POV-Ray : Newsgroups : povray.unofficial.patches : [POVMan]version 0.71.4 released Server Time
19 Mar 2026 14:27:46 EDT (-0400)
  [POVMan]version 0.71.4 released (Message 1 to 10 of 11)
Subject: [POVMan]version 0.71.4 released
Date: 4 Apr 2001 04:20:23
Message: <3ACAD946.B1F614D9@nanterre.marelli.fr>
Hi all.
Another service release :)
2 bug fixes:
- missing shader call for non-objects added (problem when using a shader
pigment in a warp).
- bug fix for crash when using a declared camera with normal.
This version is now available here:
http://tofbouf.free.fr/clothray/download_en.html
Bye.
Bouf.
Subject: Re: [POVMan]version 0.71.4 released
Date: 4 Apr 2001 12:26:23
Message: <3ACB4BD9.8F4CAC3F@reading.ac.uk>
Hi Christophe,
Many thanks to you and Vahur for this.
Mike Andrews.
Christophe Bouffartigue wrote:
> Hi all.
> 2 bug fixes:
> pigment in a warp).
[snip]
Date: 4 Apr 2001 12:52:37
Message: <3ACB5155.AA9581F7@gmx.de>
I played with the new sample scenes for isosurface shaders, found the
speed differences quite interesting.
The shader rmf was much slower than the hardcoded ridgedMF function, but
with the torus shape the shader lies just between hardcoded and directly
written function.  This means that the compiled shaders are significantly
faster than the current isosurface function interpreter.  I don't know
what optimizations are planned for Povray 3.5 in that direction - just
wanted to share this observation.
Date: 4 Apr 2001 13:30:50
Message: <3acb5a4a$1@news.povray.org>
In article <3ACB5155.AA9581F7@gmx.de> , Christoph Hormann
For complex isosurface functions a speedup factor of ten is possible,
but for extremely simple functions (like x*y) a minor slowdown will
occur.  However, all noteworthy limits in function size are eliminated
and there are hooks that could allow another factor of ten speedup (no
kidding!)...
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 4 Apr 2001 14:56:01
Message: <3ACB6E40.E27E58C1@gmx.de>
> kidding!)...
That sounds really very good, especially if it also applies for pigment
functions (of course the pigments themselves can be very slow which is
probably more difficult to optimize)
Date: 4 Apr 2001 16:40:15
Message: <chrishuff-682977.15401504042001@news.povray.org>
In article <3ACB6E40.E27E58C1@gmx.de>, Christoph Hormann
The speedup is in the actual function...the speed cost of pigment
functions is mainly from stuff that's hard-coded C, so it most likely
won't be faster. The only way to increase that speed would be to work on
the pigment code, which is completely separate from the isosurface
function code.
Christopher James Huff
Date: 4 Apr 2001 17:21:36
Message: <3ACB9060.142A7E90@gmx.de>
> function code.
I know, just thought the actual isosurface code for calculating the ray
intersection was maybe changed too which would speed up those things
equally.
I'm quite sure there are also possibilities for optimizing that, for
example by caching previously calculated values.
Date: 5 Apr 2001 03:50:12
Message: <3ACC23F7.B8BCEFD8@aetec.ee>
> occur.
Could someone disclose the secret of this "trick"? I'd like to know, how
was this acieved? Are isosurface functions precompiled in some way? Or
is the isosurface potential value calculation algorithm changed, which
allows this speedup ("minor slowdown")?
Some example of complex function?
Shaders execute functions 2-3 times faster (e.g. functions from
math_pigm.pov were 3 times faster), with more complex functions this
speedup is probably even bigger, but I'm not sure, whether speedup of 10
will be achieved.
> kidding!)...
How do these hooks work?
Vahur,
who can't wait for release of 3.5 to examine source code...
Date: 5 Apr 2001 10:43:20
Message: <3acc8488$1@news.povray.org>
In article <3ACC23F7.B8BCEFD8@aetec.ee> , Vahur Krouverk
The minor slowdown is caused by more overhead starting to evaluate a
function.  The speedup is due to a (very simple) VM architecture and
support for optimization of expressions.
>> kidding!)...
They allow you to take the VM code and generate native code prior to
rendering.  Since every VM instruction takes about 15-20 native
instructions, you can reduce the code executed to about 1/15-1/20 by
compiling.  However, since you get better pipelining effects when using
the VM, the speedup will be a bit lower than the 15-20 times maximum.
It will actually be less if you call "slow" native functions like sin or
sqrt (because then the VM overhead will be a smaller percentage of the
whole), but you get a factor of about ten for functions that use only
basic math.
> Vahur,
You? ;-)
     Thorsten
Date: 5 Apr 2001 12:01:56
Message: <3ACC9732.D22D35CA@aetec.ee>
Ahah! This (esp. optimization) may become handy in shading language VM
as well. I've thought, that it would be good, if isosurface and shading
language use same VM, for they are quite similar (talking within my
limited knowledge of iso functions, of course!) but this is still more
work than I want to do, especially now when 3.5 is around a corner.
Expression optimization: does this mean, that if expression's value does
not depend from run-time variables (e.g. sin(45)/sqrt(2)?), then its
value calculation is done beforehand? I've thought about doing this in
shading language compiler, but this is another not-yet-done thing.
> rendering.
I'm interested in this approach (thinking again about SL VM). Is this
"home-made" solution or are there publications available about this
technique? Will this hooking solve cross-platform compatibility?
> > Vahur,
> You? ;-)
OK, I have to admit: I lied. My grandmother forced me to write this, she
is the one who can't wait, _my_ middle name is Patience ;-)
Vahur P. Krouverk
