POV-Ray : Newsgroups : povray.unofficial.patches : A question on image_width Server Time
19 Nov 2025 13:42:56 EST (-0500)
  A question on image_width (Message 1 to 10 of 12)
Subject: A question on image_width
Date: 19 May 2000 00:30:44
Message: <3924C309.975A48DA@gci.net>
Are the keywords image_width and image_height functions
or variables? I had assumed that the values were set
during the parse processes and made to be variables.
So I tried this:
#ifndef (image_width)
     #declare image_width=4;
     #declare image_height=3;
And got this
error: undeclared identifier expected but float function
'image_width' found instead.
All the docs had said was they were keywords.
I had wanted to set the values if I were using
Official POV. Is there any way to do this?
Maybe with a check of version....
Think I found my answer. Thanks for listening.
Mr. Art
Subject: Re: A question on image_width
Date: 19 May 2000 00:56:16
Message: <3924C902.AEAF39A9@gci.net>
Well, I tried this:
#version unofficial MegaPov 0.5;
#warning concat("Version Value is:",str(version,0,3),"\n")
The value printed was 3.100 in MegaPOV
Then I tried
in Official POV and got 3.100.
It didn't help.
Is there any way for the scene file to
recognize that it is on the official as opposed to MegaPOV?
Mr. Art
> So I tried this:
> #end
> And got this
> Mr. Art
Date: 19 May 2000 02:04:23
Message: <3924D8FA.213C663C@gci.net>
In the search to get the scene file to recognize
Official from Mega I found this:
#version official 3.1;
camera	{location <0,.3,-1> right image_height/image_width*x look_at
<0,.2,0> angle 40 rotate -y*30}
sphere  {0,0 pigment {rgb 0}}
still renders in MegaPOV!
'image_height' and 'image_width' are not official but are not
disabled with the #version statement. Even without the
#version statement they are active.
Is this a bug or a feature? :)
> So I tried this:
> #end
> And got this
> Mr. Art
Date: 19 May 2000 06:32:51
Message: <chrishuff_99-161F4E.05362519052000@news.povray.org>
In article <3924C309.975A48DA@gci.net>, "Mr. Art" <mr.### [at] gcinet>
They are neither...they are constants, like "pi". In other words,
read-only.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 19 May 2000 06:36:19
Message: <39251923$1@news.povray.org>
Mr. Art <mr.### [at] gcinet> wrote...
> Well, I tried this:
> Then I tried
If you want to see the unofficial version number, use:
#warning concat("Unofficial Version Value
is:",str(unofficial_version,0,3),"\n")
-Nathan
Date: 19 May 2000 06:37:03
Message: <chrishuff_99-247F72.05403719052000@news.povray.org>
In article <3924C902.AEAF39A9@gci.net>, "Mr. Art" <mr.### [at] gcinet>
From the manual, towards the top:
"Changing the unofficial version number has no affect on the official
language version number.  You can also retreive the unofficial version
number using unofficial_version.   The unofficial_version variable
returns -1 if unnofficial features are diabled."
You might be able to use #ifdef on unofficial_version, otherwise, you
will just have to include a flag in your include file that the person
rendering the file would have to change.
Date: 19 May 2000 06:38:04
Message: <3925198c@news.povray.org>
Depends on who you ask.  ;-)  Truthfully, it's a small bug.
-Nathan
Date: 19 May 2000 10:01:47
Message: <3925494b@news.povray.org>
I noticed another one. I you put something unofficial in a macro, you don't
need to declare the unofficial version.
Date: 19 May 2000 13:31:14
Message: <392579FC.980BFCF@gci.net>
I tried your suggestion. #ifdef(unofficial_version) always returns
true. #ifndef(pi) returns true. It would seem that #ifndef only
checks variables, not constants.
If #ifndef() could return false for constants, than I could use
the #ifdef(unofficial_version) that you mentioned. But having
the end user change a flag in the file was what I was trying to
around.
If #ifndef() could return false for constants or if there could
be a value that #ifndef could test properly, we could make
scene files that could adjust to the allowed features and the
end user need not _have_ to know which files need special
attention, or have to choose which flavor POV to use.
A proposal:
1) Modify #ifndef() to return false for constants.
   It seems logical that constants are defined.
2) Include a variable that #ifndef() could test even if it
   wasn't modified that is only true in the patched flavors
   of POV. Maybe like 'megapatch' being a pre defined variable
   in MegaPOV. A test on it would let the scene file know what
   to expect. I know that someone might want to use that as
   a valid variable in their scene, but someone also might
   want to use some of the other keywords that MegaPOV uses.
   Its just one more that we would learn to capitalize if we
   want to use it for our own.
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> TAG Web page: http://tag.povray.org/
Date: 20 May 2000 00:43:27
Message: <392617ef@news.povray.org>
Mr. Art wrote in message <392### [at] gcinet>...
#ifdef(unofficial_version) should return false in the official version of
POV-Ray.  In MegaPOV, it is always defined, but will be -1 if unofficial
features are disabled.  This allows the following code to be used to decide
if unofficial features are available:
  #if(unofficial_version = -1)
    Official = true;
  #else
    Official = false;
#else
  Official = true;
You can then use the value of Official elsewhere in your scene file to
determine if unofficial features can be used or not.  This, however, says
nothing about which unofficial features can be used.
Mark
