POV-Ray : Newsgroups : povray.unofficial.patches : Odd lighting of object pattern isosurface Server Time
11 Jul 2026 21:29:16 EDT (-0400)
  Odd lighting of object pattern isosurface (Message 1 to 5 of 5)
Subject: Odd lighting of object pattern isosurface
Date: 20 May 2001 13:34:00
Message: <3B07FFCB.1C36B607@hotmail.com>
When rendering the source code below,
only half of the text object gets
illuminated from the (single) light
source used.
When the light source is placed to
the "left" of this camera, the "right"
half of the object is lit.
(And when the light source is placed
to the "right" of this camera then the
"left" side of the object is lit.)
Ambient light will light all of it.
Have I misunderstood something ?
Or is this a bug ?
Best regards,
Tor Olav
mailto:tor### [at] hotmailcom
http://hjem.sol.no/t-o-k/tokpicts.html
http://www.crosswinds.net/~tok
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7 =
#version unofficial MegaPov 0.7;
global_settings { ambient_light color Black }
#declare TextObject =
text {
  ttf "Arial.ttf"
  "POV-Ray" 0.2, 0
//#declare TextObject = sphere { <0, 0, 0>,  1 }
#declare pMax = max_extent(TextObject);
#declare pMin = min_extent(TextObject);
#declare PigmentFunction =
function {
    object {
      TextObject
      rgb 1, rgb 0
    turbulence 0.15
#declare D = 0.2;
#declare IsoText =
isosurface {
  function { PigmentFunction - 0.5 }
  contained_by { box { pMin - <D, D, D>, pMax + <D, D, D> } }
  max_gradient 40
//  accuracy 1e-6
  method 2
object {
  IsoText
  translate -(pMin + pMax)/2
  pigment { color White }
background { color Blue/2 }
light_source { <-1,  2, -3>*100 color White }
//light_source { < 1,  2, -3>*100 color White }
  location <0, 0, -4>
  look_at <0, 0, 0>
Subject: Re: Odd lighting of object pattern isosurface
Date: 20 May 2001 14:23:24
Message: <3B080BE2.81F1DD5B@gmx.de>
> source used.
> Or is this a bug ?
I did not try to render your code, but you should not use the object
pattern in isosurface function, because it contains infinite gradient.
Infinite gradient in isosurface functions usually leads to unexpected
results.
Date: 22 May 2001 17:47:31
Message: <3B0ADE4A.888D74F1@hotmail.com>
> > source used.
> > Or is this a bug ?
I see  - But that's a pity !
It would be a great possibility to "isofy"
all kind of "ordinary" POV-shapes.
> results.
I think though (IIRC), that I earlier
have successfully made iso-images with
infinite gradients objects.
Best regards,
Tor Olav
Date: 22 May 2001 18:05:34
Message: <3B0AE2FA.91F0B724@gmx.de>
You can try the proximity pattern, but that's slow of course.
I think method 1 sometimes works this way, but in general you should
expect strange results.  Even if the shape appears correct, shadows for
example can still be wrong.
Date: 23 May 2001 07:08:41
Message: <3b0b9a37@news.povray.org>
Tor Olav Kristensen <tor### [at] hotmailcom> wrote:
: I see  - But that's a pity !
: It would be a great possibility to "isofy"
: all kind of "ordinary" POV-shapes.
  It's an old idea and it would be very useful (eg. true non-uniform
transformations), but it can't work.
  Perhaps if a good proximity pattern is developed...
