Anybody have any success using the ipf_profile feature in Chris's patch?
Running 0.2.5 (Windows compile), I get "Singular matrix in MInvers" whenever I
try to use ipf_profile (type 1 or 2). The simulation completes OK, then parse
exits with the aforementioned error.
Example (sligtly modified from particleFalls.pov):
particle_system {
wind < 0, 0, 0>
iterations 250
time 200
environment object {Floor}
threshold 1.5
particle_emitter {
location < 0, 4.1, 0>
radius 0.3
lifespan 1000
rate 5
direction < 0, 0.2, 0>
ipf_profile {
2, .005,
.5, 2
pigment {color rgb < 0.7, 0.75, 1>}
Margus Ramst
Personal e-mail: mar### [at] peak edu ee
TAG (Team Assistance Group) e-mail: mar### [at] tag povray org
In article <397363FD.44B2276A@peak.edu.ee>, Margus Ramst
> whenever I try to use ipf_profile (type 1 or 2). The simulation
> completes OK, then parse exits with the aforementioned error.
My first thought is that NaN values are getting into the simulation
somewhere, and messing up the particle stretch calculations.
There is a bug in the particle stretch feature, one of the variables is
left uninitialized, so you have to manually turn it off by using
"particle_stretch 0,0" if you don't want to use this feature. This will
be fixed in the next version.
As for the ipf feature...my advice would be not to use it right now. It
is still very imperfect, and I will be making some changes in the future
to allow multiple fluid types. For one thing, the internal function
doesn't work with falloff values below 1 or even values above 1. Since
you used 2 as the exponent, it won't behave as it should.
Christopher James Huff - Personal e-mail: chr### [at] mac com
TAG(Technical Assistance Group) e-mail: chr### [at] tag povray org
Thanks.
One more thing: the probem also seems to occur on the first (non-ipf) run after
the ipf run. Consecutive runs (unmodified) are OK.
Out of curiosity, if you feel like explaining, how is the inter-particle
collision implemented? It takes lot of time, which is understandable, but it
strikes me as slow even with a very small ipf_distance (if I understand its
purpose correctly). Are you already using some sorting algorithm, like kd-tree
or oct-tree, to optimize things?
Margus Ramst
In article <39738497.A75CD4CC@peak.edu.ee>, Margus Ramst
> Thanks.
> run after the ipf run. Consecutive runs (unmodified) are OK.
So you run the simulation with inter-particle forces, then run it
without, and *then* it aborts parsing? Sounds like some variable isn't
being initialized...
> inter-particle collision implemented?
It isn't...the particles are points, with no size. "IPF" stands for
Inter-Particle Forces. Basically, each particle is pushed toward or away
from it's neighboring particles within the ipf distance, with a force
that depends on the distance. Positive values attract, negative values
repel(or is it the other way around...?). The default function produces
a symmetrical curve going from +1 to -1, with a relatively flat area in
the middle, which pulls toward more distant particles and pushes away
from nearer particles. The spline ("custom" profile) option allows you
to specify the curve with a spline {} instead of using the built-in
function. Particles outside the ipf distance are ignored.
I am thinking of adding a type of "solid" particles which *would* have
collision, but I need to learn more about simulating rigid object
collisions first. This is something I can't seem to figure out on my
own...the only ways I can think of would be very computationally
expensive.
> It takes lot of time, which is understandable, but it strikes me as
> slow even with a very small ipf_distance (if I understand its purpose
> kd-tree or oct-tree, to optimize things?
I haven't implemented any kind of sorting yet, though I plan to.
Currently, every particle has to be checked for distance, so every
particle has to be compared against every particle in existence for
distance, once for every iteration. This is why it is so slow.
I will probably use some kind of tree of nested, overlapping
boxes(octree?), though it is still in the planning stages. One of the
problems is that it will have to cope with particles moving from one
area of space to the next.
Oh, and what is a kd-tree? I have heard of it, and I know it is some
sort of data structure, but that is the limit of my knowledge.
Any suggestions for optimization techniques for this would be welcome.
Also, something similar may be used to bound the generated blob shape
more efficiently, and could also be used to optimize the blob pattern...
Strange, it sometimes happens without running ipf previously (although that
seems to be a sure-fire way). Haven't found the connection yet.
I see. Actually, I think this is sufficient in most cases, especially with
liquids. As for the "solid" particles - I don't think inter-particle collision
and deflection would be at all expensive for spherical particles, and
prohibitively expensive for most other shapes. What physical properties would be
needed? Collision is easy, deflection and impact energy absorption too, friction
I'm not so sure about... What else?
BTW, I found an interesting page discussing sorting algorithms for particle
systems (specifically kd-trees and Barnes-Hut trees). I saw no actual code, but
pretty informative nevertheless. The URL is:
http://physics.gmu.edu/~large/lr_forces/lr_general.html
Margus Ramst
What about rotation effects - where as 2 spheres are moving through space they
rotate around an axis and when they collide their subsequent movements, velocities &
rotations depend on both the velocities and rotation axes of the two particles.
Bye
Pabs
Yes, but is this really worth the computational expense? I suspect the spin of
individual particles has little perceptible effect on the overall behaviour a
large particle system.
Margus Ramst
Some more potentially interesting resources.
The first has a PS paper and source code of a density-based particle sorting
mechanism (uses kd-trees):
http://www.sns.ias.edu/~eisenste/hop/hop.html
And a brief description of kd-trees:
http://web.mit.edu/napoli/www/6.838/kd.html
Margus Ramst
I think when considering *Solid Particles* or balls/spheres we are getting out of the
_particle_ domain (aren't particles 1D not 3D) & into the physics of solid objects a
bit
more, which is a lot more complex than that of particles.
Bye
Pabs
the
bit
They are still particles in the sense of being elements in a very large set,
where the contribution of the individual is relatively small. It's a case of
diminishing returns. I think the physics model of individual particles needn't
be, and cannot be, as accurate as, say, when simulating the collision of just
two big spheres.
Margus Ramst
