POV-Ray : Newsgroups : povray.unofficial.patches : megapov translate bug Server Time
5 Apr 2026 06:01:01 EDT (-0400)
  megapov translate bug (Message 1 to 10 of 11)
Subject: megapov translate bug
Date: 6 Aug 2000 18:50:09
Message: <398deba1$1@news.povray.org>
mega pov running in official mode works fine with
  translate  7.5*z
in mega mode, it dosen't, i have to change it to
  translate  <0,0,7.5>
why??
Subject: Re: megapov translate bug
Date: 6 Aug 2000 19:01:06
Message: <398dee32$1@news.povray.org>
oops! - just realised i was running megapov 0.2, will download 0.5 and try
it again...
"Rick [Kitty5]" <kit### [at] dialpipexcom> wrote in message
news:398deba1$1@news.povray.org...
>   translate  7.5*z
>   translate  <0,0,7.5>
> why??
> Rick
Date: 6 Aug 2000 19:08:59
Message: <398df00b@news.povray.org>
nope bug is still there
news:398dee32$1@news.povray.org...
> it again...
> Rick
> >   translate  7.5*z
> >   translate  <0,0,7.5>
> > why??
> > Rick
Date: 6 Aug 2000 19:31:54
Message: <398df56a@news.povray.org>
news:398df00b@news.povray.org...
That's strange, I use the shorthand all the time in WMP0.5a.  Never seen a
problem with that.
Date: 6 Aug 2000 20:25:59
Message: <690sosognu8q9v6tkiej822nvj6k8c73n4@4ax.com>
On Sun, 6 Aug 2000 18:32:00 -0500, "Bob Hughes"
>problem with that.
The problem is not in the shortcut itself, it's the parser. I've
noticed such inconsistent behaviour in 0.3, 0.4 and 0.5 but was never
smart enough to save the file and hunt down the bug to report it. Most
of the problems I had were related to a missing closing brace which
was there. Adding another one fixed the problem though it was
obviously wrong (as official POV and the 'match brace' function of the
editor confirm).
I remember some of the files I got from these groups had such a
problem, with some luck I might find it.
Peter Popov ICQ : 15002700
Date: 6 Aug 2000 23:40:36
Message: <398e2fb4@news.povray.org>
Rick [Kitty5] <kit### [at] dialpipexcom> wrote...
>   translate  7.5*z
>   translate  <0,0,7.5>
> why??
First, what exactly doesn't work.  Does it give a parse error, or does it
parse but just translate incorrectly (and if so, in what way)?
Things that have changed in the MegaPov parser that might cause this:
1) vector->color promotion fixes
2) fast macro patch
3) $ and % as shortcuts for #declare and #local
Are you using macros or $/%?  If not, my guess would be bug in the
vector->color promotion fixes.  If you can send a complete (yet short and
simple) scene that demonstrates the problem, that'd help a lot in tracking
it down.  Thanks.
-Nathan
Date: 6 Aug 2000 23:42:42
Message: <398e3032@news.povray.org>
Nathan Kopp <Nat### [at] Koppcom> wrote...
> >   translate  7.5*z
> 2) fast macro patch
Wait... switching to 'official' mode doesn't turn either of these off, so it
couldn't be them.
So that means it's either this or some other change that I've forgotten
about.
-Nathan
Date: 7 Aug 2000 00:29:48
Message: <398e3b3c@news.povray.org>
Rick [Kitty5] wrote in message <398df00b@news.povray.org>...
>> >   translate  7.5*z
Does translate z*7.5 work?  What about 7.5*<0,0,1>?  Or <0,0,1>*7.5?
Mark
Date: 7 Aug 2000 06:14:28
Message: <398e8c03@news.povray.org>
I just tried this and saw no problem at all.
  Can you be more specific about the problem you are having (and perhaps post
some source code (as small as possible))?
Date: 8 Aug 2000 14:26:03
Message: <399050bb$1@news.povray.org>
Nathan, this related tot he translate issue, but I have discovered a problem
with the $ shorcut in MegaPOV 0.5a.
If I use
$Dothis = 0;
after a texture with a finish, is does not parse.
'Object or directive expected but $ found instead' is the message
Sample code:
#declare M_texture = texture {
  pigment {rgb <0.75, 0.75, 0.75>  }
  finish {
    ambient 0.1
    brilliance 6
    diffuse 0.7
    metallic
    specular 0.80
    roughness 1/120
    reflection 0.8
$Dothis = 0;
This complains about the $Dothis
if the $Dothis is before the #declare it works correctly.
I discovered this beceause the #declare was in a .inc file and the $Dothis
was giving an error...
Alan
"Nathan Kopp" <Nat### [at] Koppcom> wrote in message
news:398e3032@news.povray.org...
> > >   translate  7.5*z
> > 2) fast macro patch
it
> couldn't be them.
> about.
> -Nathan
