POV-Ray : Newsgroups : povray.unofficial.patches : Transmit -> File alpha bug im MP0.7 Server Time
18 Nov 2025 23:24:22 EST (-0500)
  Transmit -> File alpha bug im MP0.7 (Message 1 to 7 of 7)
Subject: Transmit -> File alpha bug im MP0.7
Date: 8 Jun 2001 22:40:27
Message: <3B218C97.A806BB57@internode.on.net>
The alpha channel for pixels corresponding to an object with transmit !=
0 is set to fully opaque regardless of the actual transmit value.
I've tracked this down to compute_lighted_texture() in lighting.c
but I'm having trouble following why a lot of the changes were made.
line 4711 says
ResCol[TRANSM] = (0.30*AttCol[0] + 0.59*AttCol[1] + 0.11*AttCol[2]) *
FilCol[TRANSM];
but FilCol[TRANSM] is never changed from 0.0 as far as I can see.
There's a comment at line 4617
/* note FilCol[3] stays at 1.0, [4] stays at 0.0 */
Why is that?
Thanks for your time. And thanks for MegaPOV.
Subject: Re: Transmit -> File alpha bug im MP0.7
Date: 8 Jun 2001 22:53:46
Message: <3B218FB6.DB43D627@internode.on.net>
Oops, just found the message from Mael Wed, 14 Mar 2001
Might have to wade back in and try to solve this :^0
Date: 9 Jun 2001 22:25:05
Message: <3b22da81$1@news.povray.org>
"PoD" <pod### [at] internodeonnet> wrote...
> line 4711 says
> FilCol[TRANSM];
> Why is that?
For the purposes of FilCol, anything that can be represented with the
Transmit channel can be represented using the filter channel with an
appropriate color.
Examples:
<0,0,0,0,1> can be represented as <1,1,1,1,0>
<0,0,0,0,.5> can be represened either as <.5,.5,.5,1,0>
<.5,0,0,.5,.5> can be represented as <1,.5,.5,1,0>
etc.
Actually, in future versions (far in the future) of POV, I think that we use
6-channel (actually 2*3 channel) colors: <r,g,b,rf,gf,bf>.  In lighting.cpp,
ResCol represents <r,g,b> and FilCol represents <rf,gf,bf>.  This allows
much more control of what gets transmitted and what gets diffused.  Of
course, this would cause backwards-compatibility problems...
-Nathan
Date: 10 Jun 2001 13:02:00
Message: <3b23a808$1@news.povray.org>
"Nathan Kopp" <nat### [at] koppcom> wrote ...
use
I meant to say "I think that we SHOULD use 6-channel..."
-Nathan
Date: 10 Jun 2001 14:11:06
Message: <3B23B7BF.2F9F9556@pacbell.net>
> use
Either way it's a great idea.
Date: 10 Jun 2001 21:05:20
Message: <3B24194C.9A46192C@internode.on.net>
> > line 4711 says
> > FilCol[TRANSM];
> > Why is that?
> appropriate color.
> Examples:
> etc.
OK. The problem is that the output alpha channel contains exactly what
is put into the tranmit part of FilCol at the start of
compute_lighted_texture.
To test this I made FilCol = [1.0,1.0,1.0,1.0,0.5] and then the output
alpha for any ray is 128.
PoD.
Date: 10 Jun 2001 23:40:48
Message: <3b243dc0$1@news.povray.org>
True.  There are some other problems with the alpha channel in MegaPov (and
also in POV 3.1).  These will be fixed for POV 3.5.  Basically, the line of
code that sets ResCol[TRANSM] should be moved into the preceeding
if(one_colour_found) block, and should use RfrCol[TRANSM] and Trans instead
of FilCol[TRANSM].
-Nathan
