POV-Ray : Newsgroups : povray.unofficial.patches : Megapovplus glows Server Time
19 Nov 2025 07:03:53 EST (-0500)
  Megapovplus glows (Message 1 to 9 of 9)
Subject: Megapovplus glows
Date: 27 Sep 2000 05:10:37
Message: <39d1b98d@news.povray.org>
This is mainly for Chris but anyone else playing with glows may
want to take note.
I've been working on a scene with glows and I've encountered a problem
Glows do not behave well when #declared.
The following gives an error.
#declare Test=
 glow {
  location <0,0,0>
  color rgb <1,0,0>
while
#declare Test =
 union {
  glow {
   location <0,0,0>
   color rgb <1,0,0>
  sphere {
   <0,0,0>,1
   pigment {rgb 1}
gives a warning that there should be at least 2 objects in a CSG
and places the glow in the scene.
A subsequent call
object {Test}
simply places the sphere into the scene.
Also pov-ray returns an error if a glow is the last thing in a scene.
Chris, are these issues going to be addressed in the next version?
Gail
* gsh### [at] monotixcoza              * System.dat not found.         *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k  *
* If at first you don't succeed, call it version 1.0               *
Subject: Re: Megapovplus glows
Date: 27 Sep 2000 12:10:47
Message: <1ehmqh4.c2356i1u7rkttN%smellenbergh@skynet.be>
> want to take note.
We just discovered that while testing the patch. We will take a look at
it, but Chris, if you find a solution before us: Please send it over!
Thanks.
> A subsequent call
> object {Test}
We fixed that one for MegaPov 0.6. A small fix is still needed for a
simular problem.
Smellenbergh
> Gail
e-mail:sme### [at] skynetbe
http://users.skynet.be/smellenbergh
Date: 28 Sep 2000 07:02:16
Message: <chrishuff-27B57E.06043128092000@news.povray.org>
In article <39d1b98d@news.povray.org>, "Gail Shaw"
Not surprising, since I haven't put code in to allow declaring them...on
the to-do list.
> A subsequent call
> object {Test}
That is simply because glows are not objects and do not behave
completely like objects yet. Another item on the to-do list.
That is odd...
Christopher James Huff
Date: 28 Sep 2000 07:03:43
Message: <chrishuff-556D09.06055828092000@news.povray.org>
In article <1ehmqh4.c2356i1u7rkttN%smellenbergh@skynet.be>,
I will try to figure out how to implement this...
> simular problem.
What was the problem?
Date: 28 Sep 2000 08:47:00
Message: <39d33dc4@news.povray.org>
Good to know. I really like glows.
> That is odd...
I tried the following as a test scene:
// start ********************************
 location <0,0,-5>
 look_at <0,0,0>
glow {
  location <0,0,0>
  color rgb <0.8,0.6,0>*2.5
  type 1
// End****************************
and I got the following message:
  All Streams to console..........On
  Debug Stream to console.........On
  Fatal Stream to console.........On
  Render Stream to console........On
  Statistics Stream to console....On
  Warning Stream to console.......On
  type 1
 <----ERROR
C:\My Documents\test.pov:10: error: object or directive expected but End of
File found instead.
Returned from renderer (non-zero return value)
If I put any object after the glow then the scene renders.
Gail
Subject: Allowing a scene with only glow, no lights or objects [was Re: Megapovplus glows]
Date: 28 Sep 2000 15:09:56
Message: <1eholl7.1p4rshl10jgqbeN%smellenbergh@skynet.be>
> > simular problem.
First of all, in parse.c in function Parse() change things like this
(and this is for that last little fix mentioned):
  Parse_Frame ();
  Post_Media(Frame.Atmosphere);
#ifdef GlowPatch
  if (Frame.Objects == NULL && Frame.Glows == NULL)
    Error ("No objects or glows in scene.");
#else
  if (Frame.Objects == NULL)
    Error ("No objects in scene.");
#endif
  Stage = STAGE_CLEANUP_PARSE;
This makes it possible to render a scene with no objects, no lights but
only glows.
To allow parsing you should modify Parse_Frame() in parse.c like this
(at the end of the function):
#ifdef GlowPatch
  /*YS sept 18 2000
     added this here too to allow
    for a scene with only glow */
  CASE(GLOW_TOKEN)
    #ifdef UnofficialBlocking
        parseUnofficialFeature(60);
    #endif
    GLOW * NewGlow = Create_Glow();
    Parse_Glow(NewGlow);
    Add_Glow(NewGlow);
  END_CASE
#endif
     OTHERWISE
       UNGET
       Object = Parse_Object();
       if (Object == NULL)
         Parse_Error_Str ("object or directive");
       Post_Process (Object, NULL);
       Link_To_Frame (Object);
     END_CASE
   END_EXPECT
Smellenbergh
Subject: Re: Allowing a scene with only glow, no lights or objects [was Re: Megapovplus glows]
Date: 29 Sep 2000 01:49:54
Message: <39D42C6C.5BFCC87B@skynet.be>
> only glows.
Why not simply allowing POV-Ray to render even if there are no
objects ?  Issuing a simple warning instead of an error...
Fabien.
Date: 29 Sep 2000 07:59:58
Message: <39d4843d@news.povray.org>
Or making povray consider a glow to be an object.
  If there are lots of glows in the scene, wouldn't they benefit from
bounding objects (perhaps spheres could be the best)?
Date: 29 Sep 2000 22:10:29
Message: <chrishuff-14464C.21124629092000@news.povray.org>
In article <39d4843d@news.povray.org>, Warp <war### [at] tagpovrayorg>
That is my goal...to make them imitate objects, like light_sources do.
Of course, things like "hollow" and "open" would be meaningless to
them...but they will eventually be useable in CSG's and variables.
No more than plane objects or sky_spheres would...the "realistic" glow
types are "infinite". They are not objects, but effects which depend on
the angle and proximity of the ray to a point, which makes bounding a
bit...tricky. However, my most recent version does include a "radius"
feature which allows you to cut off calculation beyond a certain
distance. But this can often make a large difference in the output,
especially when using large numbers of glows, and isn't useful as an
optimization technique for small numbers.
