POV-Ray : Newsgroups : povray.unofficial.patches : always_sample no not working?? Server Time
16 Jun 2026 06:22:41 EDT (-0400)
  always_sample no not working?? (Message 1 to 4 of 4)
Subject: always_sample no not working??
Date: 24 Jun 2000 10:35:10
Message: <3954C71E.F65E1569@itam.cas.cz>
Hello,
   I tried to use "always sample no" directive in radiosity block
   and it still create radiosity samples when rendering in final
   resolution. I really need it, because (and it may be another
   question) it takes forever when rendering some specific line
   in image, it calculates radiosity sample for every ray used
   in antialiasing, I think. I guess, that its line when plane
   touches the horizont.
   Its a bug or I'am doing something bad?
Thanks
Disnel
Subject: Re: always_sample no not working??
Date: 28 Jun 2000 08:31:22
Message: <3959f01a@news.povray.org>
Disnel <dis### [at] itamcascz> wrote...
> Hello,
MegaPov tries to reuse samples.  If it cannot reuse ANY samples, it will
still create another sample regardless of the "always_sample" setting.  This
usually does not happen, but it can, depending on the radiosity quality
settings that you use.
-Nathan
Date: 29 Jun 2000 04:45:12
Message: <395B0C97.80FF189D@itam.cas.cz>
Hmm, its perfectly logical
It nearly hangs up at line where infinite plane touches the sky.
(plane horizont is parallel to image x axis).
I think, that its general problem. POV has problems with antialising
at this line too.
> > Hello,
> -Nathan
Date: 29 Jun 2000 05:51:03
Message: <395b1c07@news.povray.org>
Disnel <dis### [at] itamcascz> wrote:
: POV has problems with antialising at this line too.
  I wouldn't say that "povray has problems antialising at this line". What's
happening is just that a lot of to-be-antialiased pixels are unluckily
grouped so that they are calculated one after another.
  If the line was vertical instead of horizontal I suppose that the
render time would be approximately the same, but the antialiasing
would be more scattered around the image so you wouldn't notice this
kind of "lockup".
