POV-Ray : Newsgroups : povray.unofficial.patches : ISO question, returning y val Server Time
16 Jun 2026 04:56:04 EDT (-0400)
  ISO question, returning y val (Message 1 to 7 of 7)
Subject: ISO question, returning y val
Date: 27 Jul 2000 10:11:38
Message: <3980431a$1@news.povray.org>
Is there anyway, when using iso-surfaces, of returning the max and min
values of the surface for y?
For example, if creating a turbulent sea (!) how would I easily find out
what the highest wave peak was and the lowest trough?
Subject: Re: ISO question, returning y val
Date: 27 Jul 2000 12:01:58
Message: <39805cf5@news.povray.org>
Tom Melly <tom### [at] tomandluf9couk> wrote:
: Is there anyway, when using iso-surfaces, of returning the max and min
: values of the surface for y?
  For many function this can be analytically impossible to calculate. You
can try to approximate with some stochastic algorithm.
Date: 27 Jul 2000 12:21:19
Message: <3980617f@news.povray.org>
news:39805cf5@news.povray.org...
So what is POV doing? Does it calculate the surface in some way that doesn't
depend on "knowing" where the surface is?
> You
Well, you could. Meanwhile, I'll go and look up "stochastic" in the
dictionary.
Date: 27 Jul 2000 12:26:59
Message: <398062d1@news.povray.org>
:>   For many function this can be analytically impossible to calculate.
: So what is POV doing? Does it calculate the surface in some way that doesn't
: depend on "knowing" where the surface is?
  Povray uses a stochastic algorithm, ie. it takes many samples and tries
to approximate the right value. It will seldom hit the mathematically exact
value.
  (This as far as I have understood correctly the isosurface raytracing.)
:> You
:> can try to approximate with some stochastic algorithm.
: Well, you could. Meanwhile, I'll go and look up "stochastic" in the
: dictionary.
  Stochastic (AFAIK) is a method of taking many samples and searching the
correct value this way. Povray's radiosity uses this kind of technique.
Date: 27 Jul 2000 12:45:01
Message: <slrn8o0qft.uip.ron.parker@fwi.com>
>value.
Well, it's not technically stochastic.  Stochastic implies some degree of
(pseudo)randomness.  POV (Well, MegaPOV, and future versions of POV) does
use a numerical algorithm, and thus is susceptible to error, but it's
deterministic and the error can be bounded to be as small as you want to,
within the limits of your machine's FP precision.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 31 Jul 2000 10:17:34
Message: <39858943.B02BF0E2@my-dejanews.com>
In case you weren't able to decipher their answers, they mean the following.
(I have working code for this at home, this is from memory):
Assume your box is bounded by        _/- x_extent, and  _/- z_extent
#delcare ymin=1000000000;
#declare ymax=-1000000000;
#declare ysum=0;
#declare count=0;
#declare dx=0;
#declare dz=0;
#while(dx<100)  // or any other big number
    #while (dz<100)  // or any other big number
        #declare Norm=<0,0,0>;
        #declare tracey=trace(Your_Iso_Object,  < (dx-50)/50*x_extent,
10000000,  (dx-50)/50*x_extent>, -y, Norm);
        #if (Norm.x = 0 & Norm.y=0 & Norm.z = 0)
            #debug "You tried to sample a point that is beyond the extent of
the surface, I'm quittin' >:-P"
            #declare asdf=1/0;
        #else
            #if (tracey.y>ymax)
                 #declare ymax=tracey;
            #if (tracey.y<ymin)
                 #declare ymin=tracey.y;
            #declare ysum=ysum+tracey.y;
            #declare count=count+1;
#declare dz=dz+1;
#declare dz=0;
#declare dx=dz+1;
#declare yavg=ysum/count;
Date: 31 Jul 2000 11:02:05
Message: <398594ed@news.povray.org>
"Greg M. Johnson" <gre### [at] my-dejanewscom> wrote in message
news:39858943.B02BF0E2@my-dejanews.com...
following.
> <SNIP>
Ah, many thanks. I'll try it tonight. - so "stochastic" is just a posh word
for kludge? ;)
