POV-Ray : Newsgroups : povray.unofficial.patches : Noisy thoughts Server Time
16 Jun 2026 03:07:52 EDT (-0400)
  Noisy thoughts (Message 1 to 10 of 26)
Subject: Noisy thoughts
Date: 25 Sep 2000 05:34:42
Message: <39CF1C2F.82A59DAB@enst.fr>
I've been busy with the noise function this last weekend (the one in
texture.c, not the isosurface function) and I got some interresting
results I thought I'd share my progress:
* I found a slight optimization that allows it to compute faster;
* I rewrote it from scratch and got a new version that's even faster for
very similar results (but the results are different, so if you spent a
lot of tim placing your building just right in your ridged mf landscape
you won't want to use this one). The drawback is that it uses more
memory (Not so much of a problem with modern computers as it was when
the original was written);
* then I lost all the speed I had gained and then some by fixing the
range problem (very big or very negative numbers give bad result) that
occurs both with the original and my  implementation.
	Here are some numbers. I computed the minimum, maximum, mean and
standard deviation in a 64 units wide cube sampling every 0.1 unit and
got the following durations (in seconds):
                original     range fixed
megapov          505.56        628.10
improved MP      439.49        608.75
mine             421.29        606.45
	Next order of business for me (next we) is to look into DNoise and see
if the same kind of optimizations are possible. Then I intend to add
keywords in global settings to allow people to choose between improved
mp and mine, and between range fixed or not. What kind of keywords would
you prefer?
PS: I just noticed that there's a bug in the "range fixed" version. It
should be slightly faster than the numbers I just gave, but not much...
Subject: Re: Noisy thoughts
Date: 25 Sep 2000 11:24:30
Message: <39cf6e2e@news.povray.org>
> you prefer?
First, off, thank you for trying to improve something even though everyone
else thinks it's working fine already. This kind of experimentation brings
new and better things.
The synxtax I see is this: noise {method 0/1/2 fixed_range/range on/off}
If you don't use fixed_range, then you don't have to go about adding more
keywords.
Date: 25 Sep 2000 21:45:19
Message: <39cfffaf$1@news.povray.org>
"Tony[B]" <ben### [at] panamac-comnet> wrote...
Actually, not everyone thinks it's working.  Check out these posts in
povray.bugreports:
"Bug in noise function" dated 8/28/99 by Margus Ramst (this may have been
fixed already)
"Bozo "saturation" problem" dated 5/20/99 by Ron Parker (this is "fixed" in
MegaPov)
"Spotted normal bug (Jerome M. Berger)" dated 11/22/99 by Peter Popov
Because this sort of thing affects bozo, spotted, wrinkles, turbulence, and
a variety of other aspects of POV, the exact way it should be implemented
may not be this simple.
-Nathan
Date: 26 Sep 2000 01:25:32
Message: <39d0334c@news.povray.org>
> povray.bugreports:
I don't check out .bugreports very often. Point taken, nonetheless.
and
Ah, OK. What would you suggest?
Date: 26 Sep 2000 05:03:52
Message: <39D06678.79AD24B5@enst.fr>
> povray.bugreports:
> fixed already)
	This is the problem I'm addressing... The point is that in most cases,
if this problem manifests itself, you're probably not using noise
correctly. Most of the times it occurs when people translate a noise
pattern to get several different "noises". But noise is actually a
periodic function (it has a period of 4096 in the current
implementations) so you don't need to translate it as much. The problem
should only manifest itself if you zoom out a lot (but then the noise
pattern is not visible anymore). However this is only true for
"straight" noise (as in the bozo pattern) and thing might be different
in other patterns or in turbulence...
> MegaPov)
	The grid that appears is unfortunately an unavoidable side effect of
the way noise is computed. I don't think this one can be fixed except by
completely replacing the algorithm and I have no idea what could be used
instead :-(
	True enough. Unfortunately, I have neither the time, nor the overall
knowledge of pov necessary to do it "the right way". Moreover the speed
versus memory parameter should indeed be global anyway. So I think I'll
do it that way (and Tony's keywords look good to me) and let others with
more time/knowledge adapt it if they really think it's necessary (after
all, the problem doesn't occur that often, and people make do very well
with the present limitations)
Date: 26 Sep 2000 05:04:30
Message: <39D0669F.BBD80654@enst.fr>
> keywords.
	Thanks, I think I'll do it that way.
Date: 26 Sep 2000 11:38:44
Message: <39D0C35B.2AFC01E8@aetec.ee>
Speeding up noise is Good Thing(TM). Lots of textures use it and its
speedup will make scene rendering faster as well. I've thought about
trying this myself, but I haven't had time or good profiler to do it.
What is this range problem, which loses this speed-up? Can't you avoid
it?
Very big numbers? Very negative numbers? Do You mean input vector
values? Can't you subtract some negative value to push it on positive
side as it is in POV-Ray code? And then take module from this? Does this
really slow down Noise function? Or do You mean something else?
Date: 26 Sep 2000 12:06:28
Message: <39D0C983.84F02ED8@enst.fr>
> it?
	Very very positive (as in more than what a long can contain) and very
negative (as in less than -10000) numbers. Of course I can do it the
same way it's done in pov now (in fact that's what I do). But I was just
suggesting that I could add an option that would allow people to get the
whole range at the cost of speed if they need it (of course I intend to
use the fast noise as the default).
Date: 27 Sep 2000 04:17:38
Message: <39D1AD83.CA713C7D@aetec.ee>
I wonder, why this clamping reduces performance in such degree (almost
50 %)? Noise calculation does much more and requires only twice as much
time? This seems really strange.
Date: 27 Sep 2000 05:21:49
Message: <39D1BC2D.420FFC7A@enst.fr>
	I guess it's because it requires computing three modulus on doubles
which is very slow (a division + a floor + a difference)*3 whereas noise
itself mostly requires some additions and substractions (all right plus
a few multiplications, but not that many and no division)
