POV-Ray : Newsgroups : povray.unofficial.patches : iso-bug (yet again) Server Time
17 May 2026 17:04:26 EDT (-0400)
  iso-bug (yet again) (Message 1 to 3 of 3)
Subject: iso-bug (yet again)
Date: 4 Jul 2000 13:01:21
Message: <39621861@news.povray.org>
Well, looking at the Intermediate Isosurface tutorial (good stuff), I was
able to narrow down the problem (or what I think is a problem) with
rendering isosurface spheres with MegaPOV (see my earlier post) to the
rendering method (1 or 2) that was used.  It seems that using a declared
function in a isosurface, which I learned from the aforementioned tutorial,
causes the rendering method 2 to be used by default.  (Is this in the
MegaPOV doc's?  I guess I should read them thoroughly instead of picking out
bits and pieces)  And method 2 does not like the function x*x+y*y+z*z for
whatever reason.  I am listing the source code below for a couple of
spheres, differing by rendering method 1 or 2 alone below--> the method 2
sphere does not appear.  Needless to say, I will be using method 1
exclusively for the time being.  Hope this info will help,
Quadhall
tre### [at] ww-interlinknet
P.S.  Isosurfaces still rule!
P.P.S.  The programmers who brought us POV and MegaPOV rule even more!
the code:
#version unofficial MegaPOV 0.5;
light_source { <3,5,-8> 1 shadowless}
camera{ location  <0,0,-4> look_at   <0,0,0> }
#declare a = function { x*x+y*y+z*z }
isosurface
 function {a(x,y,z)}
 contained_by{sphere {0,4}}
 threshold 1
 method 1
 eval
 pigment{color rgb 1}
 translate <-1,0,0>
isosurface
 function {a(x,y,z)}
 threshold 1
 method 2
 eval
 translate <1,0,0>
Subject: Re: iso-bug (yet again)
Date: 6 Jul 2000 04:12:42
Message: <39643f7a$1@news.povray.org>
"hall" <tre### [at] ww-interlinknet> wrote in message
news:39621861@news.povray.org...
> the code:
> isosurface
>  function {a(x,y,z)}
>  threshold 1
>  method 1
>  eval
>  translate <-1,0,0>
> isosurface
>  function {a(x,y,z)}
>  threshold 1
>  method 2
>  eval
>  translate <1,0,0>
Try adding  a max_gradient value - eval should give you the right(ish) val,
but check the output of eval on subsequent renders to get the final correct
val for max_gradient. I had exactly the same problem.
Date: 6 Jul 2000 06:27:00
Message: <chrishuff-8BCF33.05271306072000@news.povray.org>
In article <39621861@news.povray.org>, "hall"
<tre### [at] ww-interlinknet> wrote:
I believe your problem is here...
and here...
>  function {a(x,y,z)}
Your function "a" increases exponentially from < 0, 0, 0>, and the
contained_by object goes far outside the actual surface, so a high
max_gradient is required, and calculation is slower. Try using
"sqrt(sqr(x), sqr(y), sqr(z))". The sqr() should be a little faster than
x*x, and the sqrt() will make it a linear increase.
