POV-Ray : Newsgroups : povray.unofficial.patches : Step function Server Time
13 Mar 2026 00:01:16 EDT (-0400)
  Step function (Message 11 to 17 of 17)
Subject: Re: Step function
Date: 22 Aug 2000 22:52:18
Message: <chrishuff-3DE419.21534022082000@news.povray.org>
In article <39A30BD5.5E049847@club-internet.fr>, Francois Dispot
<woz### [at] club-internetfr> wrote:
> Being able to call finctions would be great, and would also suppress the
> need for texture or pigment evaluation...
Do you mean using eval_pattern() or eval_pigment() to extract the value?
This makes it possible to evaluate functions in the current version, but
would break with variable numbers of parameters.
> About the "if" function, it could also be possible to have something
> like the well-known cryptic a?b:c syntax.
Why? Like you said, it is cryptic. I personally avoid it like goto or
the plague. :-)
> Adding local variables and loops would probably make things quite
> different. Could you elaborate on a possible syntax? Did you think about
> some lisp-like or RPN (a la PostScript) method?
The syntax would be very similar to ordinary POV, and in ways more
similar to C...I don't know what Lisp is like, and definitely not RPN(if
you mean Reverse Polish Notation, I don't know PostScript either). Just
something like this:
#declare MyFunc =
function (V, Oct, A){
    var Ctr = 0;
    var O = 0;
    var Result = 0;
    if(Oct <= 0)
        O = 1;
    else
        O = Oct;
    endif// or maybe use {} blocks
    while(Ctr < O)
        Result += sin(O*V);
        newVal += 1;
    endwhile
    Result/O
    // or
    return A*(Result/O);
#declare Value = MyFunc(clock, 4, 1.4);
I really am not sure about the return syntax...the first one would
maintain compatibility with existing functions, but might make the
parser harder to write(and it looks funny if you are used to programming
in C). Maybe the return value should be the first expression not
preceded by an expression which is using it, and not followed by =, +=,
-=, --, or ++. So if the parser encounters an equation is just sitting
there alone, not being used as input to if(), while(), or anything, or a
variable which is not being modified, it would be used as the return
value.
And maybe it should use #if(), #while(), etc. for consistency with the
rest of the language.
Christopher James Huff
Date: 23 Aug 2000 00:19:42
Message: <39A3511E.6AC3CF43@insectes.net>
> You don't need a macro for this, a plain old function will do fine.
> #declare Heaviside = function {if(x - y, 1, 0)}
> // x=the value, y=the jump threshold, z=nothing
I was wondering about the macro, that would make it more general, but,
as has been demonstrated, they cannot be used inside functions :-)
Thanks to all, I got exactly what I needed, one-stop shopping :-))
Date: 23 Aug 2000 09:21:00
Message: <slrn8q7kmh.1ta.ron.parker@fwi.com>
>value.
Perl uses the value of the last evaluated expression as the return value.
Could that work?
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 23 Aug 2000 09:36:37
Message: <chrishuff-73EA9B.08380023082000@news.povray.org>
In article <slr### [at] fwicom>, ron### [at] povrayorg
> Could that work?
It might, I think...does it just return at the end of the function with
the value of the last expression, or is there an equivalent to the
"return" statement in C?
It could be useful to have any "orphan" expression force a return with
the value of that expression if it is reached, that would allow multiple
exit points. Or maybe that isn't a good idea...I have found it sometimes
makes cleaner code, but I have also heard it isn't good programming
style. And constantly checking every expression for the returning
conditions might slow things down, but maybe a "return" statement could
be inserted at parse-time so the checking doesn't have to be done at
run-time...
Date: 23 Aug 2000 10:27:47
Message: <39a3df63$1@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-73EA9B.08380023082000@news.povray.org...
value.
> > Could that work?
Both - it will return the last evaluated expression or you can use "return
$foo", so
sub foobar{
    $foo = 1;
    return $foo;
is the same as
sub foobar{
    $foo = 1;
Date: 23 Aug 2000 10:54:33
Message: <slrn8q7q61.1u4.ron.parker@fwi.com>
>> Could that work?
Yes.
That is, it does both.
Date: 23 Aug 2000 11:24:59
Message: <chrishuff-095530.10262323082000@news.povray.org>
wrote:
> Yes.
This sounds like a good compromise. :-)
Now, just have to figure out how to write it...I don't understand much
of the isosurface code at all, hopefully the function stuff will be
separated out and cleaned up in 3.5.
