POV-Ray : Newsgroups : povray.unofficial.patches : More oddities with Megapov 0.5a Server Time
29 Sep 2024 13:25:09 EDT (-0400)
  More oddities with Megapov 0.5a (Message 1 to 6 of 6)
Subject: More oddities with Megapov 0.5a
Date: 29 Jun 2000 08:23:50
Message: <395b3fd6@news.povray.org>
Hi again,
I wonder, if others have experienced the same: Sometimes, when I just change
my positioning in a scene a little bit (changed a "translate") and render it
with megapov, one isosurface occasionally disappears. I can't reproduce the
problem, because when I render the scene again, the isosurface is there
again. Everything I do between the two renders is undo my changes and redo
them (with ctrl-z, ctrl-a). So I end up with the same scene after that.
Just wondering ...
Marc-Hendrik
Subject: Re: More oddities with Megapov 0.5a
Date: 30 Jun 2000 08:05:36
Message: <395C8D22.35D9BE2B@inapg.inra.fr>
Possibly a max_gradient related problem.
The usual solution is to look for the right max_gradient in the stats (it
appears when using the "eval" keyword) and write it in the isosurface
definition.
Have a look at Mike Williams' tutorial here for a better explanation :
http://www.econym.demon.co.uk/isotut/keywords.htm
G.
Date: 30 Jun 2000 08:24:52
Message: <395c9194@news.povray.org>
Thanks for the link to the tutorial, but I think that is another case. I
know those holes in Isosurfaces and yes sometimes they even disappear.
But I did not change anything in the Isosurface settings, but I translated
it only one tenth of a pov unit upward. In my case the same scene source
produces to different pictures - first, one isosurface misses, the second
time it doesn't. With this max_gradient-problem, the surface will always be
the same?
Marc-Hendrik
Gilles Tran schrieb in Nachricht <395C8D22.35D9BE2B@inapg.inra.fr>...
change
it
>definition.
>G.
Date: 30 Jun 2000 08:28:14
Message: <395c925e@news.povray.org>
Nope, translations can have an effect - at least I ran into similiar
problems just moving the camera slightly. In one position a simple sphere
iso rendered without problems, moved the camera and someone had been
munching on it.
Sorry, I would have suggested this before, but I misread your original
posting and thought you were saying that you were having odd results that
were corrected by just re-typing the same co-ords.
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in message
news:395c9194@news.povray.org...
be
> the same?
> Marc-Hendrik
> change
render
> it
> >definition.
> >G.
Date: 30 Jun 2000 10:55:54
Message: <395cb4fa$1@news.povray.org>
Tom Melly schrieb in Nachricht <395c925e@news.povray.org>...
>munching on it.
Well, actually it was not so much misread!
This were my steps:
1. render a scene with 3 isosurfaces and a plane
2. move all three isos and the plane 1/10 unit up by changing the translate
3. rendering the scene -> first iso is missing
4. (Wondering and) undo the changes by pressing ctrl-z several times,
rendering. Isosurface is again there.
5. Hm, redo the changes by pressing ctrl-a several times, rendering.
Isosurface remains there.
This problem occurred now 2 times for me. As I said I can't reproduce it
though.
<Shrug> ... if no one else had this problems it might be my computer, but I
don't think so. I can definitely life with it, as long as my scene renders
in some 3 minutes, but it would be very annoying, when rendertimes go up.
Marc-Hendrik
Date: 30 Jun 2000 11:11:35
Message: <395cb8a7@news.povray.org>
news:395cb4fa$1@news.povray.org...
> This were my steps:
translate
> though.
Hmm, IMHO it still sounds like a problem with max_gradient. I convinced
myself the other day that my PC at work was rendering an iso very
differently than my home PC. Nope, just blindness on my part. Maybe you
undid one less or one more change than you thought?
Have you tried eval? It's interesting to run eval without a max_gradient,
use the eval output to set a gradient, then run the scene again. Eval quite
often then rises above it's first estimate. For a recent scene, I would use
the output of eval to set max_gradient, only to have the scene give me a
higher eval on the next render. I had to increase max_gradient about three
times until I reached a stage when eval didn't go up any further.
