POV-Ray : Newsgroups : povray.unofficial.patches : MegaPov 0.6a Available Server Time
16 Dec 2025 15:06:56 EST (-0500)
  MegaPov 0.6a Available (Message 11 to 19 of 19)
Subject: Re: MegaPov 0.6a: manual correction for ss 8.9
Date: 16 Oct 2000 13:51:07
Message: <39EB4009.9A12DAE9@schunter.etc.tu-bs.de>
Michael Andrews wrote:
> Hi Nathan,
> The manual gives the displace warp syntax as
> warp { displace { PATTERN, COLOR_MAP } type TYPE }
> which is what went into the MP+ manual as well.
> I understand the correct syntax (at least, it works for me) is
> warp { displace { PIGMENT_BODY type TYPE } }
> which means you can put in anything from a declared pigment name to a
> full compound pigment pattern ...
When we are talking about the displace warp documentation i would also suggest
to change the description how it works:
right now it says:
'In type 1, the brightness of the pigment color determines the directions and
amounts points are pushed.'
which is perfectly right, but does not describe things very detailed.  I would
either suggest (derived from what Chris Huff wrote in p.g.):
'It displaces the pattern according to the differences in brightness of the
control pigment's color away from brighter and towards darker areas.'
or in more mathematical terms:
'It displaces the pattern according to the gradient vector of the control
pigment's color.'
I hope suggestion this doesn't sound too picky, but since the displace warp
seems a quite important new feature, I thought it should have a complete
description.
Date: 16 Oct 2000 15:25:33
Message: <chrishuff-0F16AC.14281616102000@news.povray.org>
In article <39EB1876.6DE59632@reading.ac.uk>, Michael Andrews
That should have been:
warp { displace { PATTERN, COLOR_MAP type TYPE} }
You are right, anything that can be used in a pigment can be used there.
I'm not quite sure what I was thinking when I wrote that...
Christopher James Huff
Subject: Re: MegaPov 0.6a Available
Date: 16 Oct 2000 17:28:33
Message: <1eilyih.14qd26v1dsypaN%smellenbergh@skynet.be>
Vahur Krouverk <vah### [at] aetecee> wrote:
> Nathan Kopp wrote:
> > We are happy to announce the release of MegaPov 0.6a.  This is a bugfix
> > release to clean up some problems with MegaPov 0.6.
> I'm happy to hear this!
> But during testing of my patch I've found memory leak in old version
> (0.6) and seems like it ain't fixed in new version either:
> Function InitMallocCaches in file lighting.c allocates cache sizes
> (ShadowMediaListCacheSize, LightingMediaListCacheSize &
> MediaIntervalCacheSize), but does not free them in DeInitMallocCaches.
I discovered those memory leaks while working on 0.6. They were fixed
there and they remain fixed in 0.6a.
In lighting.c at about line 6804 in function DeInitMallocCaches() you
will find a block of code which starts like this:
  /*YS sept 17 2000 memory leak fix */
  if ( ShadowMediaListCacheSize != NULL)
POV_FREE(ShadowMediaListCacheSize);
    ShadowMediaListCacheSize=NULL;
Are you sure you use the most recent sources and not those that were on
Nathans home page for a few hours when 0.6 was released? They were not
those of the release 0.6 at that time.
Yvo Smellenbergh
e-mail:sme### [at] skynetbe
http://users.skynet.be/smellenbergh
Date: 16 Oct 2000 19:33:04
Message: <39eb9030$1@news.povray.org>
"smellenbergh" <sme### [at] skynetbe> wrote...
My bad.  Actually, somehow that bugfix didn't yet get into my source.  I
wish we had some kind of central repository, so we wouldn't have these kind
of synchronization problems.  :-(
-Nathan
Date: 16 Oct 2000 20:04:03
Message: <39eb9773@news.povray.org>
"Nathan Kopp" <Nat### [at] Koppcom> wrote...
kind
Well, my sloppy release of version 0.6 is continuing to haunt me.  :-(  As
it turns out, I was missing a few other memory leak fixes, as well as the
blob bounding-box fix and one other bugfix.  All of these were supposed to
be in 0.6, but somehow I missed them.  I was very careful to incorporate all
of the 0.6a fixes this time, but I had already missed these.  The new
version is now uploaded.  Well, yet again there will be a "bad" version of
WinMegaPov floating around out there.
-Nathan
Date: 16 Oct 2000 21:26:13
Message: <39EBA9C8.B1B68A2F@hotmail.com>
SourceForge ??
Bye
Pabs
Date: 17 Oct 2000 00:18:43
Message: <39ebd323$1@news.povray.org>
> Unfortunately, Windows has its own ideas about which letters should be
>upper case and which lower case, and AFAIK there's no easy way to change
>that.
Windows 98 and Windows NT 4 allow mixed-case filenames:
Windows 98: Under the "Folder Options" control panel, select the "View" tab,
then, in "Advanced Settings", check the "Allow all uppercase names" box.
Windows NT: Something similar.  I don't have access to a copy right now.
Mark
Date: 19 Oct 2000 22:12:50
Message: <39EE6A3D.CEDD2833@earthlink.net>
Thank you for continuing to supply the official gooey...=)
Date: 21 Oct 2000 08:24:52
Message: <39F18B61.A9919B5E@aetec.ee>
Hi, I'm bugging again :o(
When I run MegaPov test scenes, then I observed, that spline demos does
not free all the memory. More specifically, problem seems to be in
eval_3d_spline function. By examining code I found, that function
Parse_Num_Factor in express.c allocates memory for spline name when
parsing EVAL_3D_SPLINE_TOKEN, but does not free it. In case of
EVAL_SPLINE_TOKEN this spline name memory freeing is fixed, but
apparently 3d version was omitted.
In order to correct this, following line should be added before break
statement for case EVAL_3D_SPLINE_TOKEN:
POV_FREE(Local_String);
Well, thats all I have to type ;o)
