POV-Ray : Newsgroups : povray.unofficial.patches : WinMegaPOV Server Time
23 Mar 2026 04:00:20 EDT (-0400)
  WinMegaPOV (Message 1 to 6 of 6)
Subject: WinMegaPOV
Date: 13 Jun 2000 02:25:10
Message: <3945D3F5.179B33A2@hotmail.com>
I posted this in p.w with no replies & was instructed that it was
inappropriate for that group so I cancelled it and reposted here...
I don't know if anyone else has noticed this but in WinMegaPOV (several
versions) the "Auto-Load Error file" option does not work at all
The difference between wmp & pov-official seems to be in the function
Where_Error in tokenize.c
The official version of this function (in the windows src archive
anyway) calls WIN_WhereError as follows (the comment is present too)
just before exiting
  // CJC
  WIN_WhereError (Token.Filename, Token.Token_Line_No+1, Echo_Ptr,
Echo_Indx, Token.Token_String) ;
The call is after the following line (in the function Where_Error)
  Error_Line("\n%s:%d: error: ", Token.Filename, Token.Token_Line_No+1);
I am not sure if other platform specific versions of WIN_WhereError
exist (none in the dos src - maybe there is one in the mac/other gui
src) and if they do perhaps a define of WHERE_ERROR could be used in
config.h to determine the correct one for the specific platform (just
like other platform specific functions) and in tokenize.c do
#ifndef WHERE_ERROR
#define WHERE_ERROR(a,b,c,d,e) WIN_WhereError(a,b,c,d,e)
#endif
so that compile errors do not occur when the specific platform does not
have its own version of this function
Bye
Pabs
Subject: Re: WinMegaPOV
Date: 13 Jun 2000 10:27:26
Message: <394644ce@news.povray.org>
In article <3945D3F5.179B33A2@hotmail.com> , Pabs <pab### [at] hotmailcom>
> #ifndef WHERE_ERROR
> #endif
Just use the UICB_xx family of macros, no need to define a new one. See
frame.h to find out more about the macros, and use a multi-file search to
find out where they are used in the source.
     Thorsten
Date: 18 Jun 2000 23:02:27
Message: <394D8D71.42B5626F@nospam.hotmail.com>
These UICB_xxs are all very well but
2 probs
1.
Of the src I have looked at (win, dos, unix, linux) none of the config.h
files
define these and so they all resolve to nothing in frame.h like so
#ifndef UICB_PARSE_ERROR  /* Alert UI that a parse error occurred */
#define UICB_PARSE_ERROR
#endif
Does the mac config.h define these (I can't read hqx files) & if so why don't
other platforms use them
2.
Even if they were defined there is no define corresponding to the
WIN_WhereError function - just the following 4 defines
UICB_USER_ABORT  /* alert UI that user aborted the render */
UICB_OPEN_INCLUDE_FILE  /* alert UI that an include file was opened during
parse */
UICB_CLOSE_INCLUDE_FILE  /* alert UI that an include file was closed during
parse */
so maybe a define of UICB_WhereError could be added in config.h & frame.h to
alert the UI of where in the file the parsing error occured
& in Where_Error this funcion could be called
Only WinPOV calls this kind of function
I can't find these UICB macros in the unix src (frame.h et al.)
Anyway just for the hell of it could Nathan PLEASE add the call I mentioned
in my previous post to the next version of WinMegaPOV - even if it is just
for the compiled binary.
Pabs
Date: 21 Jun 2000 03:56:15
Message: <3950751f@news.povray.org>
In article <394D8D71.42B5626F@nospam.hotmail.com> , Pabs
> 2 probs
> 1.
> files
> #endif
This is exactly how all POV-Ray config.h macros work!  If you don't use them
POV-Ray defines a useful default.  Without this you would have to fix every
config.h of every platform whenever you add a new platform configuration
macro.
Why? Simple: POV-Ray is a complex software and these macros were added late
in the 3.1 development and other platform source code was just not adapted
in time before the 3.1 release.  This happens :-)
> 2.
> parse */
> parse */
UICB_PARSE_ERROR provides the same functionality WIN_WhereError does, it has
just a different name (Where_Error only gets called on parse errors).  It
does not need to be in Where_Error. The place it is in is fine to provide
the same functionality (in function Error in userio.c), but if you don't
like UICB_PARSE_ERROR in userio.c just move (not copy!) it to tokenize.c.
I do not know why this is the case. Are you sure you are loking at the 3.1g
Unix source code? It should be in any 3.1.
Adding it would serve no purpose as it is already there, I fail to
understand the logic behind it then - sorry :-(
    Thorsten
e-mail: tho### [at] trfde
Date: 21 Jun 2000 08:32:29
Message: <3950B79F.E2903A63@mailbag.com>
(snip)
I was, shall we say, a little out of the loop on 3.1 development ;-).
The 3.1 Unix-specific files (e.g. config.h) neglect to redefine these.
Thus, the Unix version of 3.1 reverts to the defaults defined in
frame.h.  I'm not sure that's a problem, since the Unix version has no
need for UI callbacks at this stage.  Note, however, that the defaults
_are_ in frame.h in the Unix source.
-Mark Gordon
Date: 21 Jun 2000 23:07:41
Message: <3951832C.61A7EC7D@nospamthanks.hotmail.com>
> > 2 probs
> > 1.
> > files
> > #endif
> macro.
I know & understand this
Oh well
> > 2.
> > parse */
> > parse */
There is no way (for me) to know what the functionality of this macro is supposed
to be but I hope it will be used in 3.5 properly
What I want is for the Auto-load error file option in WMP to work as it does in the
official version (that is it actually works - the editor transfers to the file,
line and column of a parsing error) - no more no less
The only difference between wmp & official src that fixed this (in my msvc compiled
version) was calling WIN_WhereError in Where_Error as I mentioned in my original
post
I don't want a flame war - just the above request
Pabs
