POV-Ray : Newsgroups : povray.unofficial.patches : Help me with megapov radiosity (Cornell box) Server Time
27 Jul 2026 19:29:59 EDT (-0400)
  Help me with megapov radiosity (Cornell box) (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Help me with megapov radiosity (Cornell box)
Date: 2 Jun 2000 12:01:26
Message: <3937DAB8.73F4087B@kivisalo.net>
Warp wrote:
>   In the official povray the maximum value for nearest_count is 10. I have
> used 10 in my image. Can it be bigger in megapov?
I used 12 but didn't check warnings.
Kari Kivisalo                                          www.kivisalo.net
Date: 2 Jun 2000 12:12:53
Message: <3937dd04@news.povray.org>
Kari Kivisalo <kar### [at] kivisalonet> wrote:
: I used 12 but didn't check warnings.
  At the beginning of radiosit.h there's this line:
#define MAX_NEAREST_COUNT 20
  I think it means that I'll try with nearest_count 20. Will post again when
the render is finished...
Date: 2 Jun 2000 12:49:25
Message: <3937e595@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote...
>   I'm quite happy with the overall illumination (altough the contrast is
> too high compared to the original) and color bleeding, but there are
> horrible blotchy spots in the corners.
>   I just can't get rid of them.
I'm pretty sure there's a bug in there somewhere (still remaining from the
official version), but I haven't been able to find it.  :-(
-Nathan
Date: 2 Jun 2000 13:16:16
Message: <3937ebe0@news.povray.org>
Btw. Since the radiosity values cited in the megapov documentation work
quite well with most scenes and usually one have to modify a couple of them
for specific scenes, wouldn't it be a good idea to make those values the
default values when they are not specified? Or are they already?
  It would be a lot easier to just write something like:
radiosity
{ count 100
instead of that gigantic block :)
  If some default value is not good for a specific scene, then one can just
specify a better value in the radiosity block when needed.
Date: 2 Jun 2000 13:47:31
Message: <3937f333$1@news.povray.org>
In article <3937d08c@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
>  You will immediately see them when you look at the
> resulting image:
Looks like you need more practice putting up wallpaper properly ;-)
       Thorsten
Date: 2 Jun 2000 14:34:07
Message: <3937fe1f$1@news.povray.org>
them
> radiosity
> { count 100
That is the way it works now.  (But the defaults are currently the
low-quality settings, not the high-quality ones.)
-Nathan
Date: 2 Jun 2000 14:44:50
Message: <39380192.602F607B@yahoo.com>
you can always add any blocks you use regularly to the 'insert' menu of
pov.  that's one way to avoid typing.
> radiosity
> { count 100
Date: 2 Jun 2000 23:55:53
Message: <3938825F.80E3D31C@aol.com>
I just found out recently I could make my own inserts. Saves having to type
commonly used items like camera and light_source.
> > radiosity
> > { count 100
Samuel Benge
E-Mail: STB### [at] aolcom
Visit my isosurface tutorial at http://members.aol.com/stbenge
Date: 3 Jun 2000 08:05:12
Message: <3938f478@news.povray.org>
ryan constantine <rco### [at] yahoocom> wrote:
: you can always add any blocks you use regularly to the 'insert' menu of
: pov.  that's one way to avoid typing.
  I have never typed a whole radiosity block entirely by hand anyways.
  It looks, however, much nicer with just one or two settings.
Date: 3 Jun 2000 08:07:00
Message: <3938f4e3@news.povray.org>
The only effect of raising the nearest_count was a raise in rendering
time as well; this time it was 2 hours 14 minutes. The results are perhaps
a bit better, but not good:
http://www.cs.tut.fi/~warp/cornell/cornell.jpg
