem with
fields, but I'm getting some unusual effects with fields in MechSim with
MegaPov 1.0.
I'm trying to apply (different) forces to various parts of a model. The
test scene below has three masses, and a field with an x-gradient (this
is shown on the vertical plane). The field alternates between a positive
and a negative force, and the masses are spaced so that two are in the
center of the negative region and one is in the positive. However, all
of the masses move in tandem. There are no other gravity or environment
forces present. Is there an easy way to achieve what I want to do?
#version unofficial megapov 1.0;
#include "mechsim.inc"
#declare field_func =
         pigment
          gradient x
          scale 2
          translate 0.5*x
          color_map
          [0.0 rgb  <0,0,1000>]
          [1.0 rgb <0,0,-1000>]
global_settings {
  max_trace_level 10
  assumed_gamma 1
  mechsim {
    gravity <0, 0, 0>
    method 2
    #if (frame_number!=1)
      step_count 300
      time_step (1/30)/300
      topology {
	load_file "test.dat"
	save_file "test.dat"
     field {function
{pigment{field_func}}}
    #else
      step_count 0
      topology {
        #declare obj_dens = 2000;
        #declare obj_stiff = 5000;
        #declare obj_damp = 200;
	  mass { <0, 0, 0.95>, <0, 0, 0>, 0.2 density obj_dens }
	   mass { <1, 0, 0.95>, <0, 0, 0>, 0.2 density obj_dens }
           mass { <-1, 0, 0.95>, <0, 0, 0>, 0.2 density obj_dens }
MechSim_Show_All_Objects(-1,false, -1, "")
  location    <0, -10, 0.5>
  direction   y
  sky         z
  up          z
  right       (4/3)*x
  look_at     <0,0,1>
  angle       30
light_source {
  <3.2, -0.3, 1.8>*100000
  color rgb <1.6, 1.5, 1.0>
sky_sphere {
    gradient z
    color_map {
      [0.00 rgb <0.8,0.9,1.0>]
      [0.10 rgb <0.6,0.7,1.0>]
      [0.25 rgb <0.2,0.3,0.8>]
plane { y, 0 pigment { field_func  }}
Thanks,
--John
