POV-Ray : Newsgroups : povray.unofficial.patches : Suggestions for spline function implementation Server Time
15 May 2025 13:01:06 EDT (-0400)
  Suggestions for spline function implementation (Message 1 to 10 of 12)
Subject: Suggestions for spline function implementation
Date: 22 Jul 2000 10:59:15
Message: <3979B575.F3DBCCD5@skynet.be>
[note : this is a user's point of view, I am totally unable to get
 my hands on the actual c code.  These suggestions comes from an
 (unsuccessfull) attempt to make a special (but logical) use of the
 spline function.]
Problems with the current implementation :
 - The name of the splines are defined as a string inside the spline
   definition.  This is inconsistent within POV-Ray syntax, and does
   not allow redefinition of a spline (a new spline with the same
   name).  Thus, it does not allow the algorithmic generation of
   multiple splines.
 - Unability to "extract" values of the control points (for example,
   if I want to put a sphere at each control point)
What would be a nice syntax ?
 - the spline's data would be stocked into an ordinary declared array
   of points
      #declare MySpline = array[N]{Pt1, Pt2, Pt3,.. PtN}
   this would allow both easy redefinition of data and extraction of
   data for other purposes than splines.  Also, it would be consistent
   with common syntax.
 - points on the spline would be retrieved by a function :
    #declare Point =
     eval_3D_spline (Identifier,[options : natural..],Position)
   this allows using different options at different times, using the
   same data.
And also :
 - suppress the 2D spline function, the user just have to declare
   points with one of the vector components set at 0.
 - suppress the "spline {..}" function, it became useless.
Cheers,
Fabien.
Subject: Re: Suggestions for spline function implementation
Date: 22 Jul 2000 13:27:54
Message: <3979D99C.153AC368@kivisalo.net>
>    of points
My linear cubic spline macro works like this but you only get
natural cubic spline. The linear part describes the fact that
the parameter points linearily along the length of the spline.
K.K.
Date: 22 Jul 2000 19:31:25
Message: <chrishuff-E82A84.18320222072000@news.povray.org>
In article <3979B575.F3DBCCD5@skynet.be>, Fabien Mosen
>    multiple splines.
Why not just use the "other" spline patch, the one with this syntax:
#declare SplineIdent =
spline {
This could easily be extended to do the things you want, and has a much
simpler and more intuitive syntax which is fairly consistent with the
rest of the POV-Ray language syntax.
Date: 23 Jul 2000 00:33:13
Message: <01bff45f$27f4fa60$397889d0@daysix>
I'm afraid I must disagree.  This spline is far more useful, and could fix
many of the problems you have.  Also, it seems to be faster, and more
intuitive that the other method.  It is also far more useful for
animations, as it can hold vectors, rotations, floats, etc. Give it a try.
I don't want to loose this baby.
H.E. Day
Date: 23 Jul 2000 08:21:29
Message: <397AE1F9.7755E424@skynet.be>
 Thank you very much, that's just what I needed !  And
it parses quite fast, too...
Fabien.
Date: 23 Jul 2000 08:26:25
Message: <397AE320.4507A0A9@skynet.be>
> spline {
Well, I tried this one altogether, but it doesn't suit my current
needs : I need to evenly gather intervals along the spline, without
having to take care of the spline's "gradation" (the argument before
the vector), which is difficult with this "alternate" implementation.
I've just posted an example of what I need to do (and will be finally
able to do elegantly thanks to Kari's macro) in "binaries.images",
it shows well why I need it to work that way.
Thaks anyway,
Fabien.
Date: 23 Jul 2000 08:29:14
Message: <397AE3CA.AA1EEBD8@skynet.be>
Well, you're right !  I did not think too much when saying that.
Sorry.
However, I'd like to see, in the future, a single spline function that
would elegantly cover all the needs.
Fabien.
Date: 23 Jul 2000 12:16:03
Message: <chrishuff-6F31D5.11164123072000@news.povray.org>
In article <397AE320.4507A0A9@skynet.be>, Fabien Mosen
It should be quite easy to make a macro to find a point a fixed distance
on a spline from a given one...and this syntax looks like it would be
more easily extended to allow these features to be added.
Date: 23 Jul 2000 23:37:04
Message: <397BB8B8.C551A8D3@skynet.be>
I gave it another try, but but but :
 - it's impossible to pass a spline identifier as a #macro parameter
 - it's impossible to #declare a point :
         #declare Point = SplineIdent (Value);
 I had to go trough sidepaths to achieve what I needed to do (e.g.
 creating a temporary spline from a declared array within the macro)
 - and I still miss the "linear natural cubic" quality of the other
   splines.  (and if I write a #macro to evenly distribute the "samples"
   along the spline, the parsing times will go trough the roof, as it
   does, alas, when using Kari's #macro).
  (please consider this as a report, not a complain/request)
Fabien.
Date: 24 Jul 2000 02:05:12
Message: <397BDC98.AECA6108@kivisalo.net>
Until this feature is added to megapov try changing the tolerance
value near the end of the macro. I haven't tested this but reasonably
even distribution should be possible with 0.05.
#local err=0.001*slen;
K.K.
