POV-Ray : Newsgroups : povray.unofficial.patches : Bug in glow calculation? Server Time
17 Apr 2026 22:35:27 EDT (-0400)
  Bug in glow calculation? (Message 11 to 12 of 12)
Subject: Re: Bug in glow calculation?
Date: 18 Oct 2000 16:46:17
Message: <chrishuff-A6EDE2.15490018102000@news.povray.org>
In article <39edc188@news.povray.org>, Warp <war### [at] tagpovrayorg>
wrote:
>   Perhaps the distance used in the calculation should not be taken from
> the current ray only, but from the total distance travelled by the ray
> sent from the camera (and bounced from reflecting objects or refracted
> from transparent objects).
>   Or would this be too hard?
The total distance travelled would be useful for other things, like the
pigmented light source patch, but I think it would make this problem
worse. The glow for the distance to the point would be calculated, then
the glow using the distance to that point and the one beyond it, etc.
And you can't calculate the total depth and then do the glow once,
because other things will change after reflection or refraction, like
the angle and position.
One other possible way to "fix" this would be to have it ignore
intersections with objects, and pretend the ray always goes to infinity.
This would be even less physically accurate, but would at least give
consistent *looking* results.
>   Perhaps better a falloff algorithm that doesn't depend on the ray
>   length.
From one of my previous messages:
"I will eventually have new falloff functions with adjustable falloff
amounts which should make fade_power unnecessary."
So: size is known to be buggy, don't use it if you have objects in your
scene. You can control the size by adjusting the brightness of the color.
The fade_power feature is known to be unrealistic with transparent or
reflective surfaces, and I do plan on adding glow types which
incorporate control of the falloff which will avoid the problem of
fade_power, as soon as I figure out how.
Which is not necessarily a simple matter, since I didn't develop the
math in the first place, and the original author is probably busy with
Arnold, said he thought his original patch had been forgotten and that
he had abandoned that approach. And I have little time to spare...I have
school to waste most of my time, and I have several other projects I am
working on.
Christopher James Huff
Date: 18 Oct 2000 22:32:13
Message: <39ee5d2d$1@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote...
Interestingly enough, MegaPov has a variable in it, "Total_Depth," which
keeps track of just that sort of thing (total distance that a ray has
traveled from the camera to the curren intersection point).  There is also a
variable "photonDepth" which is in the photon-tracing stuff which keeps
track of the same thing, but for photons.  I'd like to combine the two into
one variable.  "Total_Depth" has not been tested, but it follows the same
principle as "photonDepth," which has been tested.
The variables are set to zero before the root ray is traced, and then they
are increased/decreased in "Determine_Apparant_Colour".  There may be a
better place to put the incrrease/decrease code, but that seemed to work
well.
-Nathan
-Nathan
