POV-Ray : Newsgroups : povray.unofficial.patches : Internal Editor problem w. MegaPov 0.6 Server Time
19 Nov 2025 07:05:39 EST (-0500)
  Internal Editor problem w. MegaPov 0.6 (Message 1 to 3 of 3)
Subject: Internal Editor problem w. MegaPov 0.6
Date: 4 Oct 2000 08:25:16
Message: <39DB2166.A262F304@erols.com>
At the risk of sounding too much like a novice, I am haveing a problem
with the internal edititor in megapov0.6 (thanks for the program
Nathan).  When I start the program it gives me an "Editor DLL
initialisation faies (LoadLibrary failed, code is 00000485]" message
followed by a gui that instructs me to "see the "built-in-Editors"
section of the help file."  I have attempted to fins such a section and
have been unsuccessful.  Would one of you fine gentlemen help an aging
megapover wannabe with this problem.
Thanks,
rik
Subject: Re: Internal Editor problem w. MegaPov 0.6
Date: 4 Oct 2000 08:32:56
Message: <39db2378$1@news.povray.org>
"Rik Kline" <rik### [at] erolscom> wrote in message
news:39DB2166.A262F304@erols.com...
Hi Rik,
You're probably better off waiting for one of the pros to answer. However,
the following info might help them and also might help you to work out
what's wrong.
I'm assuming you're running under win9x - which version of ordinary pov are
you running? Have you put megapov.exe in the same directory as pvengine.exe?
(normally C:\Program Files\POV-Ray for Windows v3.1\bin\). Can you still run
ordinary pov without problems (by running pvengine.exe)?
All the best.
Date: 4 Oct 2000 08:43:16
Message: <39DB259E.C0B05D15@erols.com>
Thanks Tom, it had been long enough since installing megapov0.5 that I forgot
about where to put the .exe.  It is now working fine.
rik
> Hi Rik,
> what's wrong.
> All the best.
