POV-Ray : Newsgroups : povray.unofficial.patches : HELP! layered patterns Server Time
29 Sep 2024 01:24:35 EDT (-0400)
  HELP! layered patterns (Message 1 to 5 of 5)
Subject: HELP! layered patterns
Date: 16 Mar 2001 19:47:24
Message: <3AB2B49F.8FB1B19E@yahoo.com>
<plead>i'm trying to do a fairly complicated texture, and when i tried
to make a layered texture with a base color on the bottom, a proximity
pattern over that (which has semi transparent parts), and then a planar
texture on top (which is mostly transparent except for stripes) i got an
error stating i'm not allowed to layer patterned textures.  my question
is why not?  is there another way i can accomplish the same thing?  or
will i have to make a duplicate of my original object, cut it to the
same size as the stripe, expand the overall dimensions by a minute
amount and then texture that with the stripe color?  it seems quite
inelegant if i have to do this.  perhaps i should look into shaders for
the povman patch?  or is there a way to combine a proximity pattern on
the same layer as a planar (or gradient) pattern?</plead>
TIA
Subject: Re: HELP! layered patterns
Date: 17 Mar 2001 03:07:12
Message: <3AB31B30.4235EB9A@gmx.de>
> TIA
Often similar effects as with a layered texture can be achieved with
pigment maps.  It's not that easy to construct, but it's quite flexible.
To replace a two layer texture you can either use the first or the second
layer as a base pigment and where you use transparency in the layered
texture just place the other pigment in the pigment_map.  Of yourse it's
not really identical, because the 'filter' effect can not be achieved.
Date: 17 Mar 2001 18:18:50
Message: <3AB3F160.5EC43AFD@yahoo.com>
thanks for the tip.  i'm a little short on time lately, so would you
mind posting an example of what you mean?  i have finals all next week
that i'm studying for, and when i take breaks i pov.  thanks again.  i'd
appreciate it.
> > TIA
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 18 Mar 2001 04:42:04
Message: <3AB482EE.1F67A724@gmx.de>
> appreciate it.
A simple example:
use
        gradient y
        pigment_map {
          [ 0.5 color rgb <0.0, 0.5, 0.0> ]
          [ 0.6 gradient x color_map { [0.3 rgb x][0.7 rgb z] } ]
instead of
        gradient x
        color_map {
          [0.3 rgb x]
          [0.7 rgb z]
        gradient y
        color_map {
          [0.5 color rgb <0.0, 0.5, 0.0> ]
          [0.6 color rgbt 1 ]
Date: 18 Mar 2001 12:20:00
Message: <3AB4EECD.DA25783A@yahoo.com>
thanks man, i'll give it a try.
> > appreciate it.
> A simple example:
> use
>     texture {
>       pigment {
>         gradient y
>         pigment_map {
> instead of
>     texture {
>       pigment {
>         gradient x
>         color_map {
>           [0.3 rgb x]
>           [0.7 rgb z]
>     texture {
>       pigment {
>         gradient y
>         color_map {
>           [0.6 color rgbt 1 ]
> Christoph
