POV-Ray : Newsgroups : povray.unofficial.patches : Cutaway textures problem Server Time
15 May 2025 07:10:59 EDT (-0400)
  Cutaway textures problem (Message 1 to 4 of 4)
Subject: Cutaway textures problem
Date: 20 Oct 2000 04:41:11
Message: <39F00638.36C4E0F6@hlavacek-partner.cz>
Warp found some problems with cutaway_textures
(his message in this newsgroup from 09/15/00).
I have similar problem with following:
difference {
  union {
    sphere {<0, 0, 0>, 5 texture {pigment {color blue 1}}}
    sphere {<-5, 0, 0>, 2 texture {pigment {color red 1}}}
  plane {<0, 0, 1>, 0}
  cutaway_textures
works good, but
difference {
  union {
  union {
    plane {<-1, 0, 0>, 0}
  cutaway_textures
ignores cutaway_textures. I think, that the reason is that POV-Ray
automatically asigns default texture to the second union in difference
and cutaway_textures thinks, that this union has texture assigned
with user.
Q: should cutaway_texture ignore all textures in subtracted objects?
I know, that it works good when the planes are not composed to union,
but I have some cases, where I first compose some objects, which
will represent holes to another object in the future (for example
windows in wall, they are added by some macros to one composite) and
after I need cut them from another object in way like
difference {
  object {Actually_composed_wall}
  object {All_window_holes}
  cutaway_textures
Disnel
Subject: Re: Cutaway textures problem
Date: 20 Oct 2000 05:37:14
Message: <39f0124a@news.povray.org>
"Disnel" <dis### [at] hlavacek-partnercz> wrote in message
news:39F00638.36C4E0F6@hlavacek-partner.cz...
> with user.
Think you may be right, the union probably doesn't adhere to a proper entity
for that purpose.  Must be that CSG isn't applicable to the cutaway_textures
feature, doing it only on a per primitive basis.
Date: 20 Oct 2000 06:32:33
Message: <39F01FFD.2D53B262@hlavacek-partner.cz>
> > with user.
> Bob
I can remember all holes in array instead "storing" them in union,
but it is more complicated and I am limited with some fixed array
size .... possible growing array will be very useful ;-).
Disnel
Date: 20 Oct 2000 19:26:54
Message: <39f0d4be$1@news.povray.org>
"Disnel" <dis### [at] hlavacek-partnercz> wrote...
[clip]
> with user.
This sounds like a bug.  I don't have time to try to fix it now,
unfortunately.  I'll look into it, though.  It probably has something to do
with the fact that unions get split up.
-Nathan
