POV-Ray : Newsgroups : povray.unofficial.patches : Macros in POV-source Server Time
16 Jun 2026 01:44:41 EDT (-0400)
  Macros in POV-source (Message 1 to 5 of 5)
Subject: Macros in POV-source
Date: 19 Nov 2000 18:27:51
Message: <3A186246.8AFA7CBC@alpharay.de>
what you think about implementing of macros directly in POV
source-code??
I don't mean every small macro, i mean the famous macros,  like the
hair-macro and the tree-macros. Theese will be much faster in the source
as an POV-macro.
It is possible? Hard to implement?
Paul
Subject: Re: Macros in POV-source
Date: 19 Nov 2000 20:27:59
Message: <chrishuff-F1CBC4.20281919112000@news.povray.org>
In article <3A186246.8AFA7CBC@alpharay.de>, Paul Blaszczyk
> source-code??
> as an POV-macro.
More work than it is worth, and it would break consistency with the rest
of the POV language. If those things are added as POV features, they
should be modified to use the correct syntax. For example, trees should
be objects, not functions, POV keywords should all be lower-case, etc...
Also, it would be a tremendous amount of work to simply convert the more
complex macros and includes into functions.
BTW, for a lot of my patches, I do prototyping in POV-Script and then
use that as a base for the actual patch. The particle_system patch was
descended from a simple particle system written in POV-Script, the
extended blur patch I am now working on has it's algorithms being tested
in .pov files, etc...
Also, some features were originally macros, for example, the "sgn()"
function in MegaPOVPlus.
Christopher James Huff
Subject: Hair Macro? (Re: Macros in POV-source)
Date: 20 Nov 2000 08:39:38
Message: <3a192999@news.povray.org>
Paul Blaszczyk <3d### [at] alpharayde> wrote:
> Hi,
> source-code??
> as an POV-macro.
I thought I had a pretty good handle on what was out there.  Is there a hair
macro?  If so, where can I get it?  I don't see anything on the pov links
page.
Geoff
Subject: Re: Hair Macro? (Re: Macros in POV-source)
Date: 20 Nov 2000 09:28:36
Message: <3a193514@news.povray.org>
Geoff Wedig <wed### [at] darwinepbicwruedu> wrote:
: I thought I had a pretty good handle on what was out there.  Is there a hair
: macro?  If so, where can I get it?  I don't see anything on the pov links
: page.
  There may be several, but I think that Colefax's macro is one of the
most popular.
  It may be a little hard to find since it's "hidden" inside another
macro: The povray compressed mesh (PCM) macro. The hair macro is part of it.
http://www.geocities.com/ccolefax/pcm.html
Date: 21 Nov 2000 07:55:16
Message: <3a1a70b3$1@news.povray.org>
> : page.
> most popular.
Ah, that would explain why I couldn't find it.  Thanks.
Geoff
