POV-Ray : Newsgroups : povray.unofficial.patches : Making waves - isosurface help Server Time
17 May 2026 15:42:47 EDT (-0400)
  Making waves - isosurface help (Message 1 to 3 of 3)
Subject: Making waves - isosurface help
Date: 20 Jul 2000 04:53:54
Message: <3976be22@news.povray.org>
Assuming I didn't want to just use an inbuilt function, etc., what would be
the equation to generate a pattern similiar to ripples in an isosurface?
(ie. circular waves propagating outwards from a point).
Ta.
Subject: Re: Making waves - isosurface help
Date: 20 Jul 2000 05:56:03
Message: <3976CC76.4D63796D@reading.ac.uk>
Hi Tom,
The simplest is probably
#declare My_Ripples = function { sin(2*pi*sqrt(sqr(x)+sqr(z))) }
#declare Water_Surface = function { y - 0.2*My_Ripples }
and use function { Water_Surface } in the isosurface.
If you want more sea wave shaped ripples, I find
#declare Water_Surface = function { y - 0.2*abs(My_Ripples(x/2,0,z/2))^N
where N is around 6 or so is quite good.
Bye for now,
	Mike Andrews.
> Ta.
Date: 20 Jul 2000 09:48:32
Message: <chrishuff-FE1F5E.08490620072000@news.povray.org>
In article <3976be22@news.povray.org>, "Tom Melly"
> would be the equation to generate a pattern similiar to ripples in an
> isosurface? (ie. circular waves propagating outwards from a point).
You usually use the cosine of the distance from that point. This gives
an "onion" type pattern, with the waves emanating in all directions from
a point. You can also constrain it to a certain plane by removing one
axis from the calculations, which makes it act like wood. You may want
this for some uses.
Where <A, B, C> are the coordinates of the "center" of the ring:
"onion-like" function:
function {cos(2*pi*sqrt(sqr(x-A) + sqr(y-B) + sqr(z-C)))}
"wood-like" function(along y-axis):
function {cos(2*pi*sqrt(sqr(x-A) + sqr(z-C)))}
It is also possible to have the "waves" fall off with distance. To do
this, just multiply the above function by a function which falls off
with distance, like this:
Where R = radius, F = falloff exponent.
#declare D = function {cos(2*pi*sqrt(sqr(x) + sqr(y) + sqr(z)))}
function {
    D(x-A,0,z-C)*((max(0, R-sqrt(sqr(x-A) + sqr(z-C)))/R)^F)
Some additional things: I use sqr(x) instead of x*x or x^2, because it
may be slightly faster. I also prefer to use cosine instead of sine for
waves, because it makes a smooth center.
Disclaimer: I haven't actually tested these functions, there may be an
error or typo somewhere. They should be close, though...
