POV-Ray : Newsgroups : povray.unofficial.patches : Odd result with MegaPov 0.5 Server Time
29 Sep 2024 15:27:13 EDT (-0400)
  Odd result with MegaPov 0.5 (Message 1 to 10 of 11)
Subject: Odd result with MegaPov 0.5
Date: 27 May 2000 18:36:58
Message: <39304e0a$1@news.povray.org>
I'm developing a scene using Jaimes Vives' non-media clouds include file.
Oddly enough, when I use MegaPov 0.5 and use the line
#version unofficial MegaPov 0.5;
the clouds disappear. If I change the 0.5 back to 0.4 but still use the same
binary, the clouds reappear.
Has anyone else had similar problems? Is this just a side effect from a new
feature, or is it bug?
Darcy
Subject: Re: Odd result with MegaPov 0.5
Date: 27 May 2000 20:50:52
Message: <01bfc83e$95a354a0$9b7889d0@daysix>
Darcy Johnston <djo### [at] inamecomNOSPAM> wrote in article
<39304e0a$1@news.povray.org>...
same
new
I don't know.   I have had other problems, though.  The most serious is the
disc object.  Whenever combined with any other primitive, it causes the
intersection, difference, whatever, to disappear. This is especially
noticable when you #declare the object and use it over and over again. None
show.  Nathan, I know you're gonna read this, so is there anything you can
do about it??
H.E. Day
Date: 27 May 2000 21:53:51
Message: <39307BE1.682974EE@taconic.net>
I've run into this problem using the granite pattern (on which I think
Vives' clouds were based). I wonder if this is a result of the
re-hashing of the noise, bozo, etc. patterns.
For a fix try decreasing the color_map indecies.
Abe
> Darcy
Date: 27 May 2000 23:39:24
Message: <393094ec@news.povray.org>
Darcy Johnston <djo### [at] inamecomNOSPAM> wrote in message
news:39304e0a$1@news.povray.org...
same
new
  Yes, I've had a similar problem with the lensflare or lenseffects. I don't
understand it, with 0.5 its gone, 0.4 its there.  Hmmm.
          Kane
Date: 28 May 2000 09:10:49
Message: <39310CE8.7A2B9B79@peak.edu.ee>
I had very similar problems. I think the problem is the fixed noise function
(wrinkles, bozo, bumps, dents, turbulence). It actually works correctly now, but
inevitably breaks some scenes.
Try increasing the dense part of the colour_map or density_map. For example, if
the old colour_map was
{[.1 rgb 1][.3 rgb 0]}
try changing it to
{[.2 rgb 1][.4 rgb 0]}
Worked for me. It will take some tweaking to get back the old look.
Margus Ramst
Date: 29 May 2000 11:40:41
Message: <39328f79@news.povray.org>
H. E. Day <Pov### [at] aolcom> wrote...
the
None
> do about it??
Yes.  That is caused by a bug in the "fast disc patch".  I'm going to remove
the patch for 0.5a (which will be available soon).
-Nathan
Date: 29 May 2000 11:41:15
Message: <39328f9b@news.povray.org>
kane <ann### [at] mindspringcom> wrote...
don't
>           Kane
That's caused by a bug in the fast disc patch, which will be removed.
-Nathan
Date: 29 May 2000 12:05:00
Message: <3932952c$1@news.povray.org>
Abe <bul### [at] taconicnet> wrote...
> Abe
Past experiences would tell me that this is the problem.
-Nathan
Date: 29 May 2000 12:07:55
Message: <393295db@news.povray.org>
Nathan Kopp <Nat### [at] Koppcom> wrote...
> don't
> >           Kane
Or, if anyone wants to find a fix for this so we can keep the fast disc
patch, go ahead!
-Nathan
Date: 9 Jun 2000 06:28:01
Message: <3940c6b1@news.povray.org>
1. Send the problematic scene or scenes on my mail or  this news group.
Wating ...
      dmi### [at] xoommailcom
http://members.xoom.com/dmilos/
Nathan Kopp <Nat### [at] Koppcom> wrote in message
news:393295db@news.povray.org...
> > don't
> > >           Kane
> patch, go ahead!
> -Nathan
