POV-Ray : Newsgroups : povray.unofficial.patches : Is this a known bug? Server Time
23 Mar 2026 04:00:31 EDT (-0400)
  Is this a known bug? (Message 1 to 9 of 9)
Subject: Is this a known bug?
Date: 31 May 2000 13:47:53
Message: <39355049@news.povray.org>
Using version 3.1g, I can't seem to create checker textures properly, at
least for planes. If I specify
pigment {checker X White}
where X is any pre-defined colour, I always get a plane which appears to
have
pigment {checker Green White}
Is this a known bug, as I've only just started using POV-Ray and am not up
to speed yet? Thanks
Chris
Subject: Re: Is this a known bug?
Date: 31 May 2000 13:54:34
Message: <39355178.666933C6@pacbell.net>
> have
> Chris
It is not a bug. You MUST specify both colors with a comma seperating
them.
In your case it should be pigment { checker X, White }
Date: 1 Jun 2000 00:22:36
Message: <slrn8jbpul.2er.ron.parker@linux.parkerr.fwi.com>
>them.
Though I consider the fact that a comma is necessary a bug.  I think
I posted the fix to bugreports, but it was a long time ago.  Basically,
POV sees "Puce Chartreuse" as just "Chartreuse".
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 1 Jun 2000 13:33:27
Message: <39369e66@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: Though I consider the fact that a comma is necessary a bug.
  I would consider not throwing a syntax error when there isn't a comma a bug.
If you see "comma expected but blah blah found instead" you will probably
see quite fast what is the problem.
Date: 1 Jun 2000 14:40:01
Message: <slrn8jdc5t.2pn.ron.parker@linux.parkerr.fwi.com>
That would be true if commas were required anywhere else in the language.
As it is, they're only required when it's necessary to disambiguate the
elements of a vector ( <1,-2,3> vs. <1 -2 3>, one of which is a 3-vector
and one of which is a 2-vector.)
Besides, the problem stems from the fact that POV doesn't recognize a
difference between
  Puce Chartreuse
and
  red 1 green .7 blue .1 green 1
If the latter followed "checker", where would you expect to find the comma?
Date: 2 Jun 2000 04:54:24
Message: <3937763f@news.povray.org>
:   red 1 green .7 blue .1 green 1
: If the latter followed "checker", where would you expect to find the comma?
  Well, that's why I think comma should be required. That is, support for
a checker statement with only one parameter instead of two should be
removed. It will only do good.
Date: 2 Jun 2000 10:24:32
Message: <slrn8jfhip.3vs.ron.parker@linux.parkerr.fwi.com>
I suggested a transparent (i.e. doesn't break most existing scenes) workaround
in .bugreports when I originally posted the problem:
|Unfortunately, you can also say "color Red Green" and get green.  This
|is not documented, and is probably a bug (the docs do say COLOUR_IDs
|should come first.)  Parse_Colour should probably UNGET and EXIT when
|it gets a second instance of any of COLOUR_ID, rgb, rgbt, rgbf, rgbft,
|or a bare vector expression.  This would make rgb 1 red 0 legal as a
|shortcut for cyan, but make rgb 1 rgb 0 become two separate colors,
|suitable for use in checkers or bricks or hexagons.
Date: 2 Jun 2000 13:14:24
Message: <3937eb70@news.povray.org>
Ok, thanks for that. Just one remaining question - why the hell does it
replace the "unspecified" colour with Green?
Date: 2 Jun 2000 14:43:56
Message: <slrn8jg0p9.432.ron.parker@linux.parkerr.fwi.com>
Because the rather unintuitive defaults for checker are, IIRC, yellow and
green.
