In article <39EC8299.274E9873@schunter.etc.tu-bs.de>,
chr### [at] gmx de wrote:
> according to Chris Huff there is a problem with glows using the
> 'size' modifier interacting with other objects, but in your scene the
> problem still exists when you avoid 'size'.
This is right...don't use "size".
> After removing both 'size' and 'fade_power' i had no more any
> problems, so those two things still seem to have bugs.
In the case of fade_power, more of a cheat in the algorithm, more like
the way turbulence doesn't make 3D variations in the glow. This was just
something I added to adjust the falloff of the final values, which makes
it dependant on distance. The transparent object breaks the ray in two
parts, and the second one is shorter...which makes the result different.
So: don't use "size" yet, it is buggy, and don't use "fade_power" if you
want a remotely realistic image. If you want realism and
flexibility...use media. :-)
I will eventually have new falloff functions with adjustable falloff
amounts which should make fade_power unnecessary.
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
Chris Huff <chr### [at] mac com> wrote:
: So: don't use "size" yet
Does "size" have any effect on rendering speed? Its description sounds like
it would define a kind-of bounding sphere.
: and don't use "fade_power" if you
: want a remotely realistic image.
Well... To me "fade_power 2" looks more realistic than the default
(exactly for the same reason that a fading light source with fading power 2
is more realistic).
So I hope you fix it soon :)
: If you want realism and flexibility...use media. :-)
But media is slow and requires a lot more tweaking.
In article <39ed6af6@news.povray.org>, Warp <war### [at] tag povray org>
No, it is simply a scaling value. The calculation is always there, it
just usually doesn't do anything.
> Its description sounds like it would define a kind-of bounding sphere.
No...the "radius" keyword is the closest thing to bounding for glows.
Bounding with a sphere would probably be counterproductive...it would
probably take longer to find the intersection with a sphere than it
would to calculate the simpler glows, so "radius" does some of the glow
calculations and uses their result to decide whether to continue.
> 2 is more realistic).
It is not more accurate, and it is very unlikely that it will be
"fixed", since it does exactly what it was intended to do. In order to
get any better, falloff calculations will have to be added to the
individual types.
If you want speed and ease of use, use glows. :-)
:> Its description sounds like it would define a kind-of bounding sphere.
: No...the "radius" keyword is the closest thing to bounding for glows.
Oops! You are right. I said "size" but was thinking about "radius". Sorry :)
But if "size" can't be used, it's even worse. Of course you have to be
able to control the size of the glow.
: Bounding with a sphere would probably be counterproductive...it would
: probably take longer to find the intersection with a sphere than it
: would to calculate the simpler glows
You don't have to use real ray-sphere intersection test for this. It's
enough to test "how far is this point (the center of the glow) from this
line (the ray we are tracing)? If it's closer than 'radius', then proceed
with glow calculation, else just skip it".
Calculating the distance between a point and a line is simpler and faster
than calculating the intersection of a line and a sphere.
It might cause some speed improvement, specially when there are lots of
glows.
Or does it do this already?
:> But media is slow and requires a lot more tweaking.
: If you want speed and ease of use, use glows. :-)
But if they are buggy, the result will not be the one I wanted.
In article <39ed836d@news.povray.org>, Warp <war### [at] tag povray org>
You can do that now by making the glow brighter or dimmer. In fact, this
is how the original patch controlled the size...I may revert to doing
this internally for the first two types.
> faster than calculating the intersection of a line and a sphere. It
> glows.
That is exactly what it does. But it also affects the resulting
image...unless you use a large enough radius that there aren't any
calculations skipped, and no speedup. The two types of glows that are
fully implemented are infinite, and though individually they fade to
invisibility beyond a certain distance, when you put a large number of
them together there is a very visible difference.
They don't do what you want, but it is not a bug. The size keyword is
buggy, but fade_power does exactly what it is supposed to do: it adjusts
the final results of the glow falloff functions. This causes an
unrealistic result when reflected or seen through transparent objects,
but that is not a bug in the feature.
But Warp mentionned that the result is wrong also when the transparent
object is *behind* the glow, and that's true. He was right when he said that it
might be a problem of ray length (my guess).
In the Do_Glow code, the scattering depends both on the last intersection
found (Ray->Initial) and the next one (through Depth). I would expect the glow
to depend mostly on the Frame.Camera->Location which distance is constant to the
glow, and not from Ray->Initial that may change due to transparent objects. But
replacing that is not enough, Depth should be corrected also. Yet I didn't find
how. I also wonder how refraction would work...
Or am I completely wrong ?
Chris, I'm sure you know the answer ;-)
*** Nicolas Calimet
*** http://pov4grasp.free.fr
In article <39E### [at] free fr>, Nicolas Calimet
> said that it might be a problem of ray length (my guess).
If it shows up even when size(which is buggy) and fade_power(which is
unrealistic) are not used, then there is a problem with those
calculations...and I don't fully understand what the equations do or are
supposed to do yet.
> intersection found (Ray->Initial) and the next one (through Depth). I
> would expect the glow to depend mostly on the Frame.Camera->Location
> which distance is constant to the glow, and not from Ray->Initial
> that may change due to transparent objects. But replacing that is not
> enough, Depth should be corrected also. Yet I didn't find how. I also
If the calculations are changed to depend on the camera location instead
of the ray starting location, reflected and refracted glows will not
work at all.
Perhaps the distance used in the calculation should not be taken from
the current ray only, but from the total distance travelled by the ray
sent from the camera (and bounced from reflecting objects or refracted
from transparent objects).
Or would this be too hard?
Perhaps better a falloff algorithm that doesn't depend on the ray length.
In article <39edc188@news.povray.org>, Warp <war### [at] tag povray org>
The total distance travelled would be useful for other things, like the
pigmented light source patch, but I think it would make this problem
worse. The glow for the distance to the point would be calculated, then
the glow using the distance to that point and the one beyond it, etc.
And you can't calculate the total depth and then do the glow once,
because other things will change after reflection or refraction, like
the angle and position.
One other possible way to "fix" this would be to have it ignore
intersections with objects, and pretend the ray always goes to infinity.
This would be even less physically accurate, but would at least give
consistent *looking* results.
> length.
From one of my previous messages:
"I will eventually have new falloff functions with adjustable falloff
amounts which should make fade_power unnecessary."
So: size is known to be buggy, don't use it if you have objects in your
scene. You can control the size by adjusting the brightness of the color.
The fade_power feature is known to be unrealistic with transparent or
reflective surfaces, and I do plan on adding glow types which
incorporate control of the falloff which will avoid the problem of
fade_power, as soon as I figure out how.
Which is not necessarily a simple matter, since I didn't develop the
math in the first place, and the original author is probably busy with
Arnold, said he thought his original patch had been forgotten and that
he had abandoned that approach. And I have little time to spare...I have
school to waste most of my time, and I have several other projects I am
working on.
"Chris Huff" <chr### [at] mac com> wrote...
Interestingly enough, MegaPov has a variable in it, "Total_Depth," which
keeps track of just that sort of thing (total distance that a ray has
traveled from the camera to the curren intersection point). There is also a
variable "photonDepth" which is in the photon-tracing stuff which keeps
track of the same thing, but for photons. I'd like to combine the two into
one variable. "Total_Depth" has not been tested, but it follows the same
principle as "photonDepth," which has been tested.
The variables are set to zero before the root ray is traced, and then they
are increased/decreased in "Determine_Apparant_Colour". There may be a
better place to put the incrrease/decrease code, but that seemed to work
well.
-Nathan
-Nathan
