POV-Ray : Newsgroups : povray.unofficial.patches : Using trace Server Time
22 Mar 2026 14:41:24 EDT (-0400)
  Using trace (Message 1 to 5 of 5)
Subject: Using trace
Date: 20 Jul 2001 23:01:07
Message: <3B58EC6D.EFD74540@global2000.net>
When I try to use trace to place a tower from one of my include files
onto a heightfield island, I don't see the tower.  I put the tower onto
a plane representing water and It looked big enough to see over any part
of the island that might block it from view.  Am I using trace right?
There is a picture in p.b.i.
Brendan
#declare xtrans = 500;	//where the tower goes
#declare ztrans = 0;
#declare Start = <xtrans,10000,ztrans>;		//trace to find y value for
tower
#declare Inter =
trace ( Island, Start, <xtrans,-10000,ztrans>);
object { tower translate <xtrans,0,ztrans>+Inter*y }	//put tower there
cylinder { 0,<0,1000,0>,1 pigment { color rgb <0,0,1> } translate
<xtrans,0,ztrans> }	//shows where tower is
camera { location <1500,800,-917> look_at Inter/*+xtrans*x+ztrans*z*/ }
//camera { location <xtrans,10000,ztrans> look_at <xtrans,0,ztrans> }
//camera {  location <xtrans,400,ztrans> look_at
<xtrans,0,ztrans>+Inter*y translate <0,0,10> }
Subject: Re: Using trace
Date: 21 Jul 2001 04:03:44
Message: <3B593754.D1C80747@ignorancia.org>
  At first look it seems correct to me. Why not try "debug" to print out
the actual value of Inter.y? That could help you to figure where the
tower is going...
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 21 Jul 2001 06:40:37
Message: <3b595c25@news.povray.org>
> #declare Inter =
The third parameter in trace is a direction, not a point.
Try the following (not tested):
> #declare Inter =
> trace ( Island, Start, -y);
> object { tower translate Inter }
Hope that helps!
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Date: 22 Jul 2001 22:52:45
Message: <3B5B8D6C.16E794F6@global2000.net>
With my original trace, it put the tower at zero distance above the
water plane.  So, it was hidden under the heightfield.  Changing the
third argument of trace to -y worked.  I used str to convert the float
Inter.y to a string that #debug can output.  Thanks.
Brendan
> tower is going...
Date: 22 Jul 2001 22:56:23
Message: <3B5B8E46.DBAE87BD@global2000.net>
> > #declare Inter =
> > trace ( Island, Start, <xtrans,-10000,ztrans>);	<--- I thought that it would go
toward this point.
But it's a vector and they have a initial point which is Start, and a
direction, which should be -y as you suggested.
> > #declare Inter =
> > trace ( Island, Start, -y);		<--- This worked.
> Hope that helps!
Yes, it worked.  Thank you.  Time to move the tower around and add some
textures to it...
Brendan
