POV-Ray : Newsgroups : povray.unofficial.patches : Feature idea : rgb_adjust Server Time
16 Jun 2026 03:09:49 EDT (-0400)
  Feature idea : rgb_adjust (Message 1 to 8 of 8)
Subject: Feature idea : rgb_adjust
Date: 29 Sep 2000 12:17:12
Message: <39D4BF73.3A275524@skynet.be>
Here's an idea for a (simple, I think) texturing feature.  It would
give the ability to adjust resulting rgb values where they are
produced (essentially in pigments and textures).  Example :
 I need to repeat several wooden planks, and want to change
slightly their brightness, randomly.  Usually, I would do
that using ambient, but it is unpractical, and has annoying
consequences (if I use radiosity, etc..).  My idea is to do it
that way :
  pigment {wood color_map {WoodMap}
           rgb_adjust <r,g,b>*(1+rand(r1)*.1)
Other formulaes could be used to adjust contrast, hue, apply
some color filter... without messing with other settings which
are not designed to do that.  Much easier than messing with
the color_map, especially if it was generated externally.
And it would also work with any complex texture :
 texture {VeryComplexTexture scale.. rotate .. rgb_adjust <r*.5,g,b>}
...which would dim the Red channel at each point of the texture.
Fabien.
Subject: Re: Feature idea : rgb_adjust
Date: 29 Sep 2000 13:35:54
Message: <39D4D291.B88F7200@inapg.inra.fr>
Note that it's already possible to obtain some of these effects
using the average pattern (which doesn't mean that the rgb_adjust feature
wouldn't be interesting) :
#declare pig1=pigment{bozo color_map{[0 Green][1 Red]}}
plane { y, 0
        average
        pigment_map{
            [1 pig1]
            [0.1 color Cyan]
G.
Date: 29 Sep 2000 14:08:16
Message: <39d4da90@news.povray.org>
I think this would be an excellent addition to POV. I often need random or
slightly changing values for objects and colors and it ain't always easy to
do.
Mick
"Fabien Mosen" <fab### [at] skynetbe> wrote in message
news:39D4BF73.3A275524@skynet.be...
> that way :
> Fabien.
Date: 29 Sep 2000 22:02:25
Message: <chrishuff-28F4FC.21044229092000@news.povray.org>
In article <39D4BF73.3A275524@skynet.be>, Fabien Mosen
I have thought of making a variation of the color_matrix filter that
would work on pigments...but I wasn't sure if it would be useful enough
for the effort. Other filters could be done too...blurring, color space
conversions, etc...much of the same stuff available in post_process
filters. Kind of like an enhanced waveform applied to colors instead of
pattern values...
BTW, another thing in the same interesting-but-maybe-not-useful
category: waveform lists for patterns. Basically, it would allow you to
specify a sequence of waveform transformations instead of a single
one...it would be implemented as just another waveform type.
Christopher James Huff
Date: 29 Sep 2000 22:26:03
Message: <39d54f3b@news.povray.org>
? I don't get it... please reprocess and repeat...
Date: 30 Sep 2000 04:06:51
Message: <39d59f1b@news.povray.org>
I would have thought you gurus would have stated (already) that this is
possible now? I have already done it (wasn't tidy), so I know it can be
done. I just thought there was someone out there already working on it? Oh,
wait a minute, that was me! heh
Grim
Date: 6 Oct 2000 11:21:38
Message: <chrishuff-63D82A.10240506102000@news.povray.org>
In article <39d54f3b@news.povray.org>, "Tony[B]"
Ok...
Take "gradient y" for example. It makes a linear ramp-wave, the value of
the pattern increases from 0 to 1 and then drops sharply back to 0. If
you specify "sine_wave", this value is fed through a "filter" which
transforms the ramp wave to a sine wave before the color_map is read.
What I am proposing is a new waveform which allows you to specify a list
of waveform filters.
waveform_list {
    sine_wave|scallop_wave|ramp_wave|spline_wave
    add|subtract|multiply|divide|function|etc...
As an example:
pigment {bozo
    waveform_list {
        multiply 2
        ramp_wave
        sine_wave
        poly_wave 2
    color_map {...}
This would make a bozo pattern with twice the frequency, and a sine wave
falloff with sharper peaks due to the poly_wave. This isn't impossible
to do now...but you would have to feed a bozo pattern into a function
pattern and do the waveform stuff in the function...more flexible, but
harder to read, less obvious and slower.
Date: 17 Nov 2000 00:06:21
Message: <TrwUOqkX9j9FkCKOedWuRdD0=Gws@4ax.com>
On Fri, 29 Sep 2000 19:11:06 +0100, "Mick Hazelgrove"
>do.
>Mick
One way of thinking of this, is to specify a "tolerance" value in
addition to the actual parameter. Then the actual parameter would be
randomly modified by an amount within the tolerance you have
specified. If no tolerance is specified, then there would be no
modification of the parameter value.
Does anyone like this idea?
Later,
Glen
