POV-Ray : Newsgroups : povray.unofficial.patches : Step function Server Time
19 Mar 2026 20:29:25 EDT (-0400)
  Step function (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Step function
Date: 22 Aug 2000 13:34:23
Message: <39A2B900.9BC7401A@usb.ve>
Chris Huff wrote:
> You don't need a macro for this, a plain old function will do fine.
> #declare Heaviside = function {if(x - y, 1, 0)}
> // x=the value, y=the jump threshold, z=nothing
Agreed. But I think the best solution to Libellule problem should be
something like
#macro Heaviside(jump)
  if(x - jump, 1, 0)
isosurface{function{y - Heaviside(actual_jump)}
  contained_by{box -<1, 1, 1> <1, 1, 1>}
  accuracy .01
  max_gradient 21
where actual_jump is a constant float.
In this way, if you need more than one step function with jumps at
distinct places in the same isosurface, this would be the optimal
implementation. I tried this code but got an error message
error: float factor expected but macro identifier found instead.
So macro substitution doesn't work inside function{...}. I thought that
at parse time, this macro substitution would take effect.
Is that a MegaPov misbehavior or is this intended for some reason?
Regards, Alberto.
Date: 22 Aug 2000 14:08:04
Message: <chrishuff-33264E.13092622082000@news.povray.org>
This is the reason I wrote it as a function. :-)
No, macros don't work within functions, neither do #if, #switch, or
#while. How should the internals of the macro work? Macros can have
local variables and can do different things for each time they are
called. The only way I can see to do it would be to have the macro be
evaluated once, at parse time, but this would make it appear to the user
that the macro is called from within the function, when it is really
called to make part of the function.
I think the best way to do things would be to extend functions to have
variable numbers of parameters(so you could just have 1 parameter, or 5,
instead of always having 3), allow functions to be called like macros
from within the scene file, and to extend the function language with
loops, variables, and conditionals(there is already an if() function,
but a slightly different syntax could be useful).
Christopher James Huff
Date: 22 Aug 2000 19:25:11
Message: <39A30BD5.5E049847@club-internet.fr>
Being able to call finctions would be great, and would also suppress the
need for texture or pigment evaluation...
About the "if" function, it could also be possible to have something
like the well-known cryptic a?b:c syntax.
Adding local variables and loops would probably make things quite
different. Could you elaborate on a possible syntax? Did you think about
some lisp-like or RPN (a la PostScript) method?
      __  __ __  __  _
|  | /  \  /  / |_  /  |/
\/\/ \__/ /_ /_ |__ \_ |\
Date: 22 Aug 2000 22:52:18
Message: <chrishuff-3DE419.21534022082000@news.povray.org>
In article <39A30BD5.5E049847@club-internet.fr>, Francois Dispot
Do you mean using eval_pattern() or eval_pigment() to extract the value?
This makes it possible to evaluate functions in the current version, but
would break with variable numbers of parameters.
Why? Like you said, it is cryptic. I personally avoid it like goto or
the plague. :-)
The syntax would be very similar to ordinary POV, and in ways more
similar to C...I don't know what Lisp is like, and definitely not RPN(if
you mean Reverse Polish Notation, I don't know PostScript either). Just
something like this:
#declare MyFunc =
function (V, Oct, A){
    var Ctr = 0;
    var O = 0;
    var Result = 0;
    if(Oct <= 0)
        O = 1;
    else
        O = Oct;
    endif// or maybe use {} blocks
    while(Ctr < O)
        Result += sin(O*V);
        newVal += 1;
    endwhile
    Result/O
    // or
    return A*(Result/O);
#declare Value = MyFunc(clock, 4, 1.4);
I really am not sure about the return syntax...the first one would
maintain compatibility with existing functions, but might make the
parser harder to write(and it looks funny if you are used to programming
in C). Maybe the return value should be the first expression not
preceded by an expression which is using it, and not followed by =, +=,
-=, --, or ++. So if the parser encounters an equation is just sitting
there alone, not being used as input to if(), while(), or anything, or a
variable which is not being modified, it would be used as the return
value.
And maybe it should use #if(), #while(), etc. for consistency with the
rest of the language.
Date: 23 Aug 2000 00:19:42
Message: <39A3511E.6AC3CF43@insectes.net>
I was wondering about the macro, that would make it more general, but,
as has been demonstrated, they cannot be used inside functions :-)
Thanks to all, I got exactly what I needed, one-stop shopping :-))
Date: 23 Aug 2000 09:21:00
Message: <slrn8q7kmh.1ta.ron.parker@fwi.com>
>value.
Perl uses the value of the last evaluated expression as the return value.
Could that work?
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 23 Aug 2000 09:36:37
Message: <chrishuff-73EA9B.08380023082000@news.povray.org>
In article <slr### [at] fwicom>, ron### [at] povrayorg
> Could that work?
It might, I think...does it just return at the end of the function with
the value of the last expression, or is there an equivalent to the
"return" statement in C?
It could be useful to have any "orphan" expression force a return with
the value of that expression if it is reached, that would allow multiple
exit points. Or maybe that isn't a good idea...I have found it sometimes
makes cleaner code, but I have also heard it isn't good programming
style. And constantly checking every expression for the returning
conditions might slow things down, but maybe a "return" statement could
be inserted at parse-time so the checking doesn't have to be done at
run-time...
Date: 23 Aug 2000 10:27:47
Message: <39a3df63$1@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-73EA9B.08380023082000@news.povray.org...
value.
> > Could that work?
Both - it will return the last evaluated expression or you can use "return
$foo", so
sub foobar{
    $foo = 1;
    return $foo;
is the same as
sub foobar{
    $foo = 1;
Date: 23 Aug 2000 10:54:33
Message: <slrn8q7q61.1u4.ron.parker@fwi.com>
>> Could that work?
Yes.
That is, it does both.
Date: 23 Aug 2000 11:24:59
Message: <chrishuff-095530.10262323082000@news.povray.org>
wrote:
> Yes.
This sounds like a good compromise. :-)
Now, just have to figure out how to write it...I don't understand much
of the isosurface code at all, hopefully the function stuff will be
separated out and cleaned up in 3.5.
