POV-Ray : Newsgroups : povray.unofficial.patches : Step function Server Time
17 May 2026 15:41:32 EDT (-0400)
  Step function (Message 1 to 10 of 17)
Subject: Step function
Date: 21 Aug 2000 22:17:37
Message: <39A1E2F9.CB1B7B4B@insectes.net>
I was wondering if it was possible to add a Heaviside step function for
use in isosurfaces:
say two arguments, the first is the "switch" point, where the function
goes from 0 to 1 (or vice versa), and the second is the argument, which
would be a good place to put x, y, z or whatever for the expression.
I was thinking about this for say, limiting a sinusoid to a particular
range, by multiplying it by a step function (two actually, one to
truncate each end of it). It could have other uses, I guess.....
Subject: Re: Step function
Date: 21 Aug 2000 22:30:18
Message: <chrishuff-755F17.21314021082000@news.povray.org>
In article <39A1E2F9.CB1B7B4B@insectes.net>, Libellule
> use in isosurfaces:
I'm not quite sure what you mean...but wouldn't min() and max() do what
you want? Do you want a function that is 0 below a certain input value,
and 1 above it?
Christopher James Huff
Date: 22 Aug 2000 00:01:04
Message: <39A1FABF.3E55ED39@usb.ve>
> use in isosurfaces:
You can do it with the gradient pattern used as a pigment. In the
following example, the Heaviside function domain is restricted to the x
interval (-1, 1)
#version unofficial MegaPov 0.5;
#default{pigment{rgb 1}}
camera{location <3, 5, -5>  look_at 0 angle 60}
light_source{<2,5,-5>  rgb 1}
#macro Heaviside(jump)
  #local lx = (jump + 1)/2;
  #declare myheavi =
    function{
      pigment{gradient x translate -x/2 scale 2
      color_map{[lx rgb 0][lx rgb 1]}
Heaviside(.5)
isosurface{function{y - myheavi(x, y, z)/10}
  contained_by{box -<1, 1, 1> <1, 1, 1>}
  accuracy .01
  max_gradient 21
Hope this will help you.
Regards,       Alberto
Date: 22 Aug 2000 00:29:37
Message: <39A2016F.7B1ED0D2@usb.ve>
Sorry, there is a simpler solution. Replace the previous macro by
  #declare myheavi = function{if((x - jump),1,0)}
No restriction in the domain of definition
Regards, Alberto
Date: 22 Aug 2000 00:41:00
Message: <39A2049B.223930F@insectes.net>
> and 1 above it?
Yes.
Graph of H(u)
1|      ------
 |____________
        u
The stuff Alberto mentioned looks right, does it need all that pigment
related stuff?
Date: 22 Aug 2000 10:59:33
Message: <chrishuff-84E935.10005522082000@news.povray.org>
...snip...
You don't need a macro for this, a plain old function will do fine.
#declare Heaviside = function {if(x - y, 1, 0)}
// x=the value, y=the jump threshold, z=nothing
Date: 22 Aug 2000 11:01:02
Message: <chrishuff-D10B4C.10022422082000@news.povray.org>
In article <39A### [at] insectesnet>, Libellule
> related stuff?
It is for that method, which uses the color_map of the pigment to get
the jump. For the second method, which uses an if() function, there is
no pigment, and it should execute faster.
Date: 22 Aug 2000 13:34:23
Message: <39A2B900.9BC7401A@usb.ve>
Agreed. But I think the best solution to Libellule problem should be
something like
  if(x - jump, 1, 0)
isosurface{function{y - Heaviside(actual_jump)}
  accuracy .01
  max_gradient 21
where actual_jump is a constant float.
In this way, if you need more than one step function with jumps at
distinct places in the same isosurface, this would be the optimal
implementation. I tried this code but got an error message
error: float factor expected but macro identifier found instead.
So macro substitution doesn't work inside function{...}. I thought that
at parse time, this macro substitution would take effect.
Is that a MegaPov misbehavior or is this intended for some reason?
Regards, Alberto.
Date: 22 Aug 2000 14:08:04
Message: <chrishuff-33264E.13092622082000@news.povray.org>
This is the reason I wrote it as a function. :-)
No, macros don't work within functions, neither do #if, #switch, or
#while. How should the internals of the macro work? Macros can have
local variables and can do different things for each time they are
called. The only way I can see to do it would be to have the macro be
evaluated once, at parse time, but this would make it appear to the user
that the macro is called from within the function, when it is really
called to make part of the function.
I think the best way to do things would be to extend functions to have
variable numbers of parameters(so you could just have 1 parameter, or 5,
instead of always having 3), allow functions to be called like macros
from within the scene file, and to extend the function language with
loops, variables, and conditionals(there is already an if() function,
but a slightly different syntax could be useful).
Date: 22 Aug 2000 19:25:11
Message: <39A30BD5.5E049847@club-internet.fr>
Being able to call finctions would be great, and would also suppress the
need for texture or pigment evaluation...
About the "if" function, it could also be possible to have something
like the well-known cryptic a?b:c syntax.
Adding local variables and loops would probably make things quite
different. Could you elaborate on a possible syntax? Did you think about
some lisp-like or RPN (a la PostScript) method?
      __  __ __  __  _
|  | /  \  /  / |_  /  |/
\/\/ \__/ /_ /_ |__ \_ |\
