POV-Ray : Newsgroups : povray.unofficial.patches : Why & has higher precedence than + or - in isosurface functions? Server Time
16 Jun 2026 04:55:59 EDT (-0400)
  Why & has higher precedence than + or - in isosurface functions? (Message 1 to 10 of 41)
Subject: Why & has higher precedence than + or - in isosurface functions?
Date: 31 Jul 2000 09:03:01
Message: <39857905@news.povray.org>
Is there a reason for the operator & having higher precedence than + or -
  The equivalent operator in logic (the one that looks like an upside down 'V')
hasn't, and it would be natural to have the same precedence in isosurface
functions.
  If I write this function:
function { x+y & y+z }
at least I read it in the same way as in mathematics (I'll use '&' here, but
imagine that it's the upside down 'V'):
x+y=0 & y+z=0
  However the current isosurface implementation reads it this way:
x+(y&y)+z
Subject: Re: Why & has higher precedence than + or - in isosurface functions?
Date: 31 Jul 2000 12:37:30
Message: <3985ab4a$1@news.povray.org>
In article <39857905@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> Is there a reason for the operator & having higher precedence than + or - in
This looks like a bug to me, it should have lower precedence.
    Thorsten
e-mail: tho### [at] trfde
Date: 31 Jul 2000 14:30:43
Message: <3985C626.46C5B6E8@videotron.ca>
is "&" supposed to be the AND logical operator??It seems so,and if it
is, then it's normal: boolean operator have higher precedence than
arithmetical ones in almost all languages(and Maths); if not, then it's
a bug...
Could somebody explain why the patch uses "^" for something else than
exponents??
HTH,
 Paul
AKA paul_virak_khuong at yahoo.com, pkhuong at deja.com, pkhuong at
crosswinds.net and pkhuong at technologist.com(list not complete)...
Date: 31 Jul 2000 14:50:47
Message: <3985ca87@news.povray.org>
In article <3985C626.46C5B6E8@videotron.ca> , pk <thi### [at] videotronca>
> exponents??
As far as I know it does not use it for anything else...
    Thorsten
Date: 31 Jul 2000 14:58:30
Message: <3985CCA9.1452D454@videotron.ca>
> > exponents??
Then, why did warp say "^"(that's an inverted V, right?) does the
opposite of &?
Paul
Date: 31 Jul 2000 15:20:05
Message: <slrn8obl55.1qn.ron.parker@fwi.com>
>> > exponents??
>opposite of &?
He was referring to the mathematical symbol that looks like an inverted V.
That symbol represents logical "and", and looks nothing like a caret.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 31 Jul 2000 15:21:10
Message: <mj1bos4rmn9url4dp0shdmegjdron19h8b@4ax.com>
Well, for me & has always meant binary 'and' or binary multiplication.
As such I find it logical for it to have a higher precedence than
addition. Your mileage may vary but that largely depends on the
programming languages you're most comfortable with :)
Peter Popov ICQ : 15002700
Date: 31 Jul 2000 15:51:58
Message: <3985d8de@news.povray.org>
In article <mj1bos4rmn9url4dp0shdmegjdron19h8b@4ax.com> , Peter Popov
No, both, binary and logical and should have lower precedence.  If it is
binary it could at most have the same precedence to make any sense at all.
If you look at various programming languages you will find that all current
ones obey the rules set by mathematics.
As for binary operations, I think a dot=and, a plus=or and a line above=not
are very common or even standard.  In this case a 'and' has higher
precedence, but this has little to do with general math and is not related.
The & sign in isosurfaces is obviously the equivalent of the inverted-V, and
thus it should have lower precedence.  As for the not inverted-V, the '|'
(or-sign), I am not sure about the current implementation, but is should
also have lower precedence.
   Thorsten
Date: 1 Aug 2000 06:24:26
Message: <3986a55a@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: The & sign in isosurfaces is obviously the equivalent of the inverted-V, and
: thus it should have lower precedence.  As for the not inverted-V, the '|'
: (or-sign), I am not sure about the current implementation, but is should
: also have lower precedence.
  Also | should have lower precedence than &, so if we have this:
x-y | y-z & x+z
it should be interpreted in this way:
(x-y) | ((y-z) & (x+z))
  In this way it will be consistent with mathematics.
Date: 1 Aug 2000 07:45:21
Message: <3986b851$1@news.povray.org>
In article <3986a55a@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> x-y | y-z & x+z
I agree.
