POV-Ray : Newsgroups : povray.unofficial.patches : Help me with megapov radiosity (Cornell box) Server Time
17 May 2026 18:25:00 EDT (-0400)
  Help me with megapov radiosity (Cornell box) (Message 1 to 10 of 13)
Subject: Help me with megapov radiosity (Cornell box)
Date: 2 Jun 2000 11:19:42
Message: <3937d08c@news.povray.org>
I tried a bit different approach to the cornell box problem: I didn't use
any light source, just a bright box and let the radiosity do the rest.
  I got the illumination quite acceptable, but there are serious problems I
can't get rid of. You will immediately see them when you look at the
resulting image:
http://www.cs.tut.fi/~warp/cornell/cornell.jpg
  It uses quite extreme settings and the render time was about 48 minutes.
  I'm quite happy with the overall illumination (altough the contrast is
too high compared to the original) and color bleeding, but there are
horrible blotchy spots in the corners.
  I just can't get rid of them.
  If I specify lower quality radiosity settings I can get a very smooth
result, without those spots. However, then I don't get the darkening in the
corners either, which makes the resulting image quite different from the
original.
  If I specify higher quality settings, it doesn't get rid of the spots,
it just makes them more grainy.
  What a dilemma.
  Can anyone help me? What is the settings that can be modified to control
those artifacts?
  Another problem: Althoug the walls get darker in the corners, the ceiling
does not, for some reason. In the original image the walls and the ceiling
darken quite equally. What could be the problem?
  Here is the source code:
//     Persistence of Vision Ray Tracer Scene Description File
//     The true Cornell box...
//     PoV transcription by Stephane Marty (05/31/2000)
// "Warp" version...
#version unofficial MegaPov 0.5;
global_settings
  ambient_light 0.01
  ini_option "+QR"
  radiosity
  { pretrace_start 0.08
    pretrace_end   0.01
    count 1000
    nearest_count 10
    error_bound .5
    recursion_limit 4
    low_error_factor .5
    gray_threshold 0.2
    minimum_reuse 0.015
    brightness 1.3
    adc_bailout 0.01/1000
camera
{ location  <27.8, 27.3,-80.0>
  direction <0, 0, 1>
  up        <0, 1, 0>
  right     <-1, 0, 0>
  angle 39.5
 * colors converted from spectral space.
#declare white_cornell =
  texture
  { finish{ diffuse 1 }
    pigment { color rgb<0.740063*1.2,0.742313,0.733934*.7> }
#declare green_cornell =
  texture
    pigment { color rgb<0.162928,0.408903,0.0833759> }
#declare red_cornell =
  texture
    pigment { color rgb<0.366046,0.0371827,0.0416385>*1.5 }
#declare light_color = color rgb<0.780131,0.780409,0.775833>;
mesh
 * floor
  triangle {
    <55.28, 0.0, 0.0>,
    <0.0, 0.0, 0.0>,
    <0.0, 0.0, 55.92>
  triangle {
    <55.28, 0.0, 0.0>,
    <0.0, 0.0, 55.92>,
    <54.96, 0.0, 55.92>
 * ceiling
  triangle {
    <55.60, 54.88, 0.0>,
    <55.60, 54.88, 55.92>,
    <0.0, 54.88, 55.92>
  triangle {
    <0.0, 54.88, 55.92>,
    <0.0, 54.88, 0.0>
 * back wall
  triangle {
    <54.96, 0.0, 55.92>
  triangle {
    <54.96, 0.0, 55.92>,
    <0.0, 0.0, 55.92>
  texture { white_cornell }
mesh
 * right wall
  triangle {
    <0.0, 54.88, 0.0>,
    <0.0, 0.0, 55.92>
  triangle {
    <0.0, 54.88, 0.0>,
    <0.0, 0.0, 55.92>,
    <0.0, 0.0, 0.0>
  texture { green_cornell }
mesh
 * left wall
  triangle {
    <55.28, 0.0, 0.0>,
  triangle {
    <55.28, 0.0, 0.0>,
    <55.60, 54.88, 0.0>
  texture { red_cornell }
mesh
 * short block
  triangle {
    <13.00, 16.50, 6.50>,
    <8.20, 16.50, 22.50>,
    <24.00, 16.50, 27.20>
  triangle {
    <24.00, 16.50, 27.20>,
    <29.00, 16.50, 11.40>
  triangle {
    <29.00, 0.0, 11.40>,
    <29.00, 16.50, 11.40>,
  triangle {
    <24.00, 0.0, 27.20>
  triangle {
    <13.00, 0.0, 6.50>,
  triangle {
    <13.00, 0.0, 6.50>,
    <29.00, 0.0, 11.40>
  triangle {
    <8.20, 0.0, 22.50>,
  triangle {
    <8.20, 0.0, 22.50>,
    <13.00, 0.0, 6.50>
  triangle {
    <24.00, 0.0, 27.20>,
  triangle {
    <8.20, 0.0, 22.50>
mesh
 * tall block
  triangle {
    <42.30, 33.00, 24.70>,
    <26.50, 33.00, 29.60>,
    <31.40, 33.00, 45.60>
  triangle {
    <31.40, 33.00, 45.60>,
    <47.20 33.00 40.60>
  triangle {
    <42.30, 0.0, 24.70>,
    <47.20, 33.00, 40.60>
  triangle {
    <47.20, 33.00, 40.60>,
    <47.20, 0.0, 40.60>
  triangle {
    <47.20, 0.0, 40.60>,
  triangle {
    <31.40, 0.0 45.60>
  triangle {
    <31.40, 0.0, 45.60>,
  triangle {
    <26.50, 0.0, 29.60>
  triangle {
    <26.50, 0.0, 29.60>,
  triangle {
    <42.30, 0.0, 24.70>
// Light
box
{ <21.3,54.87,33.2><34.3,54.88,22.7> no_shadow
  pigment { light_color } finish { ambient light_color*10000 diffuse 1 }
Subject: Re: Help me with megapov radiosity (Cornell box)
Date: 2 Jun 2000 11:26:46
Message: <3937D298.3DFF5D24@kivisalo.net>
Maybe increase nearest_count?
Kari Kivisalo                                          www.kivisalo.net
Date: 2 Jun 2000 11:59:59
Message: <3937d9ff@news.povray.org>
Kari Kivisalo <kar### [at] kivisalonet> wrote:
: Maybe increase nearest_count?
  In the official povray the maximum value for nearest_count is 10. I have
used 10 in my image. Can it be bigger in megapov?
Date: 2 Jun 2000 12:01:26
Message: <3937DAB8.73F4087B@kivisalo.net>
I used 12 but didn't check warnings.
Date: 2 Jun 2000 12:12:53
Message: <3937dd04@news.povray.org>
: I used 12 but didn't check warnings.
  At the beginning of radiosit.h there's this line:
#define MAX_NEAREST_COUNT 20
  I think it means that I'll try with nearest_count 20. Will post again when
the render is finished...
Date: 2 Jun 2000 12:49:25
Message: <3937e595@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote...
I'm pretty sure there's a bug in there somewhere (still remaining from the
official version), but I haven't been able to find it.  :-(
-Nathan
Date: 2 Jun 2000 13:16:16
Message: <3937ebe0@news.povray.org>
Btw. Since the radiosity values cited in the megapov documentation work
quite well with most scenes and usually one have to modify a couple of them
for specific scenes, wouldn't it be a good idea to make those values the
default values when they are not specified? Or are they already?
  It would be a lot easier to just write something like:
radiosity
{ count 100
instead of that gigantic block :)
  If some default value is not good for a specific scene, then one can just
specify a better value in the radiosity block when needed.
Date: 2 Jun 2000 13:47:31
Message: <3937f333$1@news.povray.org>
In article <3937d08c@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> resulting image:
Looks like you need more practice putting up wallpaper properly ;-)
       Thorsten
Date: 2 Jun 2000 14:34:07
Message: <3937fe1f$1@news.povray.org>
them
> radiosity
> { count 100
That is the way it works now.  (But the defaults are currently the
low-quality settings, not the high-quality ones.)
-Nathan
Date: 2 Jun 2000 14:44:50
Message: <39380192.602F607B@yahoo.com>
you can always add any blocks you use regularly to the 'insert' menu of
pov.  that's one way to avoid typing.
> radiosity
> { count 100
