POV-Ray : Newsgroups : povray.unofficial.patches : Wanna see my clothes ? Server Time
29 Sep 2024 05:16:11 EDT (-0400)
  Wanna see my clothes ? (Message 1 to 10 of 19)
Subject: Wanna see my clothes ?
Date: 6 Feb 2001 02:23:02
Message: <3A7FA655.A9EB2BB1@nanterre.marelli.fr>
There's now a patched version of POV-Ray which can do cloth simulation.
It's named ClothRay, is based on PovMan 0.62, and the generic unix
sources are available at http://tofbouf.free.fr/clothray/index_en.html
There is some tests pictures, a mini-HOWTO, and if someone can (and
want) compile a Windows version, he/she is more than welcome....
Bouf.
Subject: Re: Wanna see my clothes ?
Date: 6 Feb 2001 03:02:52
Message: <3A7FAFAD.69214AB3@gmx.de>
Looks neat,
could you maybe point out what source files are changed, so one could
easily adapt it to another Povray version?
Date: 6 Feb 2001 07:29:11
Message: <3A7FEE16.D8E81776@nanterre.marelli.fr>
Yep:
new files:
simcloth.c, simcloth.h
modified files:
express.c,
tokenize.c,
parse.h,
frame.h,
optout.h
Bouf.
Date: 6 Feb 2001 17:31:39
Message: <3A807B41.7C9E5177@gmx.de>
Thanks,
I just compiled it with Cygwin, you can get it at:
http://www.schunter.etc.tu-bs.de/~chris/raytracing.html
I found it quite difficult to use, maybe you could think about changing
the way it is used to something similar to Warp's tesselation patch.  Some
functions could probably even be identical in both patches.
Date: 7 Feb 2001 02:54:03
Message: <3A80FF1A.C3FBD85C@nanterre.marelli.fr>
> Thanks,
Thanks a lot. I think that your Windows version will be much appreciated
at the french newsgroup...
For the syntax, I'm not sure I am able to do something similar to Warp's
tesselation.
Implementation as a function was *very* easy (copy-paste of the trace()
function parsing code).
The advantage of generating a file with a bunch of points is that you
can do whatever you want with these points, not only a mesh (I'm
currently thinking of making a lying dress, with 2 parallel copy of the
points and a transmap....)
And I don't think I will do anything more until the end of the current
IRTC round (for which the patch was wrote...)
Bouf.
Date: 7 Feb 2001 03:21:26
Message: <3A810586.EB1C93DD@aetec.ee>
In this case would it be OK to include your patch in my new version of
POVMan? I intend to release new (merged with MegaPov 0.7) version soon
(in a week or so) and as Your patch is based on mine, then it should be
fairly easy to merge them.
Only problem is the name of such version: should it be ClothPovMan,
PovManCloths, PovRayManCloths or something else? :o)
Date: 7 Feb 2001 04:33:55
Message: <3A811682.15015760@nanterre.marelli.fr>
Of course, you should !!!
But, in this case, I think I'll have to write a more complete
documentation (function description, limitations, tips & tricks....)
Let's make a survey !!!! ;)
Bouf.
Date: 7 Feb 2001 06:13:29
Message: <Pine.HPX.4.21.0102071158240.28797-100000@rzpool09.rz.tu-bs.de>
I'm writing this with pine form my university account, because my home
connection is broken again, so don't wonder about the different header
etc.
Maybe i should translate it, but i think my french is not sufficient for
that :-)
> tesselation.
sounds reasonable, a more detailed documentation will probably also clear
things up.
Looking forward to it, i'm working on something too.
Date: 7 Feb 2001 12:14:31
Message: <3A818276.267161A2@ucdavis.edu>
for a name, how about MegaPov-CM, MegaPov:ClothMan, MegaPov^2 (squared),
MegaPov^CM (MegaPov raised to the CM power) etc.  I think it's kind of
important to let people know (by the name) that it is based on MegaPov
and has all of its features plus yours.  i think my favorite name was
the last one.  it would make for a good qraphic.
hopefully, my ascii art remain in tact.
> Bouf.
Date: 7 Feb 2001 16:48:15
Message: <chrishuff-83201F.16491607022001@news.povray.org>
In article <3A818276.267161A2@ucdavis.edu>, Ryan Constantine
MegaPOVMan*c^2
MegaPOV++
Christopher James Huff
