POV-Ray : Newsgroups : povray.unofficial.patches : Find edges post process & real vectors Server Time
16 Jun 2026 01:45:52 EDT (-0400)
  Find edges post process & real vectors (Message 1 to 10 of 10)
Subject: Find edges post process & real vectors
Date: 16 Nov 2000 06:13:06
Message: <3A13D08F.ACC37273@hlavacek-partner.cz>
 Is there any chance to get real 2D curves with this (modified,
 of course) post process? It can be very usable for creating
 hidden-lined drawings with POV.
Disnel
Subject: Re: Find edges post process & real vectors
Date: 16 Nov 2000 06:34:40
Message: <chrishuff-418D4B.06345516112000@news.povray.org>
In article <3A13D08F.ACC37273@hlavacek-partner.cz>, Disnel
Could you clarify? I have no idea what you want...output of splines
defining the edges? Or just constant-width lines?
Christopher James Huff
Date: 16 Nov 2000 07:27:40
Message: <3A13E216.92046D4E@hlavacek-partner.cz>
Yes, splines or polylines for example. Output to some vector oriented
format
(DXF, PS or just text file with some representation of splines)
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 16 Nov 2000 09:30:49
Message: <3A13EF99.8FBE7AF7@tapasmail.net>
> format
	Use the current output, then run it through autotrace:
http://homepages.go.com/homepages/m/a/r/martweb/AutoTrace.htm
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 17 Nov 2000 06:50:19
Message: <chrishuff-0BED12.06503617112000@news.povray.org>
In article <3A13E216.92046D4E@hlavacek-partner.cz>, Disnel
> format (DXF, PS or just text file with some representation of
> splines)
This would be extremely difficult, and would probably be best as a
separate filter(so you can use it on any scene instead of only scenes
using find_edges. This is a per-pixel filter, it does not generate
splines internally and draw lines over the image, it takes each pixel
and tries to decide whether it is on an "edge". I have no idea where to
start converting the resulting pixel map into a group of splines...
Date: 20 Nov 2000 05:41:58
Message: <3A190F57.223A8EDF@hlavacek-partner.cz>
Hmmm, you ansvered me.
How about use normal vector to surface and assing, that resulting
contour of object will be perpendicular to normal vector's projection
into image plane? (Just an idea, don't know, if I'am right). And
how about edge between two CSG objects?
Disnel
Date: 20 Nov 2000 17:36:41
Message: <chrishuff-7CA5E2.17370320112000@news.povray.org>
In article <3A190F57.223A8EDF@hlavacek-partner.cz>, Disnel
I have no idea what you are trying to say...
> And how about edge between two CSG objects?
CSG objects work the same as any other objects. Why should they be any
different?
Date: 23 Nov 2000 03:40:34
Message: <3A1CE769.BDA52F38@hlavacek-partner.cz>
When you have sphere, for example, its controur is circle.
Normal vector to this circle is the same as projected normal
vector to sphere in this point. Thus we have direction of
sphere's controur in this point and we can search next point
in nearly that direction. This fails for edges on rotated cube,
for example (generally on all edges, it is usable for countour
of objects).
> different?
And it fails also on edge between two parts of some CSG.
Disnel
Date: 24 Nov 2000 17:58:33
Message: <chrishuff-509010.17590124112000@news.povray.org>
In article <3A1CE769.BDA52F38@hlavacek-partner.cz>, Disnel
Basically using the normal value of the pixels at an edge to determine
where to look for the next pixel on the edge? I don't know how easy or
reliable this would be...I think you would be better off doing the
spline outlines by hand.
Date: 30 Nov 2000 07:36:50
Message: <3A265951.EE3ACDDF@hlavacek-partner.cz>
Exactly.
Just an idea ;-).
Hmmm, its also one possible way to solve problem ;-).
Disnel
